Utente del mese: megthebest con ben 44 Thanks ricevuti nell'ultimo mese
Pagina 21 di 23 primaprima ... 111920212223 ultimoultimo
Visualizzazione dei risultati da 201 a 210 su 227
[ ROM ] ROCKET ROM - v23 - XXLC1 [Update 29/03] - JKay Mod 13.6.1 - MIUI Style Theme!
  1. #201
    Androidiano L'avatar di francisti
    Mariano comense
    Galaxy NOTE... spettacolo puro
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    un'immagine mia della nuova v.20
    Posto qui sotto il ChangeLog per la v.20, in maniera che tutti abbiamo immediatamente visibilità delle modifiche e possono decidere se vale la pena o no installarla :
    Changelog ROCKET ROM-V20-XXLA4
    based on official XXLA4 Firmware + Modem XXLA4
    deodexed, zipaligned and rooted by me
    added Multi-CSC
    Android Version 2.3.6
    Abyss-Kernel 3.3
    Standard Theme as usual
    added 1% battery steps
    Added CRT-OFF
    optimized framework-res.apk for additional speed and performance!
    Added '14 Toggle Status Bar' (individual modifications can be made in App 'Quickpanelsettings' ) --> again forgot to add the App to ROM , find here as CWM flashable zip: http://forum.xda-developers.com/atta...1&d=1326960762
    Some tweaks from pikachu01 (libs + bins from Android 4.0 and some others)
    lots of other tweaks + scripts for faster performance, smoother scrolling, better RAM handling, better 3rd party launcher perfromance
    transparent Sammy Weather Widget
    Widget Clock themed by criskelo
    automatic zipalign of all system apps on every reboot
    build in 'Lower Autobrightness Levels' (saves battery)
    SIP VoIP Support for Wifi + Data
    Sony Bravia Mod for better graphic quality (might be nonsense but doesn't harm anything )
    build in Smoothness-Fix in framework.jar
    build in 'No SMS on Call Log'
    build in SMS-Mod from padlad (no limitation of contacts, no convert to MMS, ...)
    build in CallRec-Mod
    build in ICS transition animations in framework
    build in smooth spinners (thx to doctorcete)
    for getting new Market after FullWipe, download any app with old market, afterwards flash new Market: http://leomar75.celogeek.com/Note/XX...roidMarket.zip (Credits go to Team CheckROM!)
    RTL Patch can be found here: Multiupload.com - upload your files to multiple file hosting sites!
    'JKay Mod Alpha3' as an optional CWM flashable download here in StockLook : http://rocket.ph0enyx.de/rom/Rocket_..._StockLook.zip
    you can do your modification with app 'Deluxe Settings' in your App Drawer.
    --> look here for JKay Mods working: http://forum.xda-developers.com/show...25&postcount=1
    ==> above Jkay Mod is special adaption for Rocket ROM with follwowing changes
    optimized framework (size 8,5 mb!) for ultimate speed and performance
    added ICS transitions
    added smoothspinners
    lowered AutoBrightness Settings
    Potresti fare uno screenshot del nuovo widget di criskelo? Grazie
  4. #203
    Mariano comense
    Rocket 19.1 e Abyss 3.3... un accoppiata praticamente perfetta sotto tutti i punti di vista... la batteria mi sta realmente durando di più, è un dato di fatto talmente oggettivo che non posso dire sia solo una sensazione come era accaduto per altre ROM (e ne ho provate molte prima)
    Fluidità davvero buona...
    Credo che fino all'arrivo di ICS non cambierò più nulla sul mio note (al max aggiorno la jkay e installo la kitchen), perchè meglio di così non si può davvero IMHO.
  5. #204
    Androidiano VIP L'avatar di Osarco94
    HTC ONE m7 ,HTC Wildfire
    Ringraziato 163 volte in 138 Posts
    update all v20...scusa il ritardo ragazzi ma questi giorni non sto al pc un attimo
    In custodia
    HTC Wildfire
    rooted with Cyanogen 9
  6. #205
    Jan 2011
    oggi ho avuto un consumo anomalo con v20+abyss 3.3+ tema ics/jkay
    il telefono era con schermo spento sulla mia scrivania ma secondo le statistiche lo schermo era acceso e la cpu al 100% (tra l'altro con nessun processo attivo)
    se non fosse x il crollo della carica penserei che il problema sia l'app che monitora...
    Uploaded with ImageShack.us
  7. #206
    Jan 2011
    Ho letto su xda che questa rom non verrà più aggiornata.. Peccato
    Inviato dal mio GT-N7000 usando Tapatalk
  8. #207
    Riserva Navajo
    [ROM] ROCKET ROM - v21 - XXLA4 [Update 30/01] - JKay Mod Alpha3 - MIUI Style Theme!
    http://rocket.ph0enyx.de/rom/ROCKET-...-eybee1970.zip
  9. #208
    occhio a non fare un full wipe o so ca...pperi, se avete la v20 fate solo un wipe cache e dalvik
    In custodia
    HTC Wildfire
  10. #209
    Androidiano L'avatar di etta
    Dec 2009
    Genova
    Ringraziato 31 volte in 28 Posts
    Quote Originariamente inviato da Osarco94 Visualizza il messaggio
    Chi proviene da altra rom deve fare full wipe?
  11. #210
    Quote Originariamente inviato da etta Visualizza il messaggio
    Se quest'altra rom è su base la4 no
    In custodia
    HTC Wildfire
  12. Il seguente Utente ha ringraziato Osarco94 per il post:
    etta (01-02-12)
