Pagina 6 di 11 primaprima ... 45678 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 102
[ROM][13/01][XXELLC]··▀▄·♑.HydRx-D v2.3.0·AOSP+Stock·JB-4.1.2-XXELLC·▄▀
  1. #51
    Androidiano VIP L'avatar di linus98
    Jan 2011
    Palermo
    HTC Diamond, HTC HD2, GS3, GS6
    Ringraziato 1,358 volte in 776 Posts
    R: [ ROM ][05/01][XXELLA]··▀▄·♑.HydRx-Dv2.2.0-JZO54K·Stock-JB-4.1.2-XXELLA·▄
    Online la 2.2.1
    Androidiano L'avatar di DannyGTI
    GT-I9300 SIII
    Quote Originariamente inviato da linus98 Visualizza il messaggio
    Online la 2.2.1
    Di già?
    Ma possiamo aggiornare tranquillamente facendo wipe cache e dalvik?
    ChangeLog HydRx-D
    2.2.1:
    • New kernel 3.0.57-HydRx-v4r58
    • Improved scaling in lower freqs (+stable)
    • Added entropy Seeder rngd I/O mod (thanks to lambgx02 & Ryuinferno) and modified a little (should be less system lag)
    • Made script of Dynamic LowMemoryKiller to avoid lags when the free ram memory is low (+performance)
    • Modified a little VM values for + AWAKE performance
    • Added Music player and fm priority on Sleep to avoid shuttering in sleep mode.
    • Edited and cleaned a little wifi off script .
    • Increased +1dBm in AWAKE wifi power (should improve a little wifi link)
    • Modified sleep up threshold values to get better DeepSleep
    • Added more Advanced AROMA installer
    • Added Samsung Stock+toggles theme to Aroma
    • Added kernels choose in Aroma (fix reboots and freezings installing -25 or -50)
    • Added apps mod or genuine apps choose in Aroma
    • Added the possibility to add the Deleted APPS to install in aroma, dragging apps what u want to rom zip, into: /extras/samsungremoved/app and enabling the install later in Aroma
    • Some more fix & tweak.
    • + I forget
    • Optimized all apks to get more ramfree
    • Zipalign..
    Ultima modifica di DannyGTI; 08-01-13 alle 10:25
    Se ti sono stato d'aiuto clicca su THANKS
  4. #53
    Jan 2011
    Palermo
    Si, vai tranquillo, anche se io sto valutando l'opzione full wipe
    Ultima modifica di linus98; 08-01-13 alle 11:48
  5. #54
    GT-I9300 SIII
    ho scaricato la rom 2.2.1 adesso metto un pò in carica il cell e flesho.
    EDIT: Aggiornato alla 2.2.1 con voltaggio a -50...ribadisco..rom semplicemente perfetta!!!
    Stabile, Battery saver e fluida con nova launcher 2 una bomba!!
    Ultima modifica di DannyGTI; 08-01-13 alle 23:54
  6. #55
    GT-I9300 SIII
    La rom XXELLA è semplicemente ottima, ho fleshato il Siyah 1.8.6 e con stweaks ho undervoltato a -75 senza toccare i valori della cpu, niente più crash o freeze.
    Una domanda, qualcuno mi può passare il walpaper che c'è di base quando installa la rom, quello con la strada per intenderci, ho cambiato sfondo e lo rivorrei solo che non riesco più a trovarlo, in sfondi non c'è
  7. #56
    Jan 2011
    Palermo
    Quoto in pieno. Io ho tenuto il kernel stock della ROM undervoltato a 125mV ed è tutto ok. Lo sfondo di default puoi scaricarlo dal mio dropbox qui: https://dl.dropbox.com/u/19557736/default_wallpaper.jpg.
    Online la v2.2.1r1
    Ultima modifica di linus98; 10-01-13 alle 13:07
  8. Il seguente Utente ha ringraziato linus98 per il post:
    DannyGTI (10-01-13)
  9. #57
    Androidiano VIP L'avatar di ste22032
    Como
    OnePlus 3, S3
    Ringraziato 4,806 volte in 2,635 Posts
    Ma è possibile avere un'interfaccia completamente stock con questa rom? Mentre per quanto riguarda il kernel, cosa consigliate come uv? Grazie ;-)
    Jan 2011
    Palermo
    Certo che si può. In fase di installazione si può scegliere quale interfaccia avere. Per quanto riguarda il kernel non c'è ne uno da consigliare, dipende da quello che "regge" il tuo telefono. Puoi partire dall'undervolt più alto, se non hai problemi di freeze o altro ok, altrimenti scendi di voltaggio.
    Ultima modifica di linus98; 11-01-13 alle 10:47
  11. Il seguente Utente ha ringraziato linus98 per il post:
    ste22032 (11-01-13)
  12. #59
    GT-I9300 SIII
    Io con undervolt -75 e -50 su kernel stock avevo dei freeze con il siyah 1.8.6 e undervolt a -75 tutto perfetto
  13. Il seguente Utente ha ringraziato DannyGTI per il post:
    linus98 (11-01-13)
  14. #60
    GT-I9300 SIII
    Online la v2.2.1r1
    ho dato un'occhiata al changelog della 2.2.1r1 e non ci sono molti cambiamenti, diciamo che è un minor update, per ora lascio la 2.2.1 visto che è stabile e performante, vedremo con la 2.2.2
