Pagina 1 di 12 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 111
[ROM][4.4.2][Team P8] SlimKat
    Ringraziato 101 volte in 70 Posts
    Nuovo colpo del Team P8 :P
    SlimKat comes with TWRP - RECOVERY!
    Information: If you get Status 7 ERROR during installing, please make sure you are on a 4.4.2 Rom.
    @Flo0008
    @GæxD @hastalafiesta
    Team Website: TEAM P8
    Prima Installazione
    1. Bisogna essere su una qualsiasi ROM 4.4.2
    2. Download ROM e Gapps
    3. Spostare ROM e Gapps nella SD esterna
    4. Riavviare in Recovery ed effettuare Wipe Data, Wipe Cache/Dalvik Cache
    5. Flashare la ROM e poi le Gapps
    6. Riavviare
    Per Utenti I9070P
    1. Download Rom, Gapps e “zip file Tee” (link tee--> https://www.dropbox.com/s/pmnmr69ii7...ler-I9070P.zip ).
    2. Spostare i tre zip nella SD esterna
    3. Riavviare in Recovery e fare un Wipe data, Wipe Cache/ Dalvik Cache
    4. Flashare la Rom, poi le Gapps e poi lo “zip file Tee”
    5. Riavviare e godersi la Rom
    Aggiornamento
    1. Scaricare la Rom
    2. Copiare il file zip nell'SD esterna
    4. Wipe Data, Cache e Dalvik Cache
    5. Flash Rom e Gapps
    6. Riavviare e godervi il nuovo aggiornamento
    Download
    SlimKat ROM HUBDROID
    Gapps
    Bug
    Da Verificare
    Changelog
    Build 1:
    -Initial Release
    Build 2:
    -OMX Fixed -Thanks to shin911 for his help
    -3.0.31 Kernel
    -WiFi Bug fixed
    -Low-Incall Sound Bug is fixed -Thanks to BMaro and Rox
    -Source Update
    BUILD 3:
    -Source update
    -3.0.31 Kernel back
    -WiFi Bug fixed
    -Low-Incall Sound Bug fixed
    -Build is more slim
    BUILD 4:
    -Source update
    -3.0.101 Kernel with OC
    -Lockscreen Notifications added
    -Novathor settings added
    MILESTONE 19/06/2014:
    -3.0.101 OC-Kernel with improvements
    -Big changes in device sources
    -Compile kernel with GCC 4.8 toolchain
    -Compile whole system with GCC 4.8
    -Latest Novathor settings added
    -Lockscreen Notifications feature update (it is buggy!!! disable it in settings/security)
    -Latest Android 4.4.3 KTU 84M
    -Apollo Music player and CM File Manager added
    -SlimKat improvements and more features
    -Some more things changed in sources
    BUILD 27/06/2014:
    -ARCHI Android Build optimization
    -Android 4.4.4 KTU84 P
    -Security fixes
    -Device source update
    -Lockscreen notification update -TEST
    -Fix Wifi Tethering in sources
    -Latest Slimkat Build 6 with fixes
    BUILD 11/07/2014:
    -App2SD
    BUILD 27/07/2014 HUBDROID:
    -Android 4.4.4 r2
    -Some fixes and latest sources
    BUILD 01/08/2014:
    -Long boot time should be fixed
    -Many changes in the device and kernel trees
    BUILD 10/08/2014:
    -Device sources (kernel, device) updated
    -Slimrom source update
    BUILD 14:
    -Performance control added
    BUILD 15:
    -Slim source update (gerrit.slimroms.net)
    FINAL:
    -Sources updatet
    -Final build of Slimkat for janice
    Features
    The real dark Slim: Invert the whole ROM including Gapps with one click.
    Notification drawer and and lockscreen shortcuts: Access your most important apps from everywhere.
    Custom Quick Settings Tiles: Why just settings? Use whatever you want.
    SlimPIE: Based on CM's PIE, inspired by PA's PIE with a light touch of Slim. A true community feature.
    All features of SlimKat qui
    Credits
    Team Canjica
    J-Team
    Carbon Rom Team
    Ringraziamenti @Tesla-MADAL93 @chirag_Galani
    @iiD4x @Rox @hastalafiesta
    @Bx16 @Force @sachinist
    @herna
    Extra
    - Impostazioni -> Performance e settare il governor con ABYSSPLUG e spuntare Set on boot
    - Premere 7 volte sul numero build per sbloccare le opzioni sviluppatore, entrare in esse e cambiare il runtime da Dalvik ad Art e riavviare (il riavvio ci metterà qualche minuto)
    Screenshot
    Link Thread Ufficiale
    ★ [ROM][4.4.2][Team P8] SlimKat ★ - xda-developers
    Ultima modifica di William990; 15-09-14 alle 13:32
  2. I seguenti 3 Utenti hanno ringraziato William990 per il post:
    Belegos (21-02-14),gianpassa (21-02-14),tommi77 (20-02-14)
    vorrei installarla, ma non mi piace che mi venga installata anche la TWRP...
    il menu è tornato quello della 4.3 what??
    è anche in italiano? come funziona?
  5. #3
    Androidiano L'avatar di Lanciator
    Samsung galaxy s advance
    Allora, la sto testando e ho dei problemi per quanto riguarda l'audio, quando vado in:
    impostazioni>audio e cerco di cambiare suoneria... Si blocca tutto quando... e dice Media Storage non risponde, oppure quando mi arrivano delle notifiche su whatsapp o simili, il telefono non emette alcun suono, risolvete, anche perché è un ottima rom
    Ultima modifica di Lanciator; 27-02-14 alle 23:45
  6. #4
    Androidiano VIP L'avatar di anch
    Ringraziato 35 volte in 32 Posts
    Ma non viene più sviluppata?
  7. #5
    Quote Originariamente inviato da anch Visualizza il messaggio
    credo che il team si stia dedicando di più sulla Carbon trascurando le altre rom
  8. #6
    Fanno male perche questa e una bomba
  9. #7
    aggiunta build 2 al primo post
  10. #8
    Senior Droid L'avatar di nextlevel
    Ringraziato 38 volte in 31 Posts
    Ciao ragazzi, allora quando la installo mi dice errore staus 7.. non so come risolvere
    Ho effettuato i wipe e il format system ma nullla
    Ho verificato il file updater script ed è apposto...
    un attimo! non avevo notato che bisogna essere su una qualsiasi rom 4.4... può influire sullo status 7??
    Ultima modifica di nextlevel; 05-04-14 alle 22:01
    Smartphone: Samsung Galaxy SIII
    ROM: Cyanogenmod 13
  11. #9
    Androidiano VIP L'avatar di tommi77
    C'è il Mare e la Montagna...
    Ringraziato 1,497 volte in 944 Posts
    Quote Originariamente inviato da nextlevel Visualizza il messaggio
    Sicuro di aver l'updater script a posto?
    Hai cancellato le stringhe o le hai corrette
  12. #10
    i9070p come da firma..
    ROM: Cyanogenmod 13
