Pagina 1 di 15 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 143
XXLSA DBT via ODIN
  2. I seguenti 2 Utenti hanno ringraziato qazual0990 per il post:
    giampa1972 (29-11-12),kdm (29-11-12)
    Qualcuno l' ha provata? Come bisogna flesharla tramite odin? Io provengo da rom stock 4.1.1 devo fleshare un kerne safe?
  5. #3
    Some of the Enhancements in the new Jelly Bean Update:
    - Android 4.1.2 – Build JZO54K
    - Buttery Smooth Performance & Great Stability (Thanks to Project Butter)
    - Multi-View (Multi Windows Multitasking, same as in Note II)
    - Multi-View can also be disabled
    - Page Buddy
    - Notification Panel can now be customized
    - New Additions in Notification Panel
    - Smart Rotation (Screen Display adjusts to your angle of sightings)
    - Continues Input in Samsung Keyboard (Like Swipe or Android 4.2 Keyboard)
    - Samsung’s Cloud services
    - Direct Call, Smart Stay and Pop-up Play Features
    - New Widgets From the Galaxy S III
    - 2 Home screen modes
    - New Notifications bar
    - Google Now
    Firmware Details:
    Android Version: 4.1.2 – JZO54K (Jelly Bean)
    PDA: N7000XXLSA
    CSC: N7000OXALSA
    MODEM: N7000XXLSA
    Changelist: 549786
    Build Date: 20th November 2012
    Region: Europe
    Country: Germany
    Flashing Instructions Steep by Steep:
    - Unzip the file
    - Open Odin 3.04 (http://www.mediafire.com/?hkzhyiv5t1gkxxq)
    - Restart phone in download mode (Home+power+vol down)
    - Connect phone and wait until you get a yellow sign in Odin
    - Add CODE_N7000XXLSA_549786_REV02_user_low_ship.tar.md5 to PDA
    - Add MODEM_N7000XXLSA_REV_05_CL1222228.tar.md5 to PHONE
    - Add CSC_OXA_N7000OXALSA_549786_REV02_user_low_ship.tar .md5 to CSC
    - Make sure re-partition NOT ticked
    - Start flash, sit back and wait a few minutes.
    Ultima modifica di qazual0990; 29-11-12 alle 10:18
  6. #4
    Quote Originariamente inviato da litfiba10 Visualizza il messaggio
    Parli di 411 erlos?
    Sono in test.
    Per il mom....
    Veloce, il primo avvio mi manda in it (tipo CSC ITV), Learning hub ok, airview no, forse un domani.
  7. #5
    Galaxy Note 2
    Buongiorno, meglio tenere la stock di eybee (che funziona alla grande e ha un ottima durata di batteria) oppure installare la stock da odin è meglio? voglio capire le differenze installando da zip e da tar e quindi con odin.
    Grazie in anticipo
  8. #6
    Androidiano VIP L'avatar di Meda
    Samsung Galaxy S7 edge SMG935F
    Ringraziato 583 volte in 434 Posts
    Hai messo il philz o hai la recovery originale?
    ____________________o____________________
    [ROM&KERNEL]: Sempre alla ricerca della migliore combinazione
  9. #7
    Androidiano VIP L'avatar di Jack79
    Samsung GS5 Blu - iPad Air
    Ringraziato 510 volte in 342 Posts
    Quote Originariamente inviato da qazual0990 Visualizza il messaggio
    Parli di 411 erlos?
    Sono in test.
    Per il mom....
    Aggiorna poi la prima pagina dove hai messo il link con il Changelog e le prime impressioni.
    Magari metti anche la procedura per chi viene da ICS ufficiale
  10. #8
    no la 4.1.1 stock rilasciata da samsung e l' ho fleshata direttamente da odin.. Posso fare uguale con questa rom?
  11. #9
    Quote Originariamente inviato da Meda Visualizza il messaggio
    ...mi scusi, a chi e indirizzata la domanda?
  12. #10
    Senior Droid L'avatar di ciavarro
    Iphone x & Samsung s8
    Ringraziato 67 volte in 54 Posts
    Ragazzi buoni.. Domanda quale sarebbe questa stock di ebeyee?? La leak?
