Pagina 8 di 12 primaprima ... 678910 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 113
[ROM][I9300]●► Omega ◄●► AOKP&CM ◄●► Android 4.4.2 Kit Kat ◄●
  1. #71
    Senior Droid L'avatar di ammanna
    Modena
    Meizu M2 Note
    Ringraziato 228 volte in 129 Posts
    aggiornamento
    Omega AOKP v14:
    Based on AOKP Android 4.3.1 with all latest updates - read changelog here
    New:
    Notification Manager by RYO Software - Omega Rom users can monitor 3 apps instead of 1, thanks and credits to bartito for this gift to us
    Updated:
    Playstore
    Account Sync Profiler
    Apex Launcher
    All mods and updates from previous Omega versions added
    Rom is no full Wipe - but full wipe is highly recommended
    Modena
    Meizu M2 Note
    Primo post aggiornato con la nuovissima versione della rom v15 con android 4.4.2!
    changelog:
    Based on AOKP AOKP Android Kit Kat 4.4.2 with all latest updates - read changelog here
    Kernel Stock
    Aroma installer - Installation is fully customizable by user
    Option to Fullwipe from Aroma
    Wipe cache partition automatic before roms installation
    Wipe Dalvik Cache automatic during installation
    OmegaDroid Bootanimation by Jorq1H
    Omega Theme for aroma installer by our artist anbech
    CM apps:
    Dsp Manager
    Google apps:
    Playstore
    Chrome
    Gmail
    Google+
    Google Earth
    Google Search
    Hangouts
    Maps
    Music
    Play Newsstand
    Play Games
    YouTube
    **Google apps added to aroma installation
    All Google apps are updated to the latest version
    Omegas extra apps:
    OmegaDroid - The official application of OmegaDroid - Android News, Apps, Games, Devices, Guides, Development, Omega Projects, Omega Rom Series, Omega Files
    Flashplayer
    Dolphin Browser with Flashplayer support
    Dolphin Browser Jet Pack
    Dropbox
    Accounts Sync Profiler by bartito
    ES File Explorer
    Hi-Q MP3 Recorder
    Hide It Pro
    Recycle Bin by RYO Software
    ZArchiver
    Launchers included:
    Apex Launcher
    Nova Launcher
    installazione:
    Make sure to make and keep in a safe place an efs backup - a nadroid backup + titanium backup, in case you need to restore.
    Flash CWM Touch 6.0.3.2 + or latest TWRP Recovery (if you have a metadata error when flashing, you're using a wrong recovery!)
    Boot to Recovery
    Wipe data/factory reset - required if coming from another Rom or another Android version
    Flash Omega
    Reboot
    Vi consiglio se volete fare una pulizia completa e veloce di visitare questa discussione: [Tool][Aroma]Mega Wipe :-: Super Wipe :-: Factory Reset :-: Simple Wipe
  4. #73
    Modena
    Meizu M2 Note
    update!
    Omega AOKP v15.1:
    Kernel Stock
    CM apps:
    Dsp Manager
    Google apps:
    Playstore
    Chrome
    Gmail
    Google+
    Google Earth
    Google Search
    Hangouts
    Maps
    Music
    Play Newsstand
    Play Games
    YouTube
    Omegas extra apps:
    Flashplayer
    Dropbox
    ES File Explorer
    Hi-Q MP3 Recorder
    Hide It Pro
    ZArchiver
    Launchers included:
    Apex Launcher
    Nova Launcher
    At settings about > Build No. it say Omega v15 and not 15.1, this is normal
  5. #74
    Androidiano L'avatar di enomis1985
    Veniceland
    galaxy i9300
    hot spot wifi funziona ?
  6. #75
    Galaxy Note 4 Black
    Appena mi ridanno il cellulare dall'assistenza, sono sicuro che la flasherò. Domandina, hai scritto che ha gli stessi problemi della CM...Quali problemi sono stati riscontrati? La fotocamera come va? Scatta bene con il flash?
  7. #76
    Modena
    Meizu M2 Note
    update
    Omega AOKP v16:
    Kernel Stock
    Updated:
    Chrome
    Dolphin
    Dropbox
    Es File Explorer
    Gmail
    mGerrit
    YouTube
    Fixed:
    Calender sync
  8. #77
    Modena
    Meizu M2 Note
    update
    Omega AOKP v17:
    Kernel Stock
    Added:
    Genie Widget
    Updated:
    Apex Launcher
    Dolphin Browser & Jet Pack
    ES File Explorer
    mGerrit
    Recycle Bin
    Removed:
    Home Switcer
  9. #78
    proprio non riesco a fare gli screenshot. Bisogna premere volume down ed il tasto power ma a me non succede niente. Mi potreste spiegare come si fanno?
    Senior Droid L'avatar di fcriseo
    Vanzaghello (MI)
    Galaxi S & S3, Asus ZenFone 2
    Ringraziato 79 volte in 69 Posts
    Quote Originariamente inviato da teonicci Visualizza il messaggio
    devi premere power e home
  11. #80
    Quote Originariamente inviato da fcriseo Visualizza il messaggio
    niente neanche così... ovviamente ho provato prima a tener premuto il tasto power e poi home.. viceversa.. tutti e due insieme.. cmq indiee spiegava che erano gli altri due tasti.. ma anche li ho provato in ogni modo e nessun screenshot.
    Non è che devo abilitare qualcosa da qualche parte e non l'ho fatto?
