[ROM] [XWKL1] [03Feb] Omega v10.4
    Senior Droid L'avatar di crisGS2
    Torino
    Samsung GS2
    Post
    Android 2.3.6
    Firmware XWKL1 Android 2.3.6 (Data: 13/12/2011)
    Modem XXLPB
    La Rom è Deodexed + Rooted + Zipaligned
    Versioni
    Omega v10.4 ◄Stock► - Molto vicina alla filosofia stock. (Link download)
    Omega v10.4 ◄Tema -Black Blue-► Fully Skinned & Ottimizzata - Bella ~ Veloce ~ Potenza combinata (Link download)
    Omega v10.4 ◄ICE CREAM SANDWICH► - Ispirata ad ICS (Link download)
    Caratteristiche Omega ◄Stock► v10.4:
    Firmware XWKL1 Android 2.3.6 (Date: 13/12/2011)
    Kernel Siyah v2.6.11
    Modem XXLPB
    Deodexed - Rooted - Zipaligned
    Overscroll glow~light Blue~enabled by default
    CMW recovery v5.0.2.7
    Omega Files Kitchen application
    Temi
    JKay BlueDoubleGinger Deluxe Theme v13.5
    Registrazione chiamata
    Phone with Call Recorder
    Programmi Stock
    New Swype 3.25
    New Android Market v3.4.4
    New Gmail v2.3.5.2
    New Google Maps v5.12.0
    New YouTube 2.2.16 (Available in Omega Files)
    New Samsung apps v2.6.114
    Gtalk with video support
    [MOD] Hacked Camera.APK for better audio quality, usage with any battery life + Complete Silent Camera
    Deluxe Settings v13.5 by jKay
    Programmi inclusi (possono essere rimossi)
    Barcode Scanner v3.72
    Compass v2.1
    ConvertPad v2.0.0
    FasterFix v1.6.1
    Google Translate 2.2
    Dropbox v2.0.1
    Hide It Pro v2.8.2
    MySword v2.3.1
    Pocket v2.6
    MixZing Media Player v3.7.0
    MySword v.2.2
    Tiny Flashlight v4.0.1
    ES File Explorer - (install ES File Explorer v1.6.0.8.apk from Omega Files Kitchen)
    GScriptLite
    DSP Manager Equalizer for Android
    AddFree Android
    AppZorter Lite for Modded TouchWiz
    NoLED v4.8
    Twitter
    Skype
    Facebook
    AirDroid
    Mods:
    Disabled boot sounds - You can enable them with Enable_bootsound.zip from Omega Files Kitchen
    No increasing ringtone volume
    Phone with disabled Noice Reduction
    Instantaneous GPS Fixation v1.2 for Europe (for other Countries check here or use FasterFix)
    SIP over wifi and 3g
    Extended power menu - it's customizable with JKay Deluxe Settings app(Included)
    StartingAlertService Wakelock (TouchWizCalendar.apk)
    Services.jar updated to allow stock SMS/MMS work with BLN
    Add support for HTC headset button
    Disable screen wake from volume buttons
    No Auto Converting SMS messages to MMS after 4 SMS it will be converted to MMS after 200 SMS
    Changed default home page in TouchWiz Launcher from 1 to 4 by petsas
    Change 4 icons dock with 5 icons dock by petsas--How to use * In the app drawer, hit edit, and add one more icon dock at the bottom of the page.
    TW Launcher 4.5
    Added csc support EUR for (Greece) and also for many more countries.
    Enable/Disable Full and Low Battery Notification (with Deluxe Settings app included in Omega)
    Enable/Disable Low battery Notification (with Deluxe Settings app included in Omega)
    Bln support
    Modded Browser With UserAgent Option by intronauta
    Remove SMS log from call log install Remove_SMS_Log_from_call_log.zip from Omega Files Kitchen for this mod.
    Rimossi (possono essere ripristinati attraverso la Omega files Kitchen):
    TouchWiz Launcher
    Yahoo finance
    Zinio reader
    Stock Shutdown Animation
    Camera sounds
    La Rom è No Full Wipe
    Caratteristiche Omega ◄Black Blue► v10.4:
    Sono presenti tutte le funzioni della Omega Stock v10.4 con l'aggiunta di cambiamenti inerenti all'interfaccia .... :
    Skinned with:
    Base Theme: Black blue by lexullde
    Many Theme icons from Clear Glass S2 by esk02k
    Fm Radio + BluetoothOpp + DigitalClock + EmailWidget + GenieWidget + LiveWallpapersPicker + MyFiles: Blue Monkey v3 Steel Theme by BananenAffe
    SamsungWidget ProgramMonitor + usb dock icons + WeatherClock+Calculator: Blue Monkey v3 Steel Theme by BananenAffe
    Calendar + Phone + email: Phone Candy Theme by dully79
    Battery icons: Full Blue Bat (by syps54)
    Many more visual changes by indie.
    Tutti gli altri programmi sono gli stessi della Omega Stock v10.4
    Caratteristiche Omega ◄Ice Cream Sandwich► v10.4:
    Ice Cream Sandwich Theme v5 by BigBangHD
    Include cinque Launcher.
    Guida all'installazione
    Istruzioni per installazione facile e veloce.
    1. Effettuate tutti i backup necessari per salvare i vostri dati.
    2.*Se provenite da un'altra Rom, spegnete il GS2 e avviatelo in ClockWorkMode Recovery (combo tre tasti: VOL. SU + TASTO HOME + ACCENSIONE), succesivamente eseguita:
    - Wipe data/factory reset
    - Wipe cache partition
    - Wipe Dalvik cache (lo trovate nel menu ADVANCED)
    infine selezionate 'install zip from internal sdcard' e flashate la Rom OMEGA
    *Se avete già la Rom Omega basta avviare in ClockWorkMode Recovery selezionate 'install zip from internal sdcard' e flashate la Rom OMEGA.
    Istruzione più lunga e difficile.
    1. ROOT: Per installare la Rom Omega è neccessario che il vostro telefono abbia i permessi di root - si consiglia il CF Root adatto alla vostra versione, che trovate qui e la GUIDA qui-.
    2. BACKUP: Prima di installare qualsiasi Costum Rom si consiglia di creare un NANDROID BACKUP. Per creare tale Backup è necessario avere almeno 2GB di spazio libero sulla sdcard. Bisogna procedere nel sguente modo: avviate in ClockWorkMode Recovery, una volta dentro la recovery selezionate backup and restore per effettuare un NANDROID BACKUP. In sostanza tale operazione crea un immagine statica del vostro telefono, ovvero così come esso si presenta in quel momento.
    Oppure potete usanre Titanium Backup disponibile sul market Android. dopo aver installato l'applicaizone, avviatela, andate su Backup/Restore tab -> premere il tastyo menu del telefono a sinistra -> Batch -> e avviate: Backup all user apps + system data.
    3. INSTALLAZIONE: Download della Rom (sopra indicate), il fale downloadato è di estensione .zip una volta che il download è stato effettuato non dezippate il file ma limitatevi semplicemente a copiarlo nella sdcard del telefono (collegandolo tramite USB al pc). Per flashare il file vi rimando alla guida sovrastante (Installazione facile e veloce).
    IMPORTANTE: PRIMA DI OGNI OPERAZIONE DI MODDING
    Per salvare questa cartella seguita questa Guida, alternativamente questa.
    INFINE VI RICORDAO CHE: NON SONO RESPONSABILE DI NESSUN MALFUNZIONAMENTO DEL VOSTRO GALAXY S II
    Ultima modifica di crisGS2; 03-02-12 alle 17:46
    Androidiano VIP L'avatar di Aetos
    LGoogle Nexus 4
    Ringraziato 280 volte in 210 Posts
    L'ho provata oggi.. consuma batteria.. S:
    Google Nexus 4 (Mako)
    Samsung Galaxy S II (i9100)
    HTC Desire (Bravo)
    Thread ben fatto!
    rom con molto carattere e personalizzazioni anche nelle animazioni e tranzizioni, fluida, stabile e veloce. Troppo caratteristica per i miei gusti ma se uno vuole qualcosa di diverso è ottima.
    Provato la black blue
    Androidiano VIP L'avatar di masterdoo
    NEXUS 5
    Ringraziato 320 volte in 253 Posts
    Quote Originariamente inviato da Aetos Visualizza il messaggio
    per vedere se una rom consuma o meno tanta batteria andrebbe provata per un paio di giorni minimo, così si ha il tempo di far stabilizzare e far adattare il gaaxy alla nuova rom
    SMARTPHONE: Nexus 5
    GESTORE TELEFONICO: Wind
    SE TI SONO STATO D'AIUTO USA L'APPOSITO TASTO THANKS!!
    LGoogle Nexus 4
    Quote Originariamente inviato da masterdoo Visualizza il messaggio
    Appunto, l'ho montata appena l'hanno postata su xda, l'ho tenuta per 3 giorni
    HTC Desire (Bravo)
    Torino
    Samsung GS2
    Confermo, molto pesante. Inoltre a me non funzionavano un paio di cose come ad esempio la Omega Files. Però è molto bella come ROM se si vule qualcosa di diverso.
    Seguiteci sulla pagina non ufficiale di Facebook OnePlus Italia oppure su Google+ OnePlus Italia. Siete tutti i benvenuti!
    LGoogle Nexus 4
    Omega files mi funzionava.. Ho eliminato varie app sia di sistema che quella preinstallate ma cmq non riuscivo ad ottenere ottimi risultati.
    L'avrei tenuta solo per il tema di ics che è fatto davvero bene.
    HTC Desire (Bravo)
