Pagina 1 di 76 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 751
[ROM] Criskelo's ICS V9 << LRG 4.0.4>> ICS 15 togg TW*S3* <<<AROMA INSTALL>>>
    Androidiano VIP L'avatar di soloilmeglio
    N7100 - N8000
    Ringraziato 1,796 volte in 1,191 Posts
    CriskeloRom ICS Note V11.2 LRK Base
    link del tread xda
    V11.2
    • ADD option in Aroma FullWipe
    • Fix Sony Bravia that was not installed
    • Fix Sony PlayStation that was not installed
    • Fix USB mode now works as it should to return to MTP from Aroma MOD options
    • Note 11.1 Updated kernel G
    • Add stock theme SIP
    • Add stock CRT off in theme
    • Now you can apply mods, themes, kernels and modems without complications, should only select what you want
    • Several minor tweaks
    link 1
    http://hotfile.com/dl/165743164/c172...4798B.zip.html
    link 2
    http://hotfile.com/dl/165743274/a504...4798B.zip.html
    link 3
    http://provence-service.com/~criskel...673E84798B.zip
    link 4
    d-h.st/cXo
    installazione (provenienza ics con root e recovery avanzata):
    1. Flash kernel notecore v14.1 hecubus.com/xda/kernel/GL_NOTECORE_v14-1_STD.zip
    2. RIAVVIARE IN RECOVERY
    3. WIPE DATA, CACHE E DALVIK CACHE
    4. MOUNTS AND STORAGE > FORMAT DATA, CACHE, SYSTEM
    5. FLASH DELLO ZIP DELLA ROM (l'installazione è guidata con aroma installer)
    6. Fine
    :::::::::::::::::::::: old versions :::::::::::::::::::::::
    CriskeloRom ICS Note V11.1 LRK Base No WIPE
    LINK DELLA ROM CRISKELO 11.1
    MIRROR 1 CRISKELO 11.1
    MIRROR 2 CRISKELO 11.1
    changelog della V 11.1
    •Some adjustments build.prop TKS Petking
    •Added options in aroma
    •Select from HTC or Stock DigitalClock
    •Select Sony PlayStation Games Library Certified On / Off
    •Sony Bravia Engine Library Select On / Off
    •Select Sony Walkman Music Pleasure On / Off
    •Delete SIM Block protection
    •Added language selection to Aroma Installer (English / Spanish)
    •And more
    comprende le altre specifiche della V 11 di seguito:
    Changelog V11
    • Base LRK
    • LRK MODEM
    • Kernel CF-Root LRG
    • Multi CSC
    • Deodex
    • ADD Superuser.apk
    • No incremental volume in ringtones
    • 4 Way Extended Restart Menu
    • Stock AccuweatherWidget (Transp.)
    • Stock DigitalClock (style HTC)
    • Fixing CRT-Off thanks Tungstwenty
    • Camera ICS MOD (configurable Volume keys and Camera VideoRec - save internal memory / SD card and more)
    • ADD Swype Keyboard
    • ADD Chinese Keyboard (on request)
    • Start up sound S3 by Syps
    • Add TouchWiz launcher-UX S3 (5x6) completely fix all errors (Select wallpapers / widgets etc.) TKS @Smando
    • LiveWallpapers Galaxy S3
    • New Status Bar 15 toggles (Add Spanish Frech)
    • QuickPanel settings now also in Fr y Spanish
    • ICS Color Icons in statusbar
    • Everything you need to run VPN (not tested) Thanks to ookba
    • SMS are not logged in CallLog
    • Several tweaks Framework-res.apk
    • Mod Settimgs.apk Version Rom /Fast Dormancy/ QuickPanel shortcut / CPU Spy/Working CPU/Select CSC/Samsung Secret Code.
    • Roletube (download videos from youtube SD-Card/downloads)
    • Host updated to Avoid ads
    • Add stock ICS BrowserPlus Browser
    • ICS keyboard AOSP
    • ICS keyboard Samsung
    • ADD AppWidgetPicker (Groups the same application widgets)
    • More HD Wallpapers AppStock, and CriskeloGallery
    • Themed Dialpad, statusbar and other
    • SMS 100 contacts and no convert to MMS
    • Add SGSIII MusicPlayer tks grgsiocl
    • New CallRec LRK
    • SIP working completely
    • Improved Cache SD-Card
    • Auto BackUp EFS / sdcard / efs.autobackup.img
    • Patched services.jar for using supercharger scripts
    • And other improvements more
    opzioni in Aroma installer
    Themes:
    •Clock Center
    •Clock Right
    •Theme Stock
    MODS:
    • [MOD]Modified DSP Manager with BEATS audio.(only GoogleMusic) TKS ...Awesome...
    • On/Off Auto Mass Storage
    • Select Sony PlayStation Games Library Certified On / Off
    • Sony Bravia Engine Library Select On / Off
    • Select from HTC or Stock DigitalClock
    Kernels:
    CF-Root LRG
    SpeedMod k3-11
    GL-Notecore v9
    GL-Notecore EX
    MODEMs:
    LB1
    LP6
    LPB
    LPK
    INSTALLAZIONE SICURA (DA QUALUNQUE BASE SI PROVENGA... ovviamente pre requisito fondamentale è root e cwm avanzata)
    1. Flash kernel abyss 4.2 recovery redpill touch AbyssNotekernel42RedTouchOriginalLogo.zip POI NON RIAVVIARE NORMALMENTE!!!!!!
    3. WIPE MENU > DATA, CACHE E DALVIK
    4. STORAGE MENU > FORMAT DATA, CACHE, SYSTEM
    6. Fine vi si riavvia il telefono su richiesta oppure si torna in recovery se volete flashare un kernel diverso da quelli proposti.
    segnalo dei temi per rom base LRK ... molto belli.
    (Mini Theme) 4.0.4 LRK SystemUI Sensation Theme Port
    [THEME/MOD] MiniDarkTheme 15 TOGGLES B&W and Green Versions (LATEST LRK)
    Dark Blue Theme All ROM 4.0.4
    NOTE CriskeloRom ICS V9
    LINK PER ROM, MIRROR + HACKED SVOICE
    [ROM] Criskelo's ICS V11.1 > ICS 15 togg TW*S3*-AROM - xda-developers
    INSTALLAZIONE (DA QUALUNQUE BASE SI PROVENGA... ovviamente pre requisito fondamentale è root e cwm avanzata)
    6. Fine vi si riavvia il telefono su richiesta oppure si torna in recovery se volete flashare l'addon hacked svoice.
    NOTE CriskeloRom ICS V8
    • Updated to the latest firmware S3 Launcher
    • New CallRec LQ3
    • Mod Settings
    download
    Hotfile.com: 1-CLICK Dateihoster: CriskeloRomNOTE.vICS-V8-MD5-C36FBDA6EAA88708473158907B44B606.zip
    fix camera ics
    Hotfile.com: 1-CLICK Dateihoster: Update.CriskeloRomNOTE-ICS-FIX-CameraICS-PanoramicMode.zip
    hacked svoice
    Dev-Host - UPD_Hacked.SVoice.zip - The Ultimate Free File Hosting / File Sharing Service
    installazione:
    seguire le istruzioni riportate in basso, relative alla versione 5, escludendo il punto n. 11 (per una installazione pulita)
    Se si proviene dalla precedente versione eseguire i punti:
    1- flash abyss kernel GB 3.9 da recovery AbyssNotekernel39OriginalLogo.zip NON RIAVVIARE!!!!
    2- da recovery selezionare advanced>reboot recovery
    3- wipe data-factory reset (opzionale)
    4- wipe cache
    5- wipe dalvik cache
    6- install zip from sd card (interna o esterna) e selezionare lo zip della rom
    7- ancora install zip from sd card per flashare il fix camera
    8- ancora install zip from sd card per flashare hacked svoice (opzionale)
    9- ancora install zip from sd card nel caso si voglia flashare un kernel diverso (opzionale)
    10- reboot system
    Il fix della camera ICS e HACKED SVOICE possono essere flashati anche da kernel ICS se non volete farlo subito.
    USCITA LA V7 BASATA SULL'ULTIMO FIRMWARE LQ3:
    https://hotfile.com/dl/159739034/531...76550.zip.html
    NOTE CriskeloRom ICS V7
    Changelog:
    Vedi xda
    [ROM] Criskelo's ICS - xda-developers
    installazione:
    seguire le istruzioni riportate in basso, relative alla precedente versione 5, escludendo il punto n. 11.
    varie.....
    Andromedone ha intercettato lo sfondo dadelion dell'S3 ... real!
    https://www.androidiani.com/forum/mo...ml#post1712506
    i suoni di sistema che piacciono a me.... non é detto che piacciano anche a voi :-D
    [ROM] Criskelo's ICS V6 > ICS 15 togg TW*S3* - Pagina 24 - Forum Android Italiano
    icone che piacciono a me :-D
    https://docs.google.com/open?id=0B0Z...jNFck9JaUhLSmc
    a chi interessa una bella bootanimation spettacolare (mettere in system/media)... sorpresa provatela!
    https://docs.google.com/open?id=0B0Z...29CVEMzNEFWZ0E
    altra bootanimation spettacolare ... rinominare in bootanimation.zip e mettere in system/media
    https://docs.google.com/open?id=0B0Z...mdWb013ZmYwbUE
    NOTE CriskeloRom ICS V6
    per i link di download rimando al post su xda, ce ne sono 4:
    [ROM] Criskelo's ICS V7 > ICS 15 togg TW*S3* - Page 191 - xda-developers
    installazione:
    seguire le istruzioni riportate in alto, relative alla versione 11.1 (logicamente non è presente aroma installer)
    changelog:
    Vedi xda
    Ultima modifica di soloilmeglio; 27-08-12 alle 17:32
    If you like my work and wants to keep the project alive please consider to buy me a glass of red wine or a toy for my dog
  2. Il seguente Utente ha ringraziato soloilmeglio per il post:
    sondra (15-07-12)
    Androidiano VIP L'avatar di ITAIce
    Feb 2011
    Monza & Brianza
    Galaxy Note 3, Galaxy Tab 10.1
    Ringraziato 257 volte in 239 Posts
    Sono tentato di provarla... Visto che oltretutto, sembra che la KingDroid sia stata sospesa (per lo meno, questo è quello che ho capito)...
    Inviato dal mio GT-P7510 con Tapatalk 2
  5. #3
    N7100 - N8000
    vai che va ancora meglio della king!
    con franco kernel 5 governor conservative.... cancella gli script nella cartella INIT.D e se vuoi aggiungi questi editando il file build.prop (fai un backup in caso di errori, se usi root explore lo fa in automatico)
    ro.HOME_APP_ADJ=1
    ro.HOME_APP_MEM=40960
    servono per fissare la home scelta come predefinita nella ram e per dare più ram alla home (scusa il gioco di parole)
  6. #4
    Aug 2009
    asti
    Galaxy S8
    Ringraziato 52 volte in 39 Posts
    Quote Originariamente inviato da soloilmeglio Visualizza il messaggio
    ro.HOME_APP_ADJ=1
    ciao ho installato la rom .. venivo dalla kd2.1 ho fatto i 3 wipe da abyss ok . pensi che sia meglio il kernel franco 5 rispetto all'originale ?
    se non erro il franco 5 e' settato in automatico su ondemand come lo cambio in conservative che utility utilizzare ?
    ciao
  7. #5
    Apr 2011
    Volevo provarla ma da xda non riuscivo a scaricarla, come sono le icone? Stock? Non devo gli screenshoot, perciò domando...
    Vi trovate bene? Ma alla fine quale kernel va meglio?
  8. #6
    Aug 2009
    asti
    Galaxy S8
    la trovo piu fluida con kernel stock della king droid 2.1 per ora lho appena installata
  9. #7
    Senior Droid L'avatar di Paolo60
    Ringraziato 33 volte in 21 Posts
    Si potrebbe anche provarla visto che ieri ho piallato il note ed ora ho una room ma basata su lc1 e non su ics.
    Quindi non devo nemmeno installare l'abyss kernel ma i wipe li poso fare direttamente.
  10. #8
    N7100 - N8000
    Quote Originariamente inviato da piero60 Visualizza il messaggio
    ciao
    vai col franco 5 e cancella gli script dalla cartella INIT.D
    per cambiare governor usa rom toolbox, setcpu, ci sono diverse app per farlo
  11. #9
    N7100 - N8000
    si é + fluida anche per me... con franco 5 va benissimo
  12. #10
    Feb 2011
    Monza & Brianza
    ciao
    https://play.google.com/store/apps/d...cmlsbHNDUFUiXQ..
    ro.HOME_APP_ADJ=1
    Fatto... Speriamo di non friggere qualcosa...
