Pagina 1 di 614 1231151101501 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 6140
[MOD][12][GHWC2][G973/75F] ☼ CarHDMod V.10.0 ☼ [14/04/23]
    Russi - RA
    Ringraziato 12,221 volte in 4,782 Posts
    CarHDMod V.10.0 14/04/23
    Basato su G975FXXUGHWC2 firmware
    Android 12
    G975F-G973F-G970F Devices Supported
    #Mod#
    -Aroma Installer
    -Based on Firmware G975FXXUGHWC2
    -CSC Features
    -Tweaks in build.prop
    -1000 Extra Fonts
    -AppLock
    -Bixby Button remap in aroma
    -Debloating options in aroma
    -Splash Boot for each model
    -Fixed Bluetooth
    -3Minit Battery
    -Power Virtual button on top/right
    -BatteryBar in Navigation Bar
    -Carrier Label on top/left
    #Rom Control#
    MODS
    -Enable/Disable Open with
    -Power Menu Background
    -Drawer TWLauncher Background
    STATUSBAR
    -3Minit Battery App
    -Carrier Label
    -Show / Hide Statusbar Icons
    -Show / Hide Virtual lock button in the statusbar
    NAVIGATION BAR
    -Navigation Battery Bar
    LOCKSCREEN
    -Hide/Show texts on bottom in the lockscreen (like swipe to open)
    -Allow quick reply on lockscreen
    PULLDOWN
    -Battery bar in Big Battery
    OTA and Links
    -OTA
    -Donate to carotix
    Download v.10.0
    Installation for v.10.0:
    1- Turn off the device and put it in download mode with the bixby / vol down button and inserting the cable to the PC at this point open Odin remove the check mark from autoreboot
    2- Load the AP patched file downloaded from HERE together with BL , CP and HOME_CSC .... if you put the CSC you lose all the data
    3- Start the flash and wait
    4- At the end with the power / vol down keys force the switch off as soon as the screen goes black press vol + / bixby / power to go in recovery and don't leave the keys until you see the twrp screen, continue to keep the 3 keys pressed and wait for the recovery to start again
    5- Flash the multidisabler and custom kernel then reboot to system
    6- Flash CarHDebloat and reboot
    7- Flash CarHDMod and reboot
    8- Flash CarHDTheme
    ULTERIORE GUIDA QUI
    Created 12/06/2019
    Last Updated 14/04/23
    Ultima modifica di carotix; 14-04-23 alle 13:03
  2. I seguenti 15 Utenti hanno ringraziato carotix per il post:
    angiotell (05-08-20),bluflight13 (12-06-19),danielionel (05-10-19),drago122 (12-06-19),hobin (12-06-19),iacomax (05-09-19),kartista75 (12-11-19),Luisyfer (03-06-20),Osso17 (04-04-20),Q.dino (12-06-19),rescorpione75 (07-04-20),Trezor (04-08-19),usitaly (12-06-19),yuri76 (12-06-19)
    Russi - RA
    CarHDTheme V.9.0
    What's themed:
    -framework-res
    -SystemUI
    -RomControl
    -3minit Battery
    -Potato Clock
    -AOD
    -imsservice
    -SamsungContacts
    -SamsungDialer
    -SamsungGallery
    -SamsungMessages
    -SecMyFiles
    -SecSettings
    -SecureFolder
    -SmartManager
    -SoundAlive
    -TelephonyUI
    -ThemeStore
    -TouchWizHome
    -ClockPackage
    -NfcNci
    -HoneyBoard
    -SamsungCalendar
    -SecCalculator
    -Weather
    -SmartView
    -SmartCapture
    -and more
    Download in OTA/CARHDTHEMES
    Screenshots in Night Mode and Light Mode
    Come cambiare il tuo tema da solo
    Scarica Master_Theme_v6.zip da OTA / CarHDThemes / Master Theme framework / Master_Theme_v6.zip
    Apri framework-res.apk all'interno dello zip
    Apri la cartella res quindi estrai la cartella drawable-sw360dp-xxxhdpi-v13 sul desktop
    dove dentro vedrai delle png , sostituendole e riflashando lo zip , te le ritroverai nel telefono
    ci sono ad esempio 2 sfondi:
    1) magnification_background.png questo è per la modalità notturna
    2) mainbg_pattern_mainarea.png questo è per la modalità giorno
    e cosi vale per le altre icone che vedi in quella cartella
    Ultima modifica di carotix; 25-01-23 alle 13:00
  5. I seguenti 6 Utenti hanno ringraziato carotix per il post:
    bluflight13 (12-06-19),drago122 (27-01-20),iacomax (05-09-19),Luisyfer (03-06-20),Q.dino (16-01-20),usitaly (13-06-20)
  6. #3
    Russi - RA
    a disposizione ..............
    Ultima modifica di carotix; 29-03-20 alle 17:36
  7. I seguenti 2 Utenti hanno ringraziato carotix per il post:
    bluflight13 (12-06-19),Luisyfer (03-06-20)
  8. #4
    Russi - RA
    Theme_True_Icons_V.15.apk
    it's a Samsung Theme ... You can download it from OTA/SAMSUNG THEMES
    Extra Icons Added
    guida per l'istallazione
    Ultima modifica di carotix; 20-05-22 alle 08:47
  9. Il seguente Utente ha ringraziato carotix per il post:
    rescorpione75 (24-04-20)
  10. #5
    lissone(MI)
    HD Rom by Carotix
    Tanta roba Fra. Un grande
    Inviato dal mio SM-G955F utilizzando Tapatalk
  11. Il seguente Utente ha ringraziato yuri76 per il post:
    carotix (12-06-19)
  12. #6
    Androidiano VIP L'avatar di hobin
    Feb 2011
    GalaxyS10+G975F_HD_Rom_Carotix
    Ringraziato 233 volte in 197 Posts
    @Franco
    per aver funzionante la fotocamera , occorre flashare la recovery stock , trovi lo zip in OTA/FILES FOR RECOVERY
    per riavere la TWRP patchata , occorre riflasharla da Odin e riflashare il multidisabler-g97x-1.1.zip
    Tutto questo si trova in ota???
  13. #7
    Russi - RA
    Quote Originariamente inviato da hobin Visualizza il messaggio
    @Franco
    si si ... mi dicono che non occorre riflashare il multidisabler dopo aver riflashato la TWRP
  14. Il seguente Utente ha ringraziato carotix per il post:
    yuri76 (12-06-19)
  15. #8
    lissone(MI)
    HD Rom by Carotix
    Una cosa. La twrp va riflashata solo ogni volta che si flasha la rom?
  16. #9
    Russi - RA
    Quote Originariamente inviato da yuri76 Visualizza il messaggio
    non servirà più flashare la recovery stock .... sono usciti i sorgenti del nuovo kernel , quindi la TWRP andrà sempre bene anche per la camera .... sto preparandola da flashare
    edit:
    questa è la TWRP nuova , patchata che ho reso flashabile da recovery
    con questa funziona anche la fotocamera .. la trovate anche in OTA/FILES FOR RECOVERY
    download
    Ultima modifica di carotix; 12-06-19 alle 18:46
  17. I seguenti 2 Utenti hanno ringraziato carotix per il post:
  18. #10
    Feb 2011
    edit:
    download
    La TWRP posso installarla prima e poi la rom.
