Visualizzazione dei risultati da 1 a 10 su 46
[ROM] CheckROMNote™ Revo NoteHD Base LA4 2.3.6
    Riserva Navajo
    [ROM][XXLA4]CheckROM Revo NoteHD™ V5 | Unleash the Beast [JAN 26]
    No Wipe ROM
    Fatevi prima un Nandroid backup non si sa mai !
    dovete avere il root
    Changelog V5
    Based on XXLA4 Firmware from Samsung
    Kernel: CF Root
    No WIPE
    Build.prop tweaks
    Hardware Acceleration Enabled (GPU UI Enabled)
    Multi CSC
    Deodexed
    Zipaligned
    Completely Stock look
    Auto Zipaligned at every boot also including Framework
    Included libsqlite.so and libsqlite_ini.so from Android 4.0 (improves performance)
    Included app_process and system_server from Android 4.0 (improves scrolling)
    Included Modified sqlite3
    Video and Audio Gtalk Front Camera 2.3.5
    Market Fixed! (added old market)(use the same method as in kl7 to fix market to v3.4.4)
    Most of the Samsung widgets and app's removed!
    Kernel Scrips to make over all battery life better
    Added Modules to NTFS Support
    Touch Fix applied
    Smooth Spinner's
    Mod-Battery with incremental rate of 1%
    ICS Transition Animation's
    Added VOIP for Wifi
    Latest Jkay Mod Suppot (Just Download and install from Kitchen)
    Download
    http://download.checkrom.com/roms/an...950&height=420
    ATTENZIONE NON SONO RESPONSABILE DI EVENTUALI MALFUNZIONAMENTI AL VOSTRO GALAXY NOTE
    Copiare la ROM nella sd interna e flashare da CWM recovery
    Ultima modifica di Andromeda1968; 30-01-12 alle 20:36
    Androidiano VIP L'avatar di tataccio
    roma
    Al momento p10
    Ringraziato 149 volte in 135 Posts
    l'ho istallata oggi su un sgs2 rimanendo a bocca aperta... la attendo con ansia per il note..!!
    Androidiano VIP L'avatar di sedor
    Jul 2010
    varese
    Mate 7-Note Edge-Lg g watch R
    Ringraziato 90 volte in 82 Posts
    ho provato a metterla ma mi va in loop.
    ho fatto i wipe pure.
    boh.
    Androidiano VIP L'avatar di Osarco94
    HTC ONE m7 ,HTC Wildfire
    Ringraziato 163 volte in 138 Posts
    ma che feautures ha questa rom?
    In custodia
    HTC Wildfire
    rooted with Cyanogen 9
    Riserva Navajo
    sembra che abbia bootloop quindi attenzione...aspettiamo una versione nuova
    Riserva Navajo
    update
    [ROM] CheckROMNote™ Revo NoteHD V1 Base KL7 2.3.6
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    update
    Accellerazione hardware enabled....quella accellerazione?
    In custodia
    HTC Wildfire
  9. #8
    Androidiano VIP L'avatar di alvarotodini
    Mar 2010
    corchiano vt
    Ringraziato 108 volte in 97 Posts
    Spettacolare, la rom preferita sul mio gs2, un buon motivo per rootare il mio note ;-)
    Inviato dal mio GT-N7000 usando Tapatalk
    Attenzione a Manule Tibaldi di ivrea (TO),è un truffatore
  10. #9
    Jul 2010
    varese
    La sto flashando adesso,ho fatto i 3 wipe,aspetto che si riavvia..........ok tutto a posto.in test.
  11. #10
    roma
    Al momento p10
    Quote Originariamente inviato da sedor Visualizza il messaggio
    socio ma non ti fermi un secondo?? ahhahaha
    come esce una rom nuova la flashi istantaneamente??
    vabbe dici come va' anche in confronto alla romow...
    attendo info e in caso flasho.. azzolo una altra volta tre wype.. e ricominciare con le impostazioni...
    LO ODIO.. ih ih ih
