Visualizzazione dei risultati da 1 a 10 su 50
[ROM][i9003][OTA] ~⌘ EHNDROIX II 12.12.x ⌘~
    Senior Droid L'avatar di chievo93
    i9003 cm10.1
    Ringraziato 75 volte in 66 Posts
    [ROM] [i9003] [OTA] • • ● EHNDROIX ™ II 13.1.31 ● • • «₪ ₪ SMOOTH STABILE ₪ ₪ SLIM»
    Welcome to the world of the EHNDROIX II !
    EHNDROIX II is a ROM based on CyanogenMod 10 created by Nitrox-developers Team. Edited and customized to the smallest details, was designed to provide users with an Jelly Bean user-friendly experience and is available for a wide range of terminals! !
    The ROM has been optimized to ensure maximum fluidity and at the same time good battery life and,
    thanks to Nitrox S, you will have the opportunity to stay up to date on the latest news and download launchers, themes "exclusive" mod and much more!
    Features
    ________________________
    • Based on CyanogenMod 10
    • New theme with new exclusive EhndroiX styles
    • Update the ROM directly from your device with integrated OTA Updater
    • Official bootanimation
    • Google Apps in Black Style
    • Xperia T Launcher
    • Flash Player Support
    • FM Radio Included
    • Send messages with exclusive EhndroiX app with a very attractive look and new features
    • Beats Audio equalizer with a unique
    • Don't you remember the title of a song? Now you can whistle or sing it and the device will give you all the information possible
    • Optimized for HD YouTube videos via 3G and Wi-Fi
    • Fantastic Official EhndroiX Wallpapers
    • GPS ultra running in all countries due to the automatic fix satellites
    • ROM in constant development (keep up to date thanks to date version)
    • Keep safe your data with Titanium Backup installed by default
    • ... and much more!
    Guide to proper installation
    Coming from a previous EHNDROIX II:
    • Download ROM
    • Wipe Cache
    • Wipe Dalvik / Cache
    • Flash EhndroiX
    • Restart
    Coming from EHNDROIX or CM7/CM9/CM10/AOKP/MIUI:
    • Download ROM
    • Wipe Data
    • Wipe Dalvik Cache
    • Flash EhndroiX
    • Restart
    Immagini allegate
    Ultima modifica di chievo93; 30-01-13 alle 21:00
    i9003 cm10.1
    Reworked ROM
    Changed Kernel in Siri Kernel RC3 HotFix
    Change LCD Density ( Looks like Phablet UI )
    System Improvement
    Removed Photos Auto-Compression
    Better Fluidity
    Better Data Connection
    Better Wi-fi Signal
    Better GPS Connection
    Updated Default Apps
    Fixed some other mini bug
    Sync to lastest CyanogenMod sources
    And other...
    Ehndroix II 13.1.31
    Update Kernel ( fixed data signals and other )
    Reworked ROM from zero
    Rom very Slimmed
    Added EhndroGapps Package ( can chose black or white pack )
    Big Graphic Update
    Big System Improvement
    Big Increased of Battery Life
    Better Fluidity
    Better Wi-fi Signal
    Created S III Style Pack
    System Improvement
    Increased Battery Life
    Added Apex Launcher
    Added Fifth indicator to Data Signals
    Added New Font
    Android 4.2.1 Jelly Bean Camera
    Decreased Glitches in Panorama Mode ( I can't fix 100% because there is in the base CyanogenMod 10 )
    Added Facebook Sync ( Google has removed it since Ice Cream Sandwich )
    New SMS Style Up with screen popup and fast notification bar control
    Updated Sony Bravia Engine Driver
    New Icon Set
    Added Miui Notes
    Added Task Manager
    Added MI File Manager ( Dark Blue Edition )
    Removed Supernotes
    Removed Android Assistant
    Removed Total Commander
    Removed Xperia T Launcher
    Updated Black and White EhndroGapps
    Fixed Titanium Backup Update in Play Store
    Fixed FM Radio
    Fixed FlashPlayer
    And other...
    EHNDROIX II 12.12.x (Prima release)
    Ultima modifica di chievo93; 08-02-13 alle 22:08
    Androidiani Power User L'avatar di 19dany84
    Piemonte
    Samsung Galaxy S23
    Ringraziato 779 volte in 660 Posts
    Quote Originariamente inviato da chievo93 Visualizza il messaggio
    Aggiornamenti con OTA Updater
    Che sarebbero????
    "Rispetta chi ti dà una mano se vuoi risolvere i problemi"
    "Non sono responsabile di qualsiasi danno arrecato al tuo dispositivo con le mie guide"
    nelle app è incluso un loro collegamento al forum,nn sò però se si possa aggiornare da li!!!
    i9003 cm10.1
    Quote Originariamente inviato da 19dany84 Visualizza il messaggio
    Che sarebbero????
    Penso significhi che si può aggiornare via OTA senza bisogno di flash!
    Androidiano VIP L'avatar di AlessandroXCV
    Dec 2009
    Ringraziato 1,646 volte in 653 Posts
    Ciao,grazie per aver aperto il thread anche qui su Androidiani
    OTA vuol dire che si possono vedere e scaricare gli update direttamente dal telefono
    Comunque se riuscissi a rendere questo thread come quello di XDA,ne sarei grato!
    Saluti
    EHNDROIX V
    Ciao ragazzi ho appena provato a flashare ma adesso il cursore che indica l'avanzamento dell'installazione è bloccato da 5 minuti con sopra la scritta update complete che faccio??? aspetto o spengo?
  9. #8
    Senior Droid L'avatar di Fabiogalaxy
    Reggio Calabria
    Samsung Galaxy s i9003
    Ringraziato 55 volte in 52 Posts
    ciao a tutti! mi chiedevo, un file solo per il download? le gapp sono comprese? un'altra domanda.. io che provengo da cm10 devo per forza fare il wipe data? grazie a tutti per la gentilezza....
    Samsung GalaxyS i9003 XXLE4 2.3.6+Root <<cpu min300/max800 Mhz>> "Meglio un post in più che un telefono morto!"
    <- se sono stato utile clicca su Grazie!
  10. #9
    Arsego
    GALAXY SI9003 EHNDROIX II
    io con ota updater ho un problema ..quando faccio aggiornamenti disponibili mi dice:
    errore nella ricerca delle informazioni: Invalid ROM(romid567342) & device (galaxysl) combo!
    che significa ??
    Grazie in anticipo
  11. #10
    Androidiano L'avatar di denix90
    Putroppo è un errore diffuso....non so il perché
    Inviato dal mio GT-i9003 usando Androidiani App
