Questa mattina stavo cercando qualche ROM per il mio SGSIII quando mi sono imbattuto in questa.
L'ho scaricata, ho fatto il full wipe, e mi sono accorto che era per i9100, cioè Galaxy SII :bd:
Ve la posto, vi potrebbe interessare.
È uscita ieri, cioè il 13/10/12 (Il mio compleanno :D)
Allora, i bug sono quelli della CyanoGenMod 10, cioè questi.
BUGS
Hardware Composer: doesn't support all JellyBean features
USB: slow ums transfer speed
Surfaceflinger: short screen flash after CRT-off animation
Camera: Recording effects broken
FM Radio: unsupported
TV Out: unsupported, will never work (proprietary, undocumented)
NFC support on GT-I9100P is missing
Audio via bluetooth unsupported
ATTENZIONE! Questa ROM è compatibile solo con questi kernel, al momento!
[/url]
Dorimanx 7.2
Siyah 4.1.5
Come installare la ROM
1. Fare un FullWipe (Consigliato ma non sempre necessario)
2. Tramite modalità recovery flashare la ROM
3. Riavvia (Ci metterà un po' a causa dell'ottimizzazione delle applicazioni)
4. Aspetta qualche minuto e riavvia nuovamente
[System]
- Optimise current themes in the program selector icon
- Optimise global search when using the current theme icons
- Fix issues with insensitive touch screen, also optimise click operation accuracy
- Fix some devices IMEI numbers can used to erase phone data (USSD Exploit)
[Phone]
- Add T9 search can switch between "alphabet" and "phonetic" search modes
- When hanging up call, fix in some cases will lead to FC errors
- Fix CDMA operator display name does not change with the system language is modified
- Fix in some cases, the missed call reminder ringtone will not stop alerting
- Fix in some cases, call log list avatars do not refresh
- Fix call answering interface and call interface shows overlapping in some cases
- Fix in some cases, the caller interface leads to FC errors
[Contacts]
- Fix when restoring contacts backup, avatars display with problems
[Messaging]
- New, If you have not opened through the network SMS to open the SMS list prompts (10-09)
- Optimise SMS expression types
- Optimise searching SMS messages or bulk SMS will be merged into one result list
- Fix issue with Phrases content not being hidden when English language is selected. Tab sliding right will lead to FC error
- Fix when sending network SMS, send and receive status displays error issues
- Fix when MMS is received, before message has been read, the notification will be repeatedly prompted
- Fix received time for MMS in notification bar shows incorrect details
- Fix HTC phones cannot send MMS message
- Fix network SMS messages cannot be sent to foreign numbers
- Fix problem with SIM card SMS contact names length
- Set the maximum number of prompts for the first time SMS is used
[Lock screen, status bar and notification bar]
- Optimisation of phone misuse system default
[Desktop]
- Fix adding a Widget to new screen, the display of the widget is not centered correctly
- Fix in some cases, the dynamic effect of the free desktop widget does not show correctly
- Fix Photo frame widget pictures cannot be replaced / edited
[Music]
- Optimise lyrics adjustment state inside the user interface
- Optimise smart removal of lyrics at the end of line with extra blank line
- Bug fix for 4x1 Desktop Widget album cover display
[Sound Recorder]
- Fix recorded radio is not displayed in the list of recordings
- Fix when Caller ID is unknown / empty, call recording will lead to FC errors
- Fix recording 'title' display shows incorrect information
[Calendar]
- Contact birthday reminders, fix porting to 4.1 android system
[Anti-disturb / DND]
- Fix, turning off anti-disturb function and issues relating to unknown caller
- Fix, some types of number prefix are missing after being added to the Blacklist
[Notes]
- Fix in certain circumstances, the notes text displays some overlapping problems
- Fix in some cases, selecting grid notes layout will lead to FC errors
[Alarm Clock]
- Fix timer ringtones select, interface dislocation issues
- Fix when setting two or more world clocks, on New Year's Day will lead to FC errors
Passi prima di postare un bug
- Hai fatto un FullWipe?
- Hai flashato una modifica compatibile con questa ROM?
- Hai flashato un kernel non compatibile?
che io sapevo aveva interrotto il progetto..infatti un utente che aveva aperto proprio un thread su questa rom mi aveva detto questo e aveva continuato il topic con un nuovo progetto che riprendeva questo..
14-10-12, 18:07
AndyTambu
La sto scaricando adesso, vi faccio sapere.. ;)
14-10-12, 22:20
michaelwool
Originariamente inviato da ZiCkY
un utente che aveva aperto un thread su questa rom
È uscita ieri sera! È stato così veloce?
14-10-12, 22:36
AndyTambu
Dopo un paio di orette di utilizzo posso dire che e' fantastica! Ha tutto quello che puo' servire ed e' fluida gia' con il kernel stock! Se vi serve qualche informazione chiedete pure..
Ciao a tutti ma è normale che rimane schermo nero usandola come secondary rom con siyah 4.1.5?
15-10-12, 16:02
michaelwool
Sono felice che ti piaccia (:
Purtroppo non ho un S2, perciò non posso provarla :/
16-10-12, 10:35
darkn3ss1
Originariamente inviato da Paro007
Stessa cosa succede a me.. ho come principale la 2.8.3 che mi funziona perfettamente e per non rischiare la volevo installare come secondaria.. ho provato anche vari kernel ma non va resta sempre schermo nero.. forse questa versione come secondaria non si può installare, peccato.. cmq approposito.. io col siyah kernel 4.1.5 non avverto le vibrazioni del telefono, ho provato a impostare anche step 4 da extweak ma nulla.. sono dovuto ritornare alla versione 3.5.2
come risolvo questa cosa? Il dorimanx come diavolo si installa su JB? non è compatibile? Parte l'aroma installer ma tutte le opzioni ci sono tranne quelle che interessano a me.. non c'è nè cm9, ne JB.. solo stock MIUI, ICS ecc..
16-10-12, 15:43
gi4ngi
con i nuovi kernel con driver mali non funziona il dualboot...si può usare solo una rom, per cui se volete provare questa dovete metterla come primaria perchè funziona solo con questi kernel.
la rom non è uscita ieri è un progetto che è cominciato a giugno su base cm9 sviluppatosi succesivamente su cm10 poi all' incirca un mese fa l'autore decise di abbandonare perché era troppo impegnato ma la settimana scorsa, colpo di scena, ha avuto un ripensamento partorendo questa domenica e come accennato da zichy un utente, stelev, aveva aperto un tread per questa rom poi trasformatosi in m1ui causa l'abbandono del progetto cmiui da parte di chillaz...per la cronaca m1ui e una rom con le stesse caratteristiche nata dopo l'abbandono dalle idee del dev di cmiui.
16-10-12, 20:01
darkn3ss1
installata come primaria e funziona ma solo col kernel stock.. col siyah mi fa la stessa cosa del dual boot, sia con la ver 3.5.2 che 4.1.4 e 4.1.5.
boh.. ho rimontato la sd esterna ma ho visto che non se la prendeva da mnt/emmc infatti la chiama diversamente e l'ho rimontata da storage/sdcard1 ed è andata finalmente in sdcard/external_sd.. un'altro boh!
ora invece mi rimane il problema del cavo OTG che non mi vede la chiavetta.. la collego si accende la spia (della chiavetta) e si spegne subito e mi esce scritto "ora è possibile rimuovere l'archiviazione USB".. come mai? che devo modificare? sto uscendo pazzo! Help ME :)
