[java -jar apktool.jar d "C:\Documents and Settings\…\Desktop\GalaxyS3ModTool_v0.6.2\files\fr  amework-res.apk" "C:\Documents and Settings\...\Desktop\GalaxyS3ModTool_v0.6.2\dec\13-02-18_173811\framework-res.apk"]
I: Framework installed to: C:\Documents and Settings\...\apktool\framework\1.apk
I: Loading resource table...
I: Loaded.
I: Decoding file-resources...
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_btn_cab_done_focused_holo_dark.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_btn_cab_done_focused_holo_light.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_scrubber_track_holo_dark.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_dropdown_disabled_focused_holo_dark.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/scrollbar_handle_vertical.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_switch_thumb_activated_holo_light.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/keyguard_pcw_list_pressed_dark.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-xhdpi/btn_toggle_on.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_btn_cab_done_pressed_holo_light.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/scrollbar_handle_horizontal.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_buttonbarbutton_selector_pressed_holo_dark.9.pn  g". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_switch_thumb_activated_holo_dark.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_tab_selected_pressed_holo.9.png". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_list_selector_background_pressed_holo_dark.9.pn  g". Renaming it to *.png.
W: Cant find 9patch chunk in file: "drawable-hdpi/tw_dropdown_disabled_holo_dark.9.png". Renaming it to *.png.
I: Decoding values*/* XMLs...
I: Done.
I: Copying assets and libs...
