Pagina 1 di 25 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 242
[ROM ICS404 LRQ 07-9-12]~CleaNote 6.00~stock~root~HydraCore~
    Androidiano VIP L'avatar di Sfattucci
    Caserta
    Tab S2 T715, S8 Plus, Gear S
    Ringraziato 6,165 volte in 2,803 Posts
    [ROM ICS LRQ 07.09.12] CleaNote 6.00 stock.root.HydraCore v4
    Da premettere che è la custom rom di chi ha creato il kernel Notecore e ad esso dedicata
    Features:
    - Based on ICS 4.0.4 official rom LR6
    - Deodexed, Zipaligned
    - Full root & superuser
    - XEU LQ2 & Baltic LQ3 & Indian LPA CSC files
    - 99% stock apps - removed Gmail, PlusOne, and STK
    - Completely stock look so dont ask for screenshots
    - Very high performance, very smooth 2d & 3d with high FPS
    - LRK modem
    - Latest STANDARD NOTECORE kernel
    - Latest hosts file for ad-free
    - Working bluetooth
    - No weird and unpredictable memory scripts, performance achieved the old fashioned way!
    Installation:
    Install from any rooted ROM with a safe kernel (notecore, speedmod, franco, CF). Installation script will automatically wipe /Cache and Dalvik cache for you. You can format /Data as well if you want a completely clean stock rom install with full root and performance enhancements.
    Install the usual way though CWM
    If you are on a stock rom, follow the following instructions
    Flash stock ICS rom in PC odin
    boot phone
    reboot to download mode
    flash Notecore kernel in PC odin
    reboot phone
    copy rom ZIP to sd card
    reboot to CWM
    perform a factory reset (format /data / cache)
    install rom ZIP
    Download:
    v6.00 http://d-h.st/WEv
    Changelog:
    v6.00
    - Built from German LRQ rom
    - hydraCore v4 standard kernel
    - English as default language
    - new build.prop tweak settings
    v5.00
    - Rebased to latest Indian LR6 official rom
    - NoteCore STANDARD 12.3 (yes 12.3! - especially for you, first release!)
    v4.00
    - Rebased to LRK official rom
    - Notecore v8.1 standard
    - Fixed all APK / Market updating issues
    v3.10
    - Notecore 5.1 STANDARED kernel
    - Switched back to LR1 modem
    - Fixed market updating
    - Fixed APK signature issues
    v3.00
    - Rebase to ICS 4.0.4 LRG rom
    - NoteCore v3b Standard kernel
    - Built entirely from scratch
    v2.30 http://d-h.st/ugG
    - Swapped to my kernel - GL_NOTECORE v2 (standard)
    - Build.prop changes
    - Tweak changes
    - Built for my kernel
    - Reverted to stock samsung GPU drivers
    - Improved scrolling
    - Improved memory management (no more settings in ROM - all done by kernel now)
    - Faster
    v2.20
    - Fixed Swype FCs
    - More build.prop edits
    - Full CM9 EGL / GPU driver set
    - Minor APK changes
    - Increased readahead
    v2.10
    - PNG / Debug optimised most system APKs
    - CM9 ICS 4.0.4 GPU drivers
    - CM9 ICS 4.0.4 SQLite libs
    - More build.prop modifications & cleanup
    - Added system test + factory test APKS (re-enabling dialpad codes)
    - More aggressive readahead tweak
    v2.00
    - Based on latest Indian LPA ICS rom dated June 12th
    - More tweaks
    - Debugging code removed from all APKs and framework
    - Smoother touchwiz
    - Faster app launch
    - Fixed S-Note
    v1.10
    - Built from LQ3 "Nordic" base
    - Fixed a few apps
    - Removed test APKs (lcd test etc etc)
    - Couple more tweaks and performance improvements
    - No wipe necessary coming from 1.02
    v1.02
    - Rebuilt from scratch
    - Fixed all initial setup FCs
    - Fully working from full wipe, even if you have formatted /Data
    - Default wallpapers
    - Default screen brightness settings
    - Fixed Launcher sometimes restarting
    - Performance improvements
    - Fixed S-Note FCs
    - Added crayon_physics
    - Added google_books and google_videos (forgot to ad them in last release!)
    v1.00b
    - first release
    Ultima modifica di Sfattucci; 08-09-12 alle 10:17 - Motivo: update
  2. Il seguente Utente ha ringraziato Sfattucci per il post:
    Mte90 (24-07-12)
    Caserta
    Da due ore sotto torchio! La rom è una full root stock che non sfrutta più gli script ma bensì le potenzialità del kernel cucinato col toolkit linaro ( leggi dalle features: "No weird and unpredictable memory scripts, performance achieved the old fashioned way!" e "Improved memory management (no more settings in ROM - all done by kernel now)" , ho messo la touch del GS3 e il NoteCore 2.15 standard ( aveva di suo la v2 ).
    PS: è la rom nativamente creata per supportare questo kernel NoteCore, che a quanto pare porta con se modifiche sostanziali nella gestione della ram e, se ci avete fatto caso, nell'adattarsi all'uso che se ne fa della "mattonella" ... nessuna rom, a livello teorico, potrebbe supportare meglio questo kernel. E io ... non ho parole ... se questi sono i presupposti ...
  5. #3
    il tuo parere su questa rom rispetto alla king?
  6. #4
    Caserta
    è una stock rom, quindi non personalizzata, come mamma samsung l'ha fatta ( le stock sono quelle meglio ottimizzate Software/Hardware del Note e questo è il risultato del primo bench fatto con antutu:Screenshot_2012-07-09-06-54-11[1].jpg
    Con la king, stesse modifiche non arrivava a più di 6.800 circa. Il sistema lo vedo completamente fluido e reattivo, più della kingdroid. L'unica non ha le modifiche "estetiche" della King essendo completamente una stock rom samsung "LR6"
    Ripeto è da stamattina che la uso, batteria una favola e ... non mi spreco nel ripetermi, non ho parole fantastica rom!!!!
    Ultima modifica di Sfattucci; 29-08-12 alle 15:51
  7. Il seguente Utente ha ringraziato Sfattucci per il post:
    Stevjobs (09-07-12)
  8. #5
    Androidiano VIP L'avatar di alvarotodini
    Mar 2010
    corchiano vt
    Ringraziato 108 volte in 97 Posts
    ciao Stattucci,ora ho la cm9 ma sinceramente vorrei ritornare ad ics samsung stock,prima di leggere i tuoi feed,avrei messo a occhi chiusi LQ3,ora sono molto tentato da questa rom,mi sapresti dire se il kernel è bug free?grazie
    Attenzione a Manule Tibaldi di ivrea (TO),è un truffatore
  9. #6
    Caserta
    Quote Originariamente inviato da alvarotodini Visualizza il messaggio
    Per il Kernel ( NoteKernel v2.15 una scheggia, per me il miglior kernel attualmente esistente per il note stock ) ha queste come features:
    Features:
    - Built from ICS Opensource Update 3
    - Compiled with linaro toolchain using module optimisations
    - Very fast and very stable
    - SIO scheduler as default
    - Ondemand governor as default
    - GPU locked to 267/267 MHz
    - Filesystem I/O tweak
    - CWM 5.8.1.8 included
    - Full root with SU and Superuser included from flash
    - CWM SDcards are the correct way around (/sdcard = removable SD, /internal = internal 16gb memory)
    - MMC_CAP_ERASE removed for safe wipes
    - Speedmod patch
    - Doubled framebuffer and GPU memory
    - Increased memory allocation for android surface pmem
    - /etc/init.d/S* script support
    - Lots of configuration optimisations
    E' un safe kernel e personalmente ho effettuato i tre wipe senza avere nessun brick, ma lo sconsiglio caldamente di farli visto che io sono un incosciente, mi è andata bene la prima volta ... ma onestamente eviterò la prossima andandoci coi piedi di piombo e usando l'Abyss visto che il kernel è ancora in fase di sviluppo
    Ultima modifica di Sfattucci; 09-07-12 alle 16:32
  10. Il seguente Utente ha ringraziato Sfattucci per il post:
    alvarotodini (09-07-12)
  11. #7
    Mar 2010
    corchiano vt
    grazie mille,nel fra tempo che finisca il download della rom,sto leggendo i post della criskelo,e della rocket,la king lo esclusa,per dei problemi che avevo riscontrato a suo tempo,l'hai provate le altre due?sensazioni?grazie ancora
  12. #8
    Caserta
    Ho solo da dire che questa rom è stata creata appositamente per il NoteCore Kernel. Cioè, il coder del kernel è lo stesso che ha creato la rom Cleanote ... il che dovrebbe togliere ogni dubbio di compatibilità, la rom è stata creata per questo kernel!!!! Non utilizza script ( che "usurpano" la RAM ) ma funzioni integrate nel Kernel per le varie tweak di sistema!!! Non c'è di meglio in giro come rom per supportare il NoteCore, anche perchè, a livello teorico, gli script delle varie rom potrebbero causare rallentamenti andando in conflitto magari con gli stessi tweak messi nel kernel ... ho la combinazione Cleanote 2.30 e Notecore 2.15 da stamattina ... e onestamente, il sistema pare abbia messo il turbo in tutto! Da aggiungere che è una stock LPA ( l'ultima release samsung ICS per note ) quindi è come avere l'aggiornamento ufficiale samsung, ma col turbo ).
    Ultima modifica di Sfattucci; 09-07-12 alle 18:39
  13. #9
    Riserva Navajo
    perchè non arricchisci il thread ??
    immagini e altre info....penso che la rom meriti non ti pare ?
  14. #10
    Caserta
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    Aspetto almeno un paio di cicli di batteria, e poi posto tutte le mie impressioni ... che già ora sono ottime
