Utente della settimana: bluemask con ben 15 Thanks ricevuti negli ultimi sette giorni
[ROM ICS404 LRK 28-7-12]~CleaNote 4.00~stock~root~NoteCore~Curried Rhino edition
    Androidiano VIP L'avatar di fashion79
    Ringraziato 77 volte in 63 Posts
    The super fast, fully rooted, stock look, standard ROM for those who want maximum performance without any themes forced down your throat!
    I know there are other stock look roms out there, but I made this for myself and decided to share my efforts with the XDA community.
    ICS - LRK - STOCK THEME - FULL ROOT - HIGH PERFORMANCE - NOTECORE/SPEEDMOD KERNEL
    Features:
    - Based on ICS 4.0.4 official rom LRK
    - Deodexed, Zipaligned
    - Full root & superuser
    - XEU LQ2 & Baltic LQ3 & Indian LPA CSC files
    - 99% stock apps - removed Gmail, PlusOne, and STK
    - Completely stock look so dont ask for screenshots
    - Very high performance, very smooth 2d & 3d with high FPS
    - LRK modem
    - Latest STANDARD NOTECORE kernel
    - Latest hosts file for ad-free
    - Working bluetooth
    - No weird and unpredictable memory scripts, performance achieved the old fashioned way!
    Installation:
    Install from any rooted ROM with a safe kernel (notecore, speedmod, franco, CF). Installation script will automatically wipe /Cache and Dalvik cache for you. You can format /Data as well if you want a completely clean stock rom install with full root and performance enhancements.
    Install the usual way though CWM
    If you are on a stock rom, follow the following instructions
    Flash stock ICS rom in PC odin
    boot phone
    reboot to download mode
    flash Notecore kernel in PC odin
    reboot phone
    copy rom ZIP to sd card
    reboot to CWM
    perform a factory reset (format /data / cache)
    install rom ZIP
    You can also watch this excellent video which shows you a step-by step installation of this very ROM !
    Extras:
    Removed apps (Gmail, STK and PlusOne (google+)) can be installed with the seperate CWM zip attached to this post.
    Optimised TouchWizUX 5x6 (from SGS3) launcher CWM zip Dev-Host - CleaNote_Optimised_TouchwizUX_5x6.zip - The Ultimate Free File Hosting / File Sharing Service
    Known Issues
    Download:
    v4.00 http://hecubus.com/xda/ROM/CleaNote4.zip
    INSTALL THIS WiFi FIX AFTER FLASHING (cwm zip) http://hecubus.com/xda/other/v4_WiFi_Fix.zip
    Istruzioni per l'installazione (partire da una ROM STOCK)
    - Flashare una rom stock tramite PC Odin Guida
    - Riavviare il telefono in download mode tenendo premuto a telefono spento la compinazione Home/Volume Down/Power
    - Flashare il kernel Notecore (consigliata l'ultima release) attraverso Mobile Odin PC
    - Copiare lo ZIP della rom http://hecubus.com/xda/ROM/CleaNote4.zip nella scheda SD
    - Riavviare in Recovery (CWM)
    - Fate un Factory reset (format /data / cache)
    - Install ZIP from SD Card
    - Reboot
    - Copiate nella Scheda SD il WiFI FIX (migliora i consumi della batteria quando il terminale è in connessione WiFi http://hecubus.com/xda/other/v4_WiFi_Fix.zip
    - Riavviate in Recovery (CWM)
    - Install Zip from SD Card
    - Reboot
    Quale Kernel abbinare?
    Prestazioni: se siete alla ricerca delle prestazioni nei videgames, un kernel spinto è il Notecore da qui
    Risparmio batteria: se il vostro interesse maggiore è il consumo più limitato della batteria ma senza disprezzare le prestazioni, flashate lo SpeedMod da qui
    BUON FLASH a TUTTI
    Ultima modifica di fashion79; 07-08-12 alle 10:43
    Androidiano VIP L'avatar di poppel
    Salizzole, VR
    Samsung Galaxy Note 4
    Ringraziato 114 volte in 111 Posts
    Questa rom è basata/testata con kernel notecore... Non è un controsenso mettere un kernel differente scusa?!
    Super Droid
    Ringraziato 2,504 volte in 1,407 Posts
    Io aggiungerei, per cortesia...
    1) screenshot
    2) scorciatoia al 3d xda
    3) prime impressioni generali
    Quote Originariamente inviato da poppel Visualizza il messaggio
    Usando il Speedmod aumentano le prestazioni della batteria
    Salizzole, VR
    Ah, non sapevo dello speedMod fomunque Guardate che da tempo è già stata aperta questo thread
    https://www.androidiani.com/forum/sh...d.php?t=165592
    [ROM][ICS-LPA][07-7-12] ~ CleaNote 2.30 ~ Full stock ~ Full root ~ NoteCore ~ Buttery
    Dove si parla di cleaNote...
    Secondo me sarebbe meglio aggiornare quello e continuare di là...
    Poi ai capi l'ardua sentenza
