Pagina 43 di 107 primaprima ... 3341424344455393 ... ultimoultimo
Visualizzazione dei risultati da 421 a 430 su 1067
[KERNEL] Stable: Boeffla-Kernel 2.x ONLY JB 4.1.x
  1. #421
    Senior Droid L'avatar di ginzo
    Padova
    Samsung Galaxy S5, i9070p
    Ringraziato 156 volte in 126 Posts
    Quote Originariamente inviato da BlackJack89 Visualizza il messaggio
    Vi siete dimenticati di questo kernel
    Ecco la nuova release: 2.11 beta...
    Changelog
    All functionalities of last stable version 2.9 included
    Completely built from scratch on latest Samsung sources update10
    Zzmoove governor Version 0.4 with fast scaling (Thanks to ZaneZam)
    New implementation for LED control like fading, blinking, brightness, speed (Thanks to Yank)
    System Tweaks disabled per default
    SD Card Tweaks (=read ahead buffer) can now be configured in several steps within boeffla-tweaks app (in config file you can freely configure the value within given range)
    New implementation of android logger control (no reboot required anymore after activation/deactivation)
    Fix permissions script can be executed in boeffla-tweaks app now
    Support for xbox controller
    Wifi Mac address changeable
    Battery monitor wakelocks reduced (maybe improving battery life a bit)
    Boeffla-RamFS complete overhaul and optimisation
    Ramdisk of EMC3 firmware
    Compiled with latest Linaro Toolchain 4.7-2013.04 from April
    Inviato del mio S3 zombie
    Ottimooooo sono appena rientrato in Italia e c'è già una bella novità!!!!
    Scarico e testo !!
    Tapatalked from my Galaxy S3
    Rom: Maya v3 XXEMC2 ♥
    Kernel: Boeffla 2.10 beta2
    Modem: XXEMC2
    Operator: Vodafone
    Recovery: Philz Touch
    Samsung Galaxy S8 Black 64GB
    Rom: originale
    Knox: 0
    MicroSD Samsung 128GB classe 10 A1
    Se ti sono stato utile, clicca o premi sul tasto Thank per ringraziarmi, non costa nulla e fa piacere riceverlo !!
    Androidiano VIP L'avatar di simone87stilo
    Pontecchio Polesine (ROVIGO)
    LG G4
    Ringraziato 187 volte in 172 Posts
    oK APPENA MESSA.
    Scusate ma leggo, controllo xbox controller, ho messo on ora come si fa a giocare con un xbox controller?
    Se il mio aiuto è servito, un click su "Thanks" è sempre gradito!
  4. #423
    Moderatore L'avatar di BlackJack89
    Vault 105
    OnePlus 5
    Ringraziato 741 volte in 538 Posts
    Quote Originariamente inviato da simone87stilo Visualizza il messaggio
    oK APPENA MESSA.
    Ti serve il cavetto otg
    Un Grazie è sempre ben accetto
  5. #424
    LG G4
    quello cè l'ho, attacco quello e attacco il joipad xbox col cavo giusto o via wirless? ho anche il ripetitore per attarclo al pc volendo quale uso?
  6. #425
    Vault 105
    OnePlus 5
    Io farei tutto tramite filo
  7. #426
    Vault 105
    OnePlus 5
    Battery drain da paura
    Uffa
  8. #427
    LG G4
    a me col 2.11 nessun battery drain
  9. #428
    Ringraziato 71 volte in 65 Posts
    io sono con anonorom e boeffla stable 2.9..non ci si può lamentare è davvero ottimo.
    Se poi ci metti anche un UV di -25 a cpu e gpu con governor zzmove,la batteria dura molto..
  10. #429
    Vault 105
    OnePlus 5
    Quote Originariamente inviato da snake24 Visualizza il messaggio
    Solo 25?
    Ormai mettono tutti 100
  11. #430
    Padova
    Solo 25?
    Beh no no io ad esempio uso il -50
    Modem: XXEMC2
    Operator: Vodafone
    Rom: originale
    Knox: 0
