Pagina 9 di 53 primaprima ... 789101119 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 523
Aggiornamenti sul Kernel 3.x
  1. #81
    Senior Droid L'avatar di chievo93
    i9003 cm10.1
    Ringraziato 75 volte in 66 Posts
    Aggiornamento da Adi:
    [DEV]
    So I have started playing around with stuff here..
    Thought of posting here just to keep you guys updated (But don't bug me for ETA's! )
    I just thought of porting the existing 2.6.35 code into 3.0.. and I have made a bit of progress upto now(I guess!)..
    I set up printk flags everywhere in the board-code.. and the Kernel dies 'just' before the board_init function..
    Here is the log: Uncompressing Linux... done, booting the kernel. <6>Initializing cgroup subsys - Pastebin.com
    My git: https://github.com/AdiPat/android_ke...atona-3.0-port
    My latest commit
    Look at Line 359, I commented omap2_init_common_hw() .. and as per 2.6.35 , it initializes the clockdomains..
    When I compared the LG Kernel and omapzoom kernel, I found that LG has removed some clockdomain code.
    So I will put it all back in there and try again..
    As for these warnings..
    Code:
    <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_core
    <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
    <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
    <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
    <4>omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
    <4>omap_hwmod: gpt12_fck: missing clockdomain for gpt12_fck.
    They are surely not killing the Kernel since they appear in the LG OB Kernel too(Working, bootable one) ..
    And Big thanks to hillbeast and dhiru for their experience and help..!
    nexus 4
    Ringraziato 49 volte in 45 Posts
    Quote Originariamente inviato da chievo93 Visualizza il messaggio
    [DEV]
    My latest commit
    Code:
    Per adesso funziona...piú o meno
    Inviato dal mio GT-I9003 con Tapatalk 2
  4. #83
    Samsung galaxy S I9003
    Ringraziato 30 volte in 30 Posts
    qualcuno che possa tradurlo?XD intendo non solo una traduzione inglese italiano ma più una traduzione tecnica XD
    Nexus 5 / Paranoid / Kernel: Franco
    Samsung Galaxy S SCL I9003/ XWLF3 / kernel: BCK 15 / EXT4 / Deodex / Camera with audio and battery hack / Cam quality improve / Wi-Fi Mod / Sms orario invio+illimitato
    Se ti sono stato utile in basso a sinistra c'è il tasto Thanks
  5. #84
    Androidiano L'avatar di JkDroid
    Apr 2009
    Molto semplice, Adi ha intuito una possibile soluzione al crash copiando da LG. Sono i primi passi ci vorrà del tempo per qualcosa di concreto!!
    iPhone 2G
    Galaxy S scl
    iPad 2
    Nexus 4
    https://play.google.com/store/apps/d...Vtb1JhY2UiXQ..
  6. #85
    i9003 cm10.1
    Un aggiornamento anche da Dhiru:
    An update from my side too.
    I have been trying to get MTD working on 2.6.35 before we use it on 3.0 since it would be better to fix issues with 2.6.35 and then port it to 3.0
    So far I was able to initialize the Onenand and create partitions. We will have to include yaffs and make changes to the ramdisk.
    Code:
    <6>OneNAND driver initializing
    <6>omap2-onenand omap2-onenand: initializing on CS0, phys base 0x08000000, virtual base e0880000
    <7>OneNAND Manufacturer: Samsung (0xec)
    <6>Muxed OneNAND 512MB 1.8V 16-bit (0x50)
    <6>OneNAND version = 0x0241
    <7>Chip support all block unlock
    <7>Chip has 4KiB pagesize
    <6>Scanning device for bad blocks
    <4>Bad eraseblock 2047 at 0x1ffc0000
    <5>Creating 7 MTD partitions on "omap2-onenand":
    <5>0x000001480000-0x000001c80000 : "boot"
    <5>0x000001c80000-0x000002480000 : "recovery"
    <5>0x000002480000-0x00001ca80000 : "datadata"
    <5>0x00001ca80000-0x00001dc00000 : "cache"
    <5>0x00001dc00000-0x00001e880000 : "efs"
    <5>0x00001e880000-0x00001f880000 : "radio"
    <5>0x00001f880000-0x000020000000 : "reservoir"
  7. #86
    Apr 2009
    Lui si sta occupando di un'altra cosa! Dai dai che qualcosa si muove!!!
    iPhone 2G
    Galaxy S scl
    iPad 2
    Nexus 4
  8. #87
    Androidiano VIP L'avatar di Dandelion
    Xiaomi MI5
    Ringraziato 246 volte in 208 Posts
    Stanno lavorando da poco, e già mi piace! rispetto a hillbeast rendono più partecipi gli utenti dei loro progressi, così non c'è bisogno di chiedere quanto manca ancora
    E magari pubblicando i vari log qualche altro utente potrebbe avere un'illuminazione e contribuire ^^
    My devices
    Xiaomi MI5 64GB
    iPad air 64 GB
    Dusting
    Samsung Galaxy SCL I9003
    Nexus 5x 32 GB
    Se ti sono stato d'aiuto un "thanks" è ben accetto
  9. #88
    Apr 2009
    Mi sa che hillbeast è un pezzo che è fermo, non accorgersi di come LG ha lavorato sul Kernel mi sembra grossa!!
    iPhone 2G
    Galaxy S scl
    iPad 2
    Nexus 4
  10. #89
    i9003 cm10.1
    Quote Originariamente inviato da JkDroid Visualizza il messaggio
    Basta vedere le correzioni che Adi ha fatto sul suo Github rispetto al kernel di hillbeast!
    Fix some silly typos
    Delete shit files
  11. #90
    Xiaomi MI5
    Adi si che ha tempo da perdere! credo abbia fatto più lui in due giorni che HB in 6 mesi....
    E a quanto pare LG non si smentisce mai... la qualità del codice è la stessa dei loro materiali...
    My devices
    Xiaomi MI5 64GB
    iPad air 64 GB
    Dusting
    Nexus 5x 32 GB
