Utente del mese: bluemask con ben 31 Thanks ricevuti nell'ultimo mese
Pagina 1 di 71 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 702
TheFrankestain^MOD[ROM][2.3.6 GB] versione 3.8
    Androidiano VIP L'avatar di bugge95
    milano
    moto g3,g2,g1,n4,scl,iphone4
    Ringraziato 598 volte in 559 Posts
    FrankestainMod:
    è basata sulla versione 2.3.6 gingerbread.
    Bug presenti:
    ad alcuni questa rom da problemi con il player video,sia su youtube sia dal player incorporato(per quest’ultimo si può risolvere scaricando gratuitamente mx player dal play store).
    ATTENZIONE: per non avere bug(video e youtube) è consigliato partire dalla versione 2.3.5 stock
    Changelog:
    Changelog:
    3.8
    -Added Play Music
    -Full delete Flash Player
    -Delete JB Lockscreen (No stable)
    -Back to stock audio lib's
    -Added busybox
    -Added Sony Playstation Certs
    -GPS optimized
    -Stock modded lockscreen from Galaxy S3 theme for Stock, S3, Furry themes (Thanks to androman1507)
    -New Galaxy S3 style theme (Based on androman1507)
    -ICS keyboard changed to S2 keyboard (More fast and nice)
    -Gallery updated
    -Solid Explorer updated
    -Gmail updated
    -Go Launcher updated
    -Google Play updated to 3.9.16
    -XDA Bam kernel as default
    -Updated wifi drivers
    -Better performance
    3.7
    -Updated app’s (Solid Explorer, Go Launcher)
    -Optimized framework-res.apk (Stock size 11mb, TF size 4mb)
    -Sense theme renamed to «Furry»
    -Fixed battery in «Furry» theme
    -Build.prop tweak’s (Internet Speed, Smooth Scroll)
    -MIUI V4 Wallpapers
    3.6.1
    -Updated Solid Explorer
    -Build.prop performance tweaks
    -Gallery fixed
    Update in Sense theme:
    -Battery fixed
    3.6
    -Deleted weather widget
    -Play Store updated to 3.8.17
    -Fixed battery capacity to 1650mah
    -LauncherPro change to Go Launcher
    -Added OTA Updater
    -Added Jelly Bean lockscreen
    -Back 14 toggle in status bar
    -Improved in audio quality
    -Added DSP Manager (Work all settings as on CM7\9)
    -Fixed ICS windows animation
    -Music Player in ICS style
    -Catigorized settings
    -Improved in camera quality
    -Updated gallery
    -Added zipalign
    -Added 14icon's to status bar
    -Status bar ICS + Sense mix
    v3.5.1
    -Back to stock music player
    -Fixed status bar style
    -ICS windows animation
    -Fixed % battery
    -Power Menu icon fixed
    -Default language - English
    -Optimized framework-res.apk for size!
    -Delete "Phone Options" from Power Menu for English and Russian languages
    Installazione Partendo da stock ROM:
    1) Eseguire un backup di applicazioni, dati e sms con un'applicazione apposita ( Titanium backup o Mybackup pro)
    2) Eseguire il backup della rubrica (Andare su rubrica ---> tasto "opzioni"--->importa/esporta
    3) Flashare un kernel compatibile con CWM (CF ROOT )
    3.1) se non hai il cf root segui questa guida: https://www.androidiani.com/forum/mo...iegazione.html
    4) Copiare il file .zip della ROM nella SD esterna
    5) Avviare telefono in Recovery (Tenere premuti tasto di accensione + tasto home + tasto del volume in su)
    6) Andare su "backup and restore", quindi selezionare nandroid backup.
    7) Effettuare il wipe data,cache e dalvik.
    8) Installare la ROM da recovery scegliendo di flashare lo zip dalla scheda sd. (install zip from sd card)
    9) Riavviare la recovery (Advanced -> Reboot Recovery)
    10) Recarsi in Mounts and Storage, quindi scegliere "Format dbdata"
    11) Wipe cache e dalvik
    12) Riavviare.
    Altre AOSP ROM (CM7/MIUI/CM9 Alpha3)
    1) Come sopra, effettuare il backup di tutto ciò che si ritiene importante (App, messaggi, rubrica, dati applicazioni, ecc... con myBackup pro o titanium)
    2) Copiare lo zip della ROM nella SD esterna
    2) Avvio in Recovery (Tenere premuti tasto di accensione, tasto home e tasto volume su)
    3) Wipe Data,cache e dalvik.
    4) Flashare lo zip della ROM da sd (Install zip from sd card)
    5) Andare su Advanced -> Reboot recovery.
    6) Andare su Mounts and Storage, poi selezionare "Format dbdata"
    7) Wipe cache e dalvik
    8) Riavvio.
    Se si arriva da cm9 alpha 4/cm10:
    Bisogna ripartire da rom stock, quindi prima flashare tramite odin 2.3.4(se volete potete flashare dopo anche 2.3.5 e2.3.6)con root e flashare la rom come scritto nel primo messaggio.
    Aggiornamento da precedenti versioni della frankestainmod
    1) Avvio in Recovery (tasto di accensione + tasto home + tasto volume su)
    2) Flash da scheda sd (install zip from sd card)
    3) Wipe cache e dalvik
    4) Riavvio.
    Problemi riscontrati
    Ricordate che in caso riscontrasse un problema diverso da quelli elencati, provate prima di chiedere a riflashare di nuovo la ROM seguendo attentamente i passaggi elencati, altrimenti rischiamo di intasare troppo il topic.
    MOD:
    mod di dany per il miglioramento del wifi: https://hotfile.com/dl/165717496/809...i9003.zip.html
    mod per funzionamento di alcune app: https://hotfile.com/dl/195000481/930...x_map.zip.html ( la mod corregge un errore presente sulla LF2 che non fa funzionare alcune applicazioni, in particolare app che fanno uso di mappe (come Foursquare, Endomondo, runtastic e simili) o che si appoggiano a servizi di geolocalizzazione (My190 e altre). grazie ad ercimau che ha pubblicato sia la descrizione sia il link)
    DOWNLOAD:
    rom[3.8]: http://thefrankenstain.ru/download/g...ankenstainmod/
    in caso non funzioni scaricate da questi link:
    http://d-h.st/iC0
    https://rapidshare.com/files/5172348...in-MOD-LF2.zip
    furry theme(miglioramento della grafica): http://d-h.st/lHj
    gs3 theme: http://d-h.st/ovA
    flash player: https://www.dropbox.com/s/d2b00kzysq...ndroid2%2B.apk
    Ovviamente ne io, ne androidiani ne tantomeno xda e il creatore della rom Frankestain(che ringraziamo) ci prendiamo responsabilità per danni al telefono.
    Grazie a:
    MorrisBuy che ci ha fatto conoscere la rom,
    frankestain(di xda) che ha creato la rom,
    dandelion perchè alcune parti per le spiegazioni le ho copiate da lui.
    Ultima modifica di bugge95; 20-03-13 alle 07:54
    Nexus4 ROM: Purity Kernel: Semaphore
    Galaxy scl ROM: cm11 Kernel: 3.0.101-CM
    Galaxy scl2 ROM: TheFrankestainMod Kernel: 3.X
  2. I seguenti 10 Utenti hanno ringraziato bugge95 per il post:
    19dany84 (11-10-12),birbapazza (31-10-12),Dandelion (12-10-12),Ercimau (26-10-12),Fabiolol96 (19-03-13),Fabiox08 (16-12-13),frank_mackey (02-11-12),Luca2717 (03-01-13),pizzo (03-11-12),rodrig (28-10-12)
    qualche immagine??
  5. #3
    milano
    Quote Originariamente inviato da sciornetto Visualizza il messaggio
    qualche immagine??
    lo so sciornetto,scusa ma mi da errore caricamento D: appena riesco le carico,comunque è uguale alla 2.3.6 con go launcher
  6. #4
    Androidiano L'avatar di genny92c
    Google Nexus 4
    lo store mi da errore di server
  7. #5
    milano
    riflasha la rom partendo dalla stock.non è un bug conosciuto,quindi credo che sia un problema di flash
  8. Il seguente Utente ha ringraziato bugge95 per il post:
    genny92c (10-10-12)
  9. #6
    Androidiano L'avatar di Ercimau
    Nexus 5
    Ringraziato 37 volte in 34 Posts
    Consiglio anche io di riflashare da stock!..
    Ecco qualche screen capture, look molto essenziale, ancora da perfezionare, ma almeno vi fate un idea!
    Google Nexus 5
    Samsung Galaxy Tab 2 p5100 - Jelly Bean 4.2.2
    Per ringraziare c'è il tasto Thanks, ed è gratis!
  10. Il seguente Utente ha ringraziato Ercimau per il post:
    gnusmas (21-10-12)
  11. #7
    milano
    per migliorare la grafica cercate i temi per go launcher e impostate quello che più preferite una cosa ottima di questa rom è che avendo go launcher è molto personalizzabile quindi vi consiglio di sfruttare quest'opportunità
  12. #8
    Posto alcuni screenshot della Rom base [senza FurryTheme ]
    SC20121010-190816.jpg SC20121010-190834.jpg SC20121010-191219.jpg SC20121010-191356 (1).jpg SC20121010-192011.jpg
    P.S.
    1) Con Quadrant e overclock MAX 1,1 ghz MIN 300mhz - Governor: smartassV2 - Scheduler: bfq ---> punteggio: 1230
    2) Vorrei aggiungere un altro dettaglio(non grave) ogni tanto Holo Locker "cazzeggia"; per chi vuole, si può disabilitare dall'app già presente o eventualmente disinstallare.
    3) Grazie bugge95 per avermi menzionato
    Current Devices:
    Acer Liquid Metal - Azur Metal & Tecnolover 1.3 kernel
    Samsung Galaxy S SCL i9003 - TheFrankenstain^MODv.3.7 & vurrutKER#9
    Huawei P8 GRA-L09 - B191 Beta 5.1.1
  13. #9
    milano
    Io con frequenza max 1000 min 300;
    scheduler noop;
    governor lagfree;
    ho ottenuto con 3 tentativi,con antutu, rispettivamente 2873 2902 e 2886...quindi con antutu è intorno ai 2880 come punteggio(che definirei molto buono per un telefono non eccellente come il nostro)
    di niente morrisbuy te li sei meritati
  14. #10
    Senior Droid L'avatar di Fabiogalaxy
    Reggio Calabria
    Samsung Galaxy s i9003
    Ringraziato 55 volte in 52 Posts
    Ragazzi , quindi ricapitolando è una versione di Gingerbred Moddata a dovre..ok ma... Go launcher lagga nello scorrere della home? qualcuno che lo ha provato? in download..mi incuriosisce...
    Samsung GalaxyS i9003 XXLE4 2.3.6+Root <<cpu min300/max800 Mhz>> "Meglio un post in più che un telefono morto!"
    <- se sono stato utile clicca su Grazie!
