Pagina 148 di 397 primaprima ... 4898138146147148149150158198248 ... ultimoultimo
Visualizzazione dei risultati da 1,471 a 1,480 su 3961
[KERNEL][GT-I9070/P][JB 4.1.2]CoCore[S Advance]
  1. #1471
    Senior Droid L'avatar di saumar
    Samsung Galaxy S Advance/Ace 2
    Ringraziato 132 volte in 105 Posts
    Quote Originariamente inviato da domenico086 Visualizza il messaggio
    ma esiste la versione anche per la versione normale senza nfc cioè i9070? mi puoi dire dover trovarla?
    Si chiama CoCore-E le trovi qui http://forum.xda-developers.com/show...php?p=37782653 alla fine del post tra gli allegati,al post successivo invece trovi la 7.2 scegli quella che vuoi e goditi questo CoCore by cocafè :beer:
    Xiaomi Redmi 5 plus Syberia OS
    Ringraziato 32 volte in 30 Posts
    nelle versioni E- non vedo la versione 6.8
  4. #1473
    Senior Droid L'avatar di iBluShared
    Ringraziato 148 volte in 143 Posts
    La puoi trovare al 5# post del thread di XDA del CoCore (non so se posso mettere il link)
    ex Galaxy S Advance&S4 mini
    Huawei P8 Lite
    ROM: Stock Rooted B565 MM
    SE TI SONO STATO UTILE CLICCA IL TASTO ''THANKS''
  5. #1474
    scusa questo è il tread ( Notes & Downloads(continued) )
    Bootanimations:
    I have collected some bootanimations.
    [Download Bootanimations Here]
    CWM:
    Now CWM has one issue.
    I am sorry.
    Dont use reboot recovery command to go to CWM.
    Because param driver cannot store reboot data with CWM.
    Yes,this is caused by CWM.
    You can use reboot download any time you like.
    But we provide you a workaround to use reboot recovery.
    When you go to CWM with this command,please flash this zip(In attachment) to reboot system.
    I am sorry for this issue.
    By the way,this method perhaps cannot work on other kernels.
    ( 5.6+) This issue has been figured out by OliverG96!
    ( 7.0+) CWM 6.0.3.4 is the newer version, CWM Touch is touchable CWM.
    Both of them have a warning: no file_contexts, that is no problem.
    Don't worry.
    TWRP:
    This TWRP is taken from S3 mini.It is offcial build.
    So it doesnt support internal memory.
    So /sdcard is mounted as /data/media
    When you go to TWRP for the first time,check Mount menu,choose Use external SD.
    It will remember your settings.
    Now i provide you guys a workaround.
    In our TWRP,/emmc is the internal memory.
    You can use built in file manager to edit the internal memory.
    When you want to install zips from /emmc,just tap (Up a level),then go to /emmc.
    So DONT wipe internal storage, DONT make backups to internal storage
    ( 5.6+) The UI in TWRP 2.5.0. 0 has been modified.
    In Mount Menu,tap storage bar to switch default storage position.
    File Type: zip reboot-system-cwm.zip - [Click for QR Code] (125.7 KB, 1357 views)
    File Type: zip CoCore-E-7.2-CWM.zip - [Click for QR Code] (8.97 MB, 909 views)
    File Type: zip CoCore-E-7.2-CWM-Touch.zip - [Click for QR Code] (9.12 MB, 583 views)
    File Type: zip CoCore-E-7.2-TWRP.zip - [Click for QR Code] (9.96 MB, 554 views)
  6. #1475
    quale devo selezionare? porta solo la 7.2
  7. #1476
    Senior Droid L'avatar di Stevex26
    Bologna
    Moto G 4G, Nexus 7
    Ringraziato 180 volte in 122 Posts
    1) Domenico, per favore, non creare doppi post!
    2) il download delle versioni precedenti é un po prima di quello della versione 7.2, basta che scorri un po più in alto..
    My devices:
    Moto G LTE -> Stock Lollipop 5.1
    Asus Nexus 7 -> Stock Lollipop 5.1.1
  8. #1477
    Ringraziato 227 volte in 185 Posts
  9. #1478
    Androidiano VIP L'avatar di Albertop97
    Padova
    Moto G/S Advance/Next
    Ringraziato 805 volte in 412 Posts
    Quote Originariamente inviato da gabricco Visualizza il messaggio
    nightly 7.5 u.u
    Non scrivere "grazie", se ti ho aiutato clicca su Thanks, non costa niente! ;-)
  10. #1479
    Androidiano VIP L'avatar di danny210497
    Samsung Galaxy S advance
    Ringraziato 130 volte in 119 Posts
    Per adesso la migliore versione quale rimane?
    Inviato dal mio GT-I9070
  11. #1480
    Quote Originariamente inviato da danny210497 Visualizza il messaggio
    per me la 6.8, però non ho provato ancora quest'ultima quindi non posso dare giudizi sulle 7.5.
    A breve ho però intenzione di metterla e vedere come si comporta.
