Cosa sono e a cosa servono?!
    Senior Droid L'avatar di maschiro
    Nov 2010
    Ringraziato 89 volte in 65 Posts
    Sono riuscito a capire come abilitare i 5 tweaks tramite CWM.
    Mi potete spiegare a cosa servono e i benefici che si hanno una volta attivati?!
    Io ho la rom Dark di Tatuato con k9.
    Grazie a tutti
    Sent from my GT-I9000 using Tapatalk
    Nov 2010
    Nessuno sá aiutarmi?!
    Androidiano L'avatar di esodar1981
    Oct 2010
    Bergamo
    GT-I9100
    Ringraziato 45 volte in 40 Posts
    Voilà, eccoti accontentato.... non chiedermi di tradurre però.....
    # Remount all partitions with noatime
    atime is a setting where the filesystem updates the access time of a file. This creates a write-after-every-read which slows things down. By default all partitions are mounted with relatime, which is an optimized version of atime. noatime is the fastest, and afaik we don't need atime.
    # Tweak cfq io scheduler
    Tweaked settings of the disk io scheduler more for flash memory. Defaults are optimized for spinning harddisks. Lowered the idle wait, re-enable the low latency mode of cfq, removed the penalty for back-seeks and explicitly tell the kernel the storage is not a spinning disk.
    # Tweak kernel VM management
    Set tendency of kernel to swap to minimum, since we don't use swap anyway.
    Lower the amount of unwritten write cache to reduce lags when a huge write is required.
    Increase tendency of kernel to keep block-cache to help with slower RFS filesystem.
    Increase minimum free memory, in theory this should make the kernel less likely to suddenly run out of memory.
    # Tweak kernel scheduler
    Make the task scheduler more 'fair' when multiple tasks are running. This has a huge effect on UI and App responsiveness. These values (less aggressive settings) are 20% of the Linux defaults, and about half of the Android defaults.
    # Miscellaneous tweaks
    Manually set the starting dalvik heap size.
    Device: Samsung GT-I9100 Galaxy SII
    Rom:CM11 Faq:La bibbia di Android
  5. Il seguente Utente ha ringraziato esodar1981 per il post:
    Val3r10 (09-12-10)
  6. #4
    Nov 2010
    Ok grazie mille.
    Appena rientro vedo di far lavorare google translator.
