[ROOT EXPLOIT] ExynosAbuse APK Dicembre 2012
Root semplice con un'applicazione di Chainfire.....in fase di test
LINK XDA alla discussione ufficiale e download
This is an APK that uses the ExynosAbuse exploit (by alephzain) to gain root privileges and install SuperSU (v0.99) on your Exynos4 based device. That's it.
For more details on the exploit itself, see this thread: http://forum.xda-developers.com/show....php?t=2048511. The exploit is used by this APK in unmodified form. You should be very afraid of this exploit - any app can use it to gain root without asking and without any permissions on a vulnerable device. Let's hope for some fixes ASAP !
Compatibility:
Samsung Galaxy S2 GT-I9100
Samsung Galaxy S3 GT-I9300
Samsung Galaxy Note GT-N7000
Samsung Galaxy Note 2 GT-N7100
Verizon Galaxy Note 2 SCH-I605 imnuts, with locked BLs
Samsung Galaxy Note 10.1 GT-N8010 alteregon
Google Nexus 10 not compatible, Exynos5, Supercurio
Post in this thread if you have a device to add.
Notes
I'm not sure if this APK will work right on Android 2.x devices (not tested yet), doesn't mean the exploit doesn't work. So if you're on Android 2.x and this APK doesn't work for you, try doing the exploit manually
R: [ROOT EXPLOIT] ExynosAbuse APK Dicembre 2012
Andromeda1968
testato e funzionante sul Note2 date feedback
Interessante...
Ma anche questa tipologia di root inibisce gli aggiornamenti OTA oppure aggira il problema?
Semplice curiosità. ..:)
