[ROM]{CWM}İCS REMİX ROM V0.2 XXKP8 4.0.3 ALL FİXED resurrection
Rom sulla base della Bezke 1.1
Descrizione:
hey guys this is bezke's ics 4.0.3 resurrection rom backup...
everythings works perfect i fixed these....
faceunlock,lock wallpaper ,phone ,ics calender ,ics email,replaced go sms pro , no fc anymore ,.AND MORE
İ changed some stock apps from cwm9 and another ics roms now very stable just try out...
%97 smooth performans
whats in _ whats new
Features
lockscreen wallpaper fixed
rooted and superuser
youtube works
replaced gosms pro as stock sms app(because of fc s i cant fix it )
ics calender
ics email
sony scetch font
cm 9 launcher fixed
face unlock fixed works awesome
removed some broken apps
google apps
org ics gallery added
cwm manager
ics org calculator
ics org weather widget added
and more...
maby soon i will add ics phone and ics messages apps
Instructions: (backup old rom before install)
Download the cwm backup
Put it on your internal SD Card . example phone/internal sd/clockworkmode/backup ( NOT EXTERNAL SD CARD )
Enter Recovery
Wipe Everything
select restore and backup
Select restore from internal sd card ( NOT EXTERNAL SD CARD
After install finished
reboot the device
Enjoy!
ressurection V0.3 new update is ready to set up
-fixed market error
-lockwallpaper added to system files
-back to orginal roboto font
-less force closes
-quick boot
-better performans
-more free ram space
-same battery life
-changed some broken stock apps
-now english
ATTENTİON :İF U DO FULL WİPE AFTER RESTORE THİS BACUP U LL LOSE FACE UNLOCK
enjoy...
RESSURECTİON V0.3 CWM backup file
DOWNLOAD LİNK
http://www.megaupload.com/?d=O7SEJPLY
DOWNLOAD LİNK V0.4 UPDATE
http://www.megaupload.com/?d=JP79DCPY
NOTİCE : AFTER FİRST BOOT PHONE WİLL START TO MEDİA SCANNİNG FOR A WHİLE ABOUT 4 MIN
CAMERA WİLL NOT WORK..
AND WHEN YOU ADD YOUR GOOGLE ACCOUNT TO MARKET 2 FC CAN VİZİT YOU
DONT PANİC İTS BECAUSE OF THE SYNC OF GOOGLE APPS AND MEDİA SCANNİNG... THAN PHONE WİLL BE SMOOTH .....
THANKS BEZKE SAMFİRMWARE AND CM9 YOU ARE THE BEST.
Link ufficiale XDA:http://forum.xda-developers.com/show....php?t=1436854
http://www.youtube.com/watch?v=TU4FF...layer_embedded
