Pagina 281 di 380 primaprima ... 181231271279280281282283291331 ... ultimoultimo
Visualizzazione dei risultati da 2,801 a 2,810 su 3794
[ROM][ICS 4.0.4] CyanogenMod 9.1 [Thread Ufficiale by carminelnx]
  1. #2801
    Aym
    Aym non č in linea
    Androidiano L'avatar di Aym
    Localitā
    Lg G2
    Forse conviene aspettare un altro giorno, la prossima nightly sembra corposa
    sm8660: removed uneeded On value for dualmic_enabled
    MERGED ON JUN 24TH AT 01:33:56 IN ANDROID_HARDWARE_QCOM_MEDIA
    alsa: Add TARGET_PROVIDES_LIBAUDIO flag
    MERGED ON JUN 24TH AT 01:29:27 IN ANDROID_HARDWARE_ALSA_SOUND
    Merge "Fixed apostrophe causing compilation to break" into ics
    MERGED ON JUN 23RD AT 23:01:42 IN ANDROID_PACKAGES_APPS_MMS
    MERGED ON JUN 23RD AT 23:00:16 IN ANDROID_PACKAGES_APPS_MMS
    Merge "Settings: Dutch translations" into ics
    MERGED ON JUN 23RD AT 22:59:26 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "Mms: Dutch translations" into ics
    MERGED ON JUN 23RD AT 22:59:05 IN ANDROID_PACKAGES_APPS_MMS
    Merge "Simplified Chinese Translations for Settings" into ics
    MERGED ON JUN 23RD AT 22:56:58 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "Don't reset recipients when loading draft." into ics
    MERGED ON JUN 23RD AT 22:53:11 IN ANDROID_PACKAGES_APPS_EMAIL
    Merge "mms: updated finnish translations" into ics
    MERGED ON JUN 23RD AT 22:52:48 IN ANDROID_PACKAGES_APPS_MMS
    Merge "trebuchet: updated finnish translations" into ics
    MERGED ON JUN 23RD AT 22:52:13 IN ANDROID_PACKAGES_APPS_TREBUCHET
    msm8660: Add samsung dualmic support
    MERGED ON JUN 23RD AT 22:48:50 IN ANDROID_HARDWARE_QCOM_MEDIA
    Merge "Does not copy anything" into ics
    MERGED ON JUN 23RD AT 22:48:21 IN ANDROID_BUILD
    Merge "Fixes to ensure keyboard backlight is lit when the keyboard is visible." into ics
    MERGED ON JUN 23RD AT 22:48:08 IN ANDROID_FRAMEWORKS_BASE
    Merge "Fixed build for full-eng" into ics
    MERGED ON JUN 23RD AT 22:46:39 IN ANDROID_BUILD
    Merge "Update Russian Translation-Mms-CM9" into ics
    MERGED ON JUN 23RD AT 22:45:04 IN ANDROID_PACKAGES_APPS_MMS
    Merge "Settings: Danish translation" into ics
    MERGED ON JUN 23RD AT 22:44:51 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "PT-BR: Added missing translations" into ics
    MERGED ON JUN 23RD AT 22:44:34 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "Settings: Update Turkish translations" into ics
    MERGED ON JUN 23RD AT 22:44:11 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "frameworks/base: Updated Turkish translations" into ics
    MERGED ON JUN 23RD AT 22:43:50 IN ANDROID_FRAMEWORKS_BASE
    Merge "SNR is higher when using Direct DAC" into ics
    MERGED ON JUN 23RD AT 22:43:40 IN ANDROID_PACKAGES_APPS_DSPMANAGER
    Merge "Fix FC in Bluetooth due to MAP" into ics
    MERGED ON JUN 23RD AT 22:42:57 IN ANDROID_PACKAGES_APPS_BLUETOOTH
    Merge "init: Check for symlinks with lstat() not open()" into ics
    MERGED ON JUN 23RD AT 22:42:44 IN ANDROID_SYSTEM_CORE
    Merge "[PATCH] Ensure that the port number and TXID are properly randomized." into ics
    MERGED ON JUN 23RD AT 22:42:17 IN ANDROID_BIONIC
    Merge "fnmatch.c: Update to version in OpenBSD HEAD" into ics
    MERGED ON JUN 23RD AT 22:42:01 IN ANDROID_BIONIC
    Merge "Update Russian Translation-CM9" into ics
    MERGED ON JUN 23RD AT 22:39:07 IN ANDROID_FRAMEWORKS_BASE
    libhwcomposer: Make fb width 32 aligned.
    MERGED ON JUN 23RD AT 22:38:51 IN ANDROID_HARDWARE_QCOM_DISPLAY
    Merge "Mms - Updated Italian translation" into ics
    MERGED ON JUN 23RD AT 22:38:11 IN ANDROID_PACKAGES_APPS_MMS
    Merge "frameworks_base - Updated Italian translation" into ics
    MERGED ON JUN 23RD AT 22:37:56 IN ANDROID_FRAMEWORKS_BASE
    MERGED ON JUN 23RD AT 22:37:47 IN ANDROID_FRAMEWORKS_BASE
    libqcomui: Allocate idleTimer dynamically and arm it to expire once
    MERGED ON JUN 23RD AT 22:37:23 IN ANDROID_HARDWARE_QCOM_DISPLAY
    Merge "Overlay: Close channels on s3d format change" into ics
    MERGED ON JUN 23RD AT 22:36:47 IN ANDROID_HARDWARE_QCOM_DISPLAY
    Merge "SearchWidget: passing APP_DATA to voice intent" into ics
    MERGED ON JUN 23RD AT 22:36:10 IN ANDROID_FRAMEWORKS_BASE
    Merge "make the bar fill the row more homogeneously (padding left was to big)" into ics
    MERGED ON JUN 23RD AT 22:34:34 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "remove code that was not being used at all, proper cleanup" into ics
    MERGED ON JUN 23RD AT 22:34:14 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "Update Russian Translation-DHCP time lease-CM9" into ics
    MERGED ON JUN 23RD AT 22:29:40 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "Update Japanese translation." into ics
    MERGED ON JUN 23RD AT 22:15:57 IN ANDROID_PACKAGES_APPS_MMS
    Merge "Update Japanese translation" into ics
    MERGED ON JUN 23RD AT 22:15:49 IN ANDROID_PACKAGES_APPS_PHONE
    MERGED ON JUN 23RD AT 22:11:12 IN ANDROID_PACKAGES_APPS_SETTINGS
    Add multiple UUID tags to profile (2/2 Settings)
    MERGED ON JUN 23RD AT 22:05:31 IN ANDROID_PACKAGES_APPS_SETTINGS
    Merge "Add multiple UUID tags to profile (1/2 Frameworks)" into ics
    MERGED ON JUN 23RD AT 22:04:34 IN ANDROID_FRAMEWORKS_BASE
    Fix name - part 2
    MERGED ON JUN 23RD AT 19:49:25 IN ANDROID_PACKAGES_APPS_CMWALLPAPERS
    galaxysmtd: Use .txt extraction method
    MERGED ON JUN 23RD AT 15:50:39 IN ANDROID_DEVICE_SAMSUNG_GALAXYSMTD
    aries-common: Use .txt extract method
    MERGED ON JUN 23RD AT 15:48:44 IN ANDROID_DEVICE_SAMSUNG_ARIES-COMMON
    Lg G2 D802 16Gb
    i9000 CM11
    Androidiano VIP L'avatar di punticci
    Localitā
    Vicenza
    LG Nexus 4
    Ringraziato 152 volte in 126 Posts
    Quote Originariamente inviato da carminelnx Visualizza il messaggio
    L'ultima nightly proprio non ne vuole sapere di andare con il midnight, si blocca di continuo, mi sa che ritornerō per un periodo a stock samsung
    A me va benissimo con il midnight..continuo ad essere uno dei pochi fortunati che non hanno nessun problema con questa rom vedo.Perō ho visto la tiramislim su un sgs di un mio amico e devo dire che mi ha stupito..sono combattuto devo essere onesto.
    Inviato dal mio GT-I9000
    Modello: Nexus 5
    Play Store:https://play.google.com/store/apps/d...=Davide+Dellai
    All In One System: https://play.google.com/store/apps/d...dd.androreboot
    Email: dellai.davide@gmail.com
  4. Il seguente Utente ha ringraziato punticci per il post:
    Rok3r (24-06-12)
  5. #2803
    Androidiano VIP L'avatar di carminelnx
    Localitā
    Salerno
    Nexus 4
    Ringraziato 211 volte in 153 Posts
    Quote Originariamente inviato da Aym Visualizza il messaggio
    Fix name - part 2
    Guardate bene il changelog lol, č tutto cm7 questo!
    Nexus 4 | Rom: Stock 4.4 | Kernel: Stock | Baseband: .97
  6. #2804
    Localitā
    Vicenza
    LG Nexus 4
    Omg ah ah qualcuno ha failato xD
    Modello: Nexus 5
  7. #2805
    mi sa che č la volta buona che passo all elite :/
  8. #2806
    finalmente oggi ho scaricato la 23 e hanno risolto il problema del wifi
    ci sono volute 3 settimane piene
    il tethering ancora nn vā
  9. #2807
    Localitā
    Salerno
    Nexus 4
    Comunque io ho risolto ripartendo da una situazione pulita, e la nightly con midnight fila come dio comanda )
  10. #2808
    Androidiano L'avatar di fruit
    Localitā
    Firenze
    Samsung Galaxy S II
    Ringraziato 38 volte in 30 Posts
    ...era tanto che non rimettevo una nightly e devo dire che mi ha sorpreso
    Inviato dal mio GT-I9000 con Tapatalk 2
  11. #2809
    Quote Originariamente inviato da kalikalikali Visualizza il messaggio
    l'ho messa pure io il problema wi fi persiste :/
  12. #2810
    Androidiano L'avatar di Rok3r
    Linaro non e presente in cm9 ..
    http://www.mobilejournal.net/android...r-adesso-10714
    galaxy s i9000 Cm9
