[CM10 Hybrid tablet mode][Jelly Bean] PARANOID ANDROID [Thread Ufficiale by xlory]
    Androidiano VIP L'avatar di xlory
    Trento
    Galaxy S - Galaxy S3
    Ringraziato 4,937 volte in 2,433 Posts
    IN ARRIVO TRADUZIONE PROVE.......
    Do not report ANYTHING or as moles and D4rkn3sSyS says, I will hunt you :P
    JellyBean Beta
    • CWM: Wipe Cache / Factory Reset IF you're on any ROM other than AOSP JB (May work without fullwipe from older PA versions if your /data folder is not full of things)
    • CWM: Install Zip: Rom: Download
    • CWM: Install Zip: Gapps: Download
    • CWM: Wipe Cache Partition
    • CWM: Advanced/Wipe Dalvik Cache
    • Reboot
      [*]Video tutorial: [url=http://www.youtube.com/watch?v=72Ow-YQeex4]How To Install PARANOIDANDROID Hybrid ROM (JB 4.1.1) Onto Your GSM Galaxy Nexus - YouTube[/url] - Could someone kindly record a video ? thanks
    ICS Stable
    • If you have an issue and you want to call our attention, here's what you do:
    • 1. Try everything you can, find solutions for yourself. Wipe caches, revert all your settings you have made, go back to your stock Kernel, factory reset if you have to or reflash the rom. Assume that the issue is on your side and try your best to isolate it.
    • 2. Search this thread and Cyanogenmods aswell (its our base) for possible reoccurences of your issue and hopefully solutions that may have come up.
    • 3. If you think the issue is important enough that we should cease our work and look into it, post your issue, BUT ...
    • ... stay friendly, do not demand anything, do not threaten
    • ... explain your issue as precise as you can, name the exact apps and conditions that cause trouble, help us to replicate the issue right away. If we can't there's no way we can fix it and your post will simply clutter the thread
    • ... collect evidence, keep in mind this is a developer thread so even if you are not one, do us the favor and research how to record logcat. logcat is the single most important help you can give us to resolve your issue.
    • Tina: Home
    • Cyanogenmod Team
    • Pawitp
    • TeamHackSung
    • ParanoidAndroid Team
    Ultima modifica di xlory; 27-07-12 alle 19:46
    Samsung Galaxy S - Tsunami X AOKP JB - VorteX CM10 - XanaX slim
    Samsung Galaxy S3 Tsunami X AOKP JB - UltimaRom - Vortex Cm10.1
    Samsung Galaxy P3110 - Tsunami X JB
    Ti sono stato utile?..... un Thanks....
  2. I seguenti 2 Utenti hanno ringraziato xlory per il post:
    maxsab (28-07-12),vidaqui73 (28-07-12)
    Trento
    reserved.....
    Ultima modifica di xlory; 27-07-12 alle 19:37
  5. #3
    Trento
    reserved......
  6. #4
    Trento
    reserved.....
  7. #5
    Senior Droid L'avatar di mrciccio
    Oct 2010
    Pianura, Napoli
    Xlory ma stiamo parlando del SG1?
    Inviato dal mio GT-I9000 con Tapatalk 2
    SmartPhone:
    Samsung Galaxy S3 4.1.2 stock White
    Tablet:
    Samsung Galaxy Note 10.1 3G White
  8. #6
    Trento
    Quote Originariamente inviato da mrciccio Visualizza il messaggio
    Certamente.... la base è sempre la cm10 però ha già molte personalizzazioni....
