Pagina 38 di 72 primaprima ... 28363738394048 ... ultimoultimo
Visualizzazione dei risultati da 371 a 380 su 718
[ROM][XXLP2][RC3] Simplistic ICS >> A SuperLite,Battery Friendly ROM (Data Fixed :D)
  1. #371
    torino BIANCONERA
    NEXUS 6P
    Ringraziato 499 volte in 419 Posts
    ragazzi eccomi!
    mangio e poi cerco delle soluzioni...
    intanto..
    RC5-UpdatePackage1 (Still working on it)
    Fixed moving signal bar (DONE)
    Fixed contacts importing exporting (DONE)
    Added Gmail, Google Talk (DONE)
    Removed Samsung Clock and replaced with ICS Clock (DONE)
    Updates some Gapps to Ver 10 (DONE)
    Toggles area have been edited, and 2 toggles have been changed (Thanks to amazing work of Vin87), They now look Amazing. (DONE)
    Added Sound Manager App (Thanks for its developer Daniel Roozen) which can fix Vibration and thanks to ajayjohn for finding this fix (DONE)
    Added Weather and News widget (DONE)
    DSP Manager Added (DONE)
    Will bring back stock Battery with no percentage (I will make my battery mods in my other post compatible with the Rom within 2 or 3 days) (Done)
    Will try bringing back AOSP looking Settings(Still Working on it)
    " Any ETA on update pack 1?
    Hopefully coming after 30 mins or so "
    torino BIANCONERA
    NEXUS 6P
    Originally Posted by ajayjohn
    A permanent workaround/fix for the vibrate issue in notifications
    1) Visit https://market.android.com/details?i...dManager&hl=en OR search for Sound Manager in your phone's Market and install it.
    2) Open the Sound Manager app and press the menu soft-key on your phone.
    3) In the Menu popup, touch Vibrate settings.
    4) Ensure that for both calls and notifications, the option "Vibrate whenever possible" is selected.
    5) Press the back soft-key and exit the app. Test if notifications in any app (Messaging, whatsapp, Gmail etc.) work.
    6) Even if you uninstall the Sound Manager app and the fix will still prevail.
    7) Enjoy a flawless RC5 with GApps and this fix!
    Cheers
  4. #373
    torino BIANCONERA
    NEXUS 6P
    Multiupload.com - upload your files to multiple file hosting sites!
    gapp v10, per fixare il problema della sync contatti..
  5. #374
    Quote Originariamente inviato da bonusax Visualizza il messaggio
    come si installa? XD
  6. #375
    Androidiano VIP L'avatar di seb86
    Nov 2009
    Reggio Calabria
    Ringraziato 113 volte in 90 Posts
    zip da flashare da recovery
  7. #376
    torino BIANCONERA
    NEXUS 6P
    Quote Originariamente inviato da seb86 Visualizza il messaggio
    yes!
    CMQ RAGAZZI LEGENDK95 STA TESTANDOI IL PACCHETTO DI UPDATE...FRA POCO LO AVREMO..SPERO NON COME IERI SERA CHE CI SON VOLUTE TRE ORE..
  8. #377
    Androidiano VIP L'avatar di Francys-t
    Galaxy S3
    Ringraziato 1,975 volte in 1,500 Posts
    Certo che va flashato da recovery..
    Non ti costa nulla mettere un Thanks..
    Per la mia Rom ----> http://www.androidiani.com/forum/mod...3-v-1-lp7.html
    Per il Kernel AbyssIcs ----> http://www.androidiani.com/forum/mod...e-version.html
  9. #378
    torino BIANCONERA
    NEXUS 6P
    Quote Originariamente inviato da Fuoritempo Visualizza il messaggio
    .....temo proprio non sia l'unico....
    Avete novità circa le impressioni d'uso della rc5 ?!?
    IO SONO SIncero...la rom e' belll, forse piu delle altre.
    Ma non perfetta..sia chiaro io oggi non ho trovato nessun problema, ma bisogna per forza fare quelle due o tre cosette dopo il flash per sistemare tutto.
    Magari non tutti sanno o vogliono fare tanti passaggi x avere goni cosa a suo posto..
    Di mio posso dire che , avendo provato TUTTe le rom ics uscite in questi giorni,(PURE ICS, WANAM 7.4, ALTRE 4 DI CUI NN RICORDO IL NOME) questa e' la piu bella...anche perche e' l'unica con la rubrica aosp, i messaggi aosp, che trovo molto meglio della stock.
    Di contro, se con il pacchetto di stsasera il suo creatore la renderà davvero precisa e perfetta gia al primo flash, penso che di meglio non ci sia..ma se continua a dar problemini (piccoli sia ben chiaro) magari ci si stufa opo un po..
    Certo, cosa buona, nessun FC, NESSUN REBOOT, NESSUN IMPUNTAMENTO ...
  10. Il seguente Utente ha ringraziato bonusax per il post:
    Fuoritempo (23-01-12)
  11. #379
    ok altra domandina se apro la cmw dall'icona nelle apps, mi dice che molte funzioni sono disabilitate perchè ho un diverso kernel..
    quale dovrei flashare?
  12. #380
    torino BIANCONERA
    NEXUS 6P
    Quote Originariamente inviato da Alez Visualizza il messaggio
    na na na na..
    non quel cwm
    devi andare in recovery...e ali flashare...
LinkBacks (?)
  1. 05-07-12, 17:28
