Pagina 1 di 8 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 73
[Kernel][19 Jul][N7100-N7105-I317][2.7] Adam Kernel
    Androidiano VIP L'avatar di luchino71
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Ringraziato 814 volte in 547 Posts
    Questo kernel di Wanan funziona solo su rom con base Samsung 4.1.2
    Chi flasha lo fa a proprio rischio e pericolo
    L'obiettivo principale di questo kernel rimarrà stock: non contiene alcuna CPU / GPU / IO / ottimizzazioni di memoria, include Stweaks, Boeffla suono, Tegrak Overclock e supporto "init.d" in modo da poter modificare a piacere..
    Link:
    Adam Kernel V2.7 -
    Ultima modifica di luchino71; 20-07-13 alle 10:47
  2. I seguenti 7 Utenti hanno ringraziato luchino71 per il post:
    8thphloor (29-07-13),checco1926 (05-04-13),japoco_poz14 (17-04-13),lorenzo63 (10-04-13),massarone (17-04-13),sodocacai (16-04-13),wolvie80 (05-04-13)
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Changes-log v2.7
    Removed the Auto-Root
    Fixed 200Mhz step UV
    NFS support built-in kernel
    Removed Zram support (Swap still supported)
    Few battery life tweaks
    Keep supporting All Samsung 4.1.2 Roms.
    Changes-log v2.4:
    Add Zzmoove and Lulzactiveq cpu governors (Thanks to the Authors)
    Proportional Rate Reduction for TCP (Thanks to Nandita Dukkipati)
    LTE updates built on stock LTE config (should fix some connection issues)
    CPU voltage control for UV trough Stweaks (Thanks to AndreiLux)
    Black crush fix (Thanks to Andip and AndreiLux)
    Changes-log v2.3:
    Patched with Samsung sources Update10
    Dynamic FSync Control
    Other small permission fixes from MC3 InitRamfs
    Changes-log v2.2.1:
    Workaround to enable the Equalizer on Note2
    Triangle away support (Thanks to IndiP and Delute)
    Fixed IO Scheduler Settings on Stweaks
    Other small fixes
    Changes-log v2.2:
    Merge base with Samsung sources update 9
    Stweaks support (Used AndreiLux customization of GokhanMoral generic interface, Big thanks to them)
    Add Row IO scheduler (Thanks to Yank555-lu)
    Auto install of Boeffla Sound and Stweaks Apps (Thanks to Simone201 and Gokhan)
    Changes-log v2.1:
    Boeffla sound App support (Thanks to AndiP)
    Battery charging control (AndreiLux implementation, Big thanks to him) (Port Detecting and Self-Enumerating Charger)
    Reduce Battery monitor wakelocks (Thanks to AndreiLux)
    Added the primitive IO schedulers: SIO & ZEN (Thanks to AndreiLux)
    Both Note 2 kernels are now based the official Samsung GNote2 sources U2
    Changes-log v2.0.1:
    Revert back Charging values to the stock one
    Disabled Swape support, useless and may slow down the System
    Changes-log v1.4:
    Built with XXDMB6 Initramfs (N7100 version)
    Faster USB charging (700mAh)
    Enabled ARM CPU topology
    Enabled Car Dock charging
    Enabled Swape support
    Changes-log v1.3:
    CIFS and NFS support (nfs requires loaded sunrpc and lockd)
    exFAT support
    Changes-log v1.2:
    Reduced msleep delay to 100ms for faster Lock
    Built with XXDMB5 Initramfs
    Changes-log v1.1:
    Patched with Exynos bug fixes from GS3 kernel sources (update8)
    Inital realease v1.0:
    Built from Samsung sources Update 2 (Sudden Death fixes included)
    Built with XXDMB4 Initramfs
    Init.d support
    Added support for Crt-Off (thanks to Codeworkx and Perka)
    Ultima modifica di luchino71; 20-07-13 alle 10:49
  5. I seguenti 2 Utenti hanno ringraziato luchino71 per il post:
    checco1926 (05-04-13),wolvie80 (05-04-13)
  6. #3
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Riservato .........
  7. #4
    FN6
    FN6 non è in linea
    Senior Droid L'avatar di FN6
    Cities Of The Universe
    P3600-P3700-TyTNII-HD2-GN2-GN3
    Ringraziato 226 volte in 154 Posts
    ...lo uso già sulla rom di Picciotto, e francamente sono rimasto basito dalla durata della batteria...ovviamente più la rom è ripulita dalle apk in background, meno consumerà, ma la differenza con il perseus che usavo prima è apprezzabile...va da sè che dipende sempre dall'uso che se ne fa del padellone, e che cosa si privilegia, ma per ora ne sono pienamente soddisfatto...
    ...Il mio nome è Ayrton e faccio il pilota, e corro veloce per la mia strada, anche se non è più la stessa strada, anche se non è più la stessa cosa...
  8. #5
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Riguardo a batteria è tra i migliori a mio parere
  9. #6
    Androidiani Power User L'avatar di Picciotto
    vBulletin
    Nexus 5 P9+ P10+
    Ringraziato 3,631 volte in 1,957 Posts
    Come non posso quotarvi questo è il miglior kernel stock moddato semplice ma efficace la durata della batteria è il suo pezzo forte..... il dev @adam è uno dei migliori e gentilissimi in circolazione
    Inviato dal mio Galaxy Note II con Tapatalk 2
  10. Il seguente Utente ha ringraziato Picciotto per il post:
    FN6 (03-04-13)
  11. #7
    Baby Droid L'avatar di jaccat
    Pordenone
    GS2 I9100 e N7100
    [QUOTE=Picciotto;3612093]Come non posso quotarvi questo è il miglior kernel stock moddato semplice ma efficace la durata della batteria è il suo pezzo forte..... il dev @adam è uno dei migliori e gentilissimi in circolazione
    Concordo in pieno.......
  12. #8
    Androidiano L'avatar di Elvecio
    Eccellente, lo uso dagli albori e in quanto a batteria è il migliore del mazzo.
  13. #9
    Androidiano VIP L'avatar di wolvie80
    Cameri (NO)
    Ringraziato 958 volte in 648 Posts
    Bravo luchino mancava il thread di questo fantastici kernel.
    Sotto wifi ho fatto anche 10 ore di schermo e in 3g non scendo mai sotto le 7 con la rom di fratello Picciotto veramente buono...
  14. Il seguente Utente ha ringraziato wolvie80 per il post:
    luchino71 (05-04-13)
  15. #10
    Dec 2009
    Pesaro Urbino
    Ora G4 poi boo,
    Quote Originariamente inviato da wolvie80 Visualizza il messaggio
    Ho visto che nessuno apriva il 3d e l' ho fatto io perchè davvero merita questo kernel
  16. I seguenti 2 Utenti hanno ringraziato luchino71 per il post:
    lorenzo63 (10-04-13),wolvie80 (05-04-13)
