Pagina 250 di 297 primaprima ... 150200240248249250251252260 ... ultimoultimo
Visualizzazione dei risultati da 2,491 a 2,500 su 2966
[ROM][XWLSW]Omega v24●►Final JB 4.1.2◄●Omega Files●►Fully Modded◄●
  1. #2491
    Quote Originariamente inviato da LEO2589 Visualizza il messaggio
    Su xda titolo modificato da indie v22 soon.. Quindi a breve avremo novità..
    Sent from Tapatalked JB GT~i91x10^2
    Intanto lo cambio...
    Sent under my wife supervision
  2. Il seguente Utente ha ringraziato Anna per il post:
    Leo2589 (02-04-13)
    Ringraziato 17 volte in 13 Posts
    v 22 on download!!
  5. #2493
    Androidiano VIP L'avatar di N1m0Y
    originario del pianeta Vulcano
    Tricorder, GT-i9100, le Pro 3
    Ringraziato 3,811 volte in 2,605 Posts
    http://forum.xda-developers.com/show...php?p=39833397
    Quote Originariamente inviato da ::indie::
    New version Omega v22:
    Based on XWLSJ Android 4.1.2 (Date: 26/02/2013)
    New:
    Kernel PhilZ-cwm6-XWLSJ-OXX-4.91.5
    Updated:
    Samsung Push Service v1.1.8
    hosts
    All mods and updates from previous Omega JB 4.1.2 versions added
    Rom is Deodexed + Rooted + Zipaligned
    Rom is No Full Wipe
    Omega Files:
    Please read the following before flashing v22:
    1. Make sure to make and keep in a safe place an efs backup, in case you need to restore it.
    2. Rom is No Full wipe rom, but Full wipe is strongly recommended if you have issues!
    3. Please update Omega Files from Play Store.
    4. If you want to flash theme or kernel, please make sure first they are compatible with this Omega version.
    My Pledgie:
    Please support me to get the new Samsung Galaxy S4,
    this way I will support one more device with Omega roms
    and I will not have to sell my other devices to get the new S4.
    Donation:
    If you like and you use Omega v22 and Omega Files app, please consider a donation.
    Enjoy the new Jelly Bean Omega
    Non risponderò in PM a richieste di aiuto sul modding. C'è il forum per questo, se usato correttamente.
    Se ti sono stato d'aiuto usa il tasto Thanks in basso a sinistra.
    Prima di postare leggi sempre la prima pagina del thread.
  6. #2494
    carlo201983
    in flash la v22 .. speriamo bene
  7. #2495
    Senior Droid L'avatar di ermejodercolosseo88
    Castelleone (CREMONA)
    Nexus 4
    Ringraziato 158 volte in 57 Posts
    Quote Originariamente inviato da carlo201983 Visualizza il messaggio
    Poi quando capisci se la wifi funziona meglio (eliminato il Battery drain) lo puoi scrivere sul forum? Grazie!
    Inviato dal mio Galaxy S2 con Tapatalk 2
    LG G2
    Seguimi su Twitter @FranciPedri
  8. #2496
    carlo201983
    Quote Originariamente inviato da ermejodercolosseo88 Visualizza il messaggio
    aspetto un paio di giorni e ti dico, quello che ho notato subito e che la ram è meglio ottimizzata in quest'ultima release ed ancor magior fluidità
  9. #2497
    Nexus 4
    Ok ottimo! Io faccio l'upgrade solo se si risolve questo problema, sennò resto come sono, perché è una gran rottura reinstallare tutte le app e con titanium backup alcune app danno problemi...
    LG G2
  10. #2498
    carlo201983
    io cmq x adesso nn ho fatto wipe data, è consigliato in caso di problemi, il cell infatti al momento nn fa cose strane è ripeto nn ho fatto il wipe data factory
  11. #2499
    Buon giorno a tutti! Volevo chiedere se la V22 Omega (LSJ) sia sempre compatibile con il kernel Hirox. O se eventualmente qualcuno avesse riscontrato dei problemi in merito.
    carlo201983
    Quote Originariamente inviato da Trosky Visualizza il messaggio
    esendo appena uscita nn credo che qualcuno passa risponderti così velocemente .
