Pagina 365 di 978 primaprima ... 265315355363364365366367375415465865 ... ultimoultimo
Visualizzazione dei risultati da 3,641 a 3,650 su 9780
[ROM][KK][4.4.4 PORTING] Ditto Note 4 (by Electron Team) | Note 4 Features
  1. #3641
    Senior Droid L'avatar di Quak
    Senior Droid L'avatar di Uz4ever
    Localitā
    Sedriano (MI)
    HTC Desire HD
    Ringraziato 87 volte in 65 Posts
    Quote Originariamente inviato da nickaka Visualizza il messaggio
    si conoscono le novitā rispetto alla 4.0?
    Sent from somewhere with my UZgalaxyNote2
  4. #3643
    Base rom: NB4 4.4.2 Leak
    more battery friendly and more stable.
    new boot sound.
    Air command perfectly working without any cosmetic issues.
    lock screen camera icon and 5 effects to chose from.
    systemui as s5. (another option available check downlaods.)
    framework as s5.
    Pen window minimize cosmetic bug fixed
    N3 Apps: browser, calculator, gallery, video player, sms
    s5 icons and theme.
    s5 settings new (bugs in one hand and toolbox.. will be fixed later.......also settings are double in app drawer)
    new snote(s5) and lockscreen effects.
    systemui includes 2 shortcuts on notification bar like s5.(quick connect needs app.)
    4 way reboot.
    holo fmradio
    new samsung apps from s5.
    pull up from fake japanese guy (thnx very much... solid app for us )
    incoming call notification
    all fixes until now.
    themes in settings (need to downlaod separately each theme... thnx bekien80 for help )
    Its still beta expect bugs.
    One hand sometimes doesnt work..
    u need to try a lot to make it work
    help us out if works for u and tell us what did u do.
  5. #3644
    Localitā
    Como
    Samsung Galaxy Note N7100
    Ringraziato 81 volte in 66 Posts
    corregetemi se sbaglio vā flashata con lo stesso procedimento della 4.0 giusto?
  6. #3645
    Localitā
    Salerno
    Samsung Galaxy Note 2
    Ragazzi non la fa scaricare. Dice che il link č stato cancellato o disabilitato. Come devo fare?
  7. #3646
    Androidiano VIP L'avatar di andy88de
    Ringraziato 754 volte in 508 Posts
    Il download č stato sospeso come annunciato da ravajiani. A breve sarā rispristinato con una 4.1 rivista o una 4.2
    Per il flash vanno preferibilmente usate le ultime versioni delle recovery scaricabili da qui sotto.
    Philz 6.19.3 (deflaggando l'opzione binary upadate)
    http://goo.im/devs/philz_touch/CWM_A..._Edition/n7100
    Twrp 2.7
    http://techerrata.com/file/twrp2/t03...7.0.0-t03g.zip
    Per il pannello notifiche e lo stile multitasking seguite questi passaggi:
    1) apri Root Explorer
    2) vai in /system e trova build.prop
    3) tieni premuto per 2 secondi build.prop
    4) Premi apri in Text Editor*
    5) edita le due rigje come segue "SM-N900S"
    ro.product.name=SM-N900S
    ro.product.device=SM-N900S
    6) riavvia
    Screenshots :
    Ultima modifica di andy88de; 12-03-14 alle 19:25
  8. I seguenti 3 Utenti hanno ringraziato andy88de per il post:
    Larenz (13-03-14),ratyur (12-03-14)
  9. #3647
    Localitā
    Salerno
    Quote Originariamente inviato da andy88de Visualizza il messaggio
    Ma č sempre BETA?
  10. #3648
    Quote Originariamente inviato da ratyur Visualizza il messaggio
    Ma č sempre BETA?
    Sie si tratta sempre di una beta.
  11. Il seguente Utente ha ringraziato andy88de per il post:
    ratyur (12-03-14)
  12. #3649
    Localitā
    Salerno
    Ok grazie mille
  13. #3650
    continua.mente
    Twrp 2.7
    6) riavvia
    Screenshots :
    Vado tranquillo se flasho l'ultima versione della twrp da recovery?
    Non ci sono problemi di compatibilitā nel restorare i backup?
