Pagina 8 di 9 primaprima ... 6789 ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 88
[ICS ROM ] MIUI.4.I9000 (Porting by lucainno) Thread by Frank_9.5
  1. #71
    Senior Droid L'avatar di Frank_9.5
    Provincia di Caserta
    Ringraziato 271 volte in 193 Posts
    Aggiunta versione 2.7.27
    Androidiano L'avatar di Cicciowii
    Genova
    Samsug Galaxy S I9000
    Quote Originariamente inviato da Frank_9.5 Visualizza il messaggio
    cosa ha di diverso per la curiosità?
    e poi devo per forza fare il wipe data ???
    Ultima modifica di Cicciowii; 01-08-12 alle 23:43
    Samsung Galaxy S GT-I9000
  4. #73
    Quote Originariamente inviato da Cicciowii Visualizza il messaggio
    Ecco il changelog
    MIUI 2.7.27 (Android 4.0)
    [System]
    - Added settings for magnifying glass text selection (See Settings > Full Settings > Input settings)
    - Added support for text editor, long press text to display magnifying glass
    - Fix some radio signal issues
    - Added support for 5 new ICS based devices; HTC Incredible S, HTC Desire S, HTC Evo 3D, Meizu MX and Samsung Galaxy Note
    [Phone]
    - Optimisation for long-press call records, select the menu for edit before call will automatically pop up the T9 panel
    - Fix the input field at the top of the dialer interface, selecting numbers would open input method keyboard
    - Fix the T9 search in some cases will lead to FC error
    - Fix setting without IP dialing numbers, the bottom of the "add numbers" section will be repeated
    [Contacts]
    - Optimise contacts interface horizontal screen issues
    - Optimisation of the group list picture loading speed
    - Fix adding 'New contact' when name is too long causes a memory overflow problem
    - Fix when synchronising Xiaomi account, decoding of some Wi-Fi services leads to FC error
    [Messaging]
    - Optimisation of network SMS availability, retransmission failure messages will be prompted when you can re-send message(s)
    - Fix problem in some cases where text messages are not displayed in the SMS sessions list
    - Fix new message, enter recipients, if more than the same number added (with and without prefix) will only show with prefix number
    - Fix system to clear SMS mute tone
    [Lock screen, status bar and notifications]
    - New (high resolution devices) support for 720P resolution with status bar
    - Fix 720P devices unlock button dropped down too far
    [Themes]
    - Optimisation to support 720P device interoperability with non-720P themes
    - Optimisation of listings loading speeds in some cases
    - Fix mix and match wallpaper option displays the wrong information
    - Fix in some cases returning from theme details page to list page results in FC error
    - Fix search results page cannot use the back key to return
    [Camera] [MIONE ONLY]
    - New real-time video filters; Classic and Lomo
    - New panoramic photo's now able to save location details
    - Fix pressing shutter, if the phone jitters make cause issues with photos
    - Fix camera store animation ghosting problems
    - Fix in some cases starting more than one camera interface
    [Gallery]
    - Added "Show on map" function to image details pages
    - Optimise the image details interface page
    - For optimal viewing of pictures, added quick switch to next picture / photo
    - Fix browsing cloud album(s) in some cases leads to FC error
    [Settings]
    - New (high-resolution devices) support for 720P resolution
    [File Explorer]
    [Browser]
    - Optimisation when selecting web content text
    [Sound Recorder]
    [Notes]
    - Fix setting note reminders leads to FC error
    [Alarm Clock]
    - Fix shutdown alarm clock, default ringtones issue
    Il wipe data non devi farlo per forza, ma se hai problemi dopo devi reinstallare la rom facendolo... quindi è meglio farlo da subito
  5. #74
    Genova
    Ecco il changelog
    [System]
    [Phone]
    [Contacts]
    [Messaging]
    [Themes]
    [Gallery]
    [Settings]
    [File Explorer]
    [Browser]
    [Sound Recorder]
    [Notes]
    [Alarm Clock]
    Funziona tutto ok
    Inviato dal mio GT-I9000 con Tapatalk 2
  6. Il seguente Utente ha ringraziato Cicciowii per il post:
    Frank_9.5 (02-08-12)
  7. #75
    Genova
    Ho letto che è uscita la 2.8.3 è vero?:confused:
  8. #76
    Sì ma bisogna aspettare che esca il porting per il nostro Galaxy S, visto che non è supportato ufficialmente
  9. Il seguente Utente ha ringraziato Frank_9.5 per il post:
    Cicciowii (03-08-12)
  10. #77
    Genova
    Ah okok
  11. #78
    Genova
    Ancora nessuna novità?
  12. #79
    Ancora no...
  13. Il seguente Utente ha ringraziato Frank_9.5 per il post:
    Cicciowii (07-08-12)
  14. #80
    Aggiornato con la versione del 15/08
