Utente del giorno:megthebest con ben 1 Thanks ricevuti nelle ultime 24 ore Utente della settimana:megthebest con ben 17 Thanks ricevuti negli ultimi sette giorni Utente del mese:megthebest con ben 47 Thanks ricevuti nell'ultimo mese
Finally, after a long time i'm happy to present you the first version of HDBlog Custom ROM also for the Gs2!
Installation:
Download Odin
Install Samsung Kies
Connect the SGS2 to the Pc and make sure it is recognised
Unplug the phone and shut it down
Download the package LeoDroid Custom ROM v1.0 and unzip it
Open Odin
Select PDA and the package .tar just extract
Turn on the phone into download mode
volume - + central button + power
oce it has been recognised you can se the yellow write in odin
Press start and wait the reboot
THAT'S ALL
Note
The installation will not make any wipe and you'll keep your apps and settings, YOU DON'T need the ROOT.
This rom don't contain the CHEATS used by other developers to reache higher score on QUADRANT!!!
Features:
-Based on the last XWKE8
-The framework is mod to keep the LeoDroid's theme:
--blue charging bar
--changed the icons of GPS and 3G
--Changed also the toggle buttons!
-insert also the Battery mod!
-Added the shut down effects like an Old TV!
-added the Overscroll glow
-Added the extended power menu
-Modded the Widget Samsung Meteo with the trasparence!
-Modded also the app Widget Email with the trasparence
-Changed the wallpaper of the Lockscreen
-All the Framework is deodexed and zipaligned.
-Insert Gtalk con Video - Thanks to Paul MoDaCo
-Better apk of Browser
-Insert BETTER CAMERA MOD
-added the SIP stack to make calls over VOIP Wifi and 3G
-Removed the Wifi sharing, cause of the battery drain
-Added the cf 3.7 for the firmware XWKE8
-Root + Busybox
-Added Chainfire 3D
-Added TegrakOverclock
Se cortesemente volessi tradurre in italiano sarebbe gradito
se non ha voglia/tempo/possibilità di tradurlo, io volendo posso aprire un thread come ho fatto per la Lite'ning, senza problemi, qualcuno mi faccia sapere
Ultima modifica di nigno; 11-06-11 alle 20:08
Device: Sony Xperia Z3 - Rooted Stock Rom Device: LG G2 - Cloudy G3 Rom Device: Galaxy S2 GT-I9100 Black - Asnet Miui Rom Device: Galaxy S1 GT-I9000- Slim Rom Device: LG G Pad 8.3 - Rooted Stock Rom Device: -
- Brabus Xclusive -
Quando questo aggeggio toccherà le 88 miglia orarie ne vedremo delle belle, Marty.
- Brabus Xclusive -
Nigro si secondo me è meglio che apri un bel thread tradotto e semrpe bello aggiornato così come il litining ....ovviamente se sei disponibile
io sono disponibilissimo, posso farlo anche domani..non vorrei però nè andare OT adesso e nè togliere meriti o ringraziamenti all'autore di questo thread, quindi aspetto una conferma da chi è più in alto di me
- Brabus Xclusive -
questa rom non esiste più,è stata ritirata sia su XDA che su HDblog,lunedi leo ne rilascerà una basata su KE7.........
Ragazzi è stato rubato un lavoro che avevo iniziato di modifiche basato sulla litening, mentre era in corso di sviluppo. Tutto questo è stato possibile grazie alla preziosa collaborazione con angelomiui che è stato molto disponibile e mi ha aiutato in privato in questi giorni!
Mentre stavo editando il forum originale un bastardo italiano frequentatore di XDA ha postato il lavoro incompleto ed ha pure messo il pulsante Donate.
Non è una custom ROM ma è solamente un mio tentativo di capire e studiare meglio come customizzare il Gs2 che non era pubblico ma riservato.
Sono l'autore di diverse custom ROM per LG Dual e stavo cercando di capire meglio grazie all'aiuto di Angelom come lavorare anche sul GS2 e di certo non amo fare nessun copia incolla, ma capire tutto quello che faccio ed essere leale e corretto verso tutti gli sviluppatori!
Quindi mi scuso per l'accaduto, ho chiarito ogni cosa con gli Admin del forum XDA e con l'autore della Litening, ora stiamo aspettando solo una punizione dell'utente focamonca che si è permesso di rubare un lavoro incompleto e privo di informazioni e changelog.
Grazie!
Vi sto seguendo da giorni e non vedo l'ora di poter contribuire a soddisfare alcune richieste dei vari lettori di questo forum.
Leonardo.
Ultima modifica di LeoMar75; 12-06-11 alle 10:26
Il seguente Utente ha ringraziato LeoMar75 per il post:
