Pagina 92 di 327 primaprima ... 42829091929394102142192 ... ultimoultimo
Visualizzazione dei risultati da 911 a 920 su 3265
[ROM][ICS 4.0] Onecosmic - ICSSGS RC4.2 [Thread Ufficiale by olivercervera]
  1. #911
    Androidiano VIP L'avatar di Browser
    Apr 2011
    Galaxy S, Note 2 , S7 Edge
    Ringraziato 853 volte in 646 Posts
    Guys, firstly I'll try and write this up so most people can understand.
    I know many, many people love this ROM and the pure AOSP goodness. That's why RC4 got pulled. If you take a look at the issue tracker on Google Code, it's full of people already reporting bugs that are already in the 'Known Issues' section of the first page. Onecosmic is doing most of the developing for this ROM, with the rest of us adding small contributions, like test kernels, scripts, minor bug fixes and public relations. We try our best to work like a well oiled machine, but sometimes things break and bad stuff happens. Just like RC4 getting released with the WiFi/Data bug. We are building across 4 devices, I9000/B, Captivate and Vibrant and trying to compensate things for thousands of many different devices.
    I know most people may not take the time to read this, but if you do kudos to you if you did and I'm glad you understand the scale of this project. Bugs are going to happen, but please try to be considerate when posting and make a post than can be somewhat useful.
    First and foremost I would like to apologise for any false hope we may have given you by releasing RC4 with a few bugs that will stop you from using this ROM as your daily driver. I guess we got too ahead of ourselves and wanted you guys to give this a test run as we too were anticipating your response.
    Hopefully in the meantime we can find a proper fix for the issues remaining in RC4 and will provide a repack. Time is a factor here, Onecosmic is the only one with the ROM source at the moment so he is doing the ROM based fixes, whereas all of us have access to the kernel source and kernel issues can be fixed. Again, sorry about releasing RC4 and then pulling it.
    Thanks.
    CIT PAULFORDE
    Non usi Dropbox? Scoprilo qui Link
    Problemi con i governors? Leggiti la guida
    Senior Droid L'avatar di olivercervera
    Ischia (NA)
    Ringraziato 120 volte in 65 Posts
    Quote Originariamente inviato da Browser Visualizza il messaggio
    Col nuovo aggiornamento kernel è possibile solo che sto avendo problemi con il wifi, è connesso ma non riesco a navigare neanche dopo i wipe!
    Che diavolo dici? Non esiste ancora nessun fix. E' proprio quello il problema, il wifi e la connessione 3g funzionano male.
    Nexus 5 32GB
    CM12
    Google Nexus 4 VENDUTO
    Samsung Galaxy Nexus i9250 VENDUTO
    Samsung Galaxy S i9000 VENDUTO
    Nexus 7 2012 VENDUTO
    RICORDA IL THANKS QUI SOTTO A SX!
  4. #913
    Apr 2011
    Quote Originariamente inviato da olivercervera Visualizza il messaggio
    Non ti scaldare, siccome prima non riuscivo a impostare la frequenza minima a 100 mhz con il nuovo aggiornamento kernel sono riuscito! Avevo capito che si riferiva a quello il nuovo utente
  5. #914
    Nov 2010
    Ringraziato 14 volte in 2 Posts
    io l'ho scaricata in tempo e navigo tranquillaente sia wifi che 3g °°
  6. #915
    Androidiano L'avatar di pisquito
    Oct 2010
    Ringraziato 2 volte in 1 Post
    ragazzi,sapete per caso se con la nuova versione vi saranno il fix per il market che non permette di acquistare app e della bussola?grazie in anticipo
  7. #916
    Androidiano L'avatar di luca2006
    Pescara
    SGSI/II-Bold9900-iPhone4-MotoG
    Ringraziato 38 volte in 20 Posts
    Cè scritto nel changelog...cè scritto ed è stato detto..
    Se sono stato di aiuto, clicca sul tasto Thanks
  8. #917
    Oct 2010
    Quote Originariamente inviato da luca2006 Visualizza il messaggio
    perdonami,ho notato solo ora
    però non dice se c'è il fix della bussola,ma penso di si.
    Ultima modifica di pisquito; 30-01-12 alle 21:40
  9. #918
    Ischia (NA)
    Il kernel nella rom integra sia i 100mhz che il Deep Idle! Non vedo nessun aggiornamento, se non quello stesso nella rom che ha anche i voltaggi fixati..
    Nexus 5 32GB
    CM12
  10. #919
    Androidiano L'avatar di pyrmici
    ragazzi ma per flashare l'rc4 non ci sarà bisogno di fare il wipe data vero?
  11. #920
    ma è una mia impressione o con l'ultimo kernel il display è meno luminoso?
    Ultima modifica di pyrmici; 30-01-12 alle 22:12
LinkBacks (?)
  1. 06-08-12, 06:37
  2. 14-05-12, 10:23
  3. 30-04-12, 13:05
  4. 04-03-12, 13:53
  5. 04-03-12, 10:00
  6. 24-02-12, 15:23
  7. 21-02-12, 19:17
  8. 20-02-12, 12:47
  9. 19-02-12, 20:05
  10. 19-02-12, 18:48
  11. 19-02-12, 18:41
  12. 19-02-12, 12:34
  13. 19-02-12, 11:59
  14. 19-02-12, 11:05
  15. 19-02-12, 09:47
  16. 19-02-12, 08:32
  17. 19-02-12, 08:28
  18. 09-02-12, 18:29
  19. 08-02-12, 17:37
  20. 06-02-12, 10:14
  21. 28-01-12, 21:00
  22. 12-01-12, 18:32
  23. 06-01-12, 00:30
  24. 04-01-12, 12:57
  25. 27-12-11, 17:46
  26. 26-12-11, 20:53
