Pagina 15 di 66 primaprima ... 513141516172565 ... ultimoultimo
Visualizzazione dei risultati da 141 a 150 su 657
[DUAL-BOOT] Googy-Max Kernel (For SammyRom & CM 10.1/10.2)
  1. #141
    Quote Originariamente inviato da alegu Visualizza il messaggio
    Ecco a voi l'evoluzione del kernel Siyah...(questa frase mi ricorda qualcosa )
    Il Thread di riferimento su xda lo trovate linkato qui con relativo download:
    http://forum.xda-developers.com/show...php?p=41194664
    This kernel is ONLY for SAMSUNG 4.1.2 ROMS OR CM10.1 (or both ) !!!
    ATTENZIONE QUESTO KERNEL È VIETATO AI MINORI DI 16 ANNI PROVOCA "ASSOLUTA DIPENDENZA DA FLASH DI NOVITÀ" NON ABUSARNE...
    Googy-Max Kernel è inizialmente basato sull'eccezionale lavoro di Gokhanmoral (Siyah Kernel) .
    Current version : [ 1.4.2 ] - (26/05/2013) (Changelog on post #2)
    Features :
    - Based on Siyah Kernel 1.9.1 Sources
    - Dual-booting. You can have Samsung JB and CM10.1 ROMs on a single device at the same time :good:
    - Updated to latest ramdisk
    - Patched to Samsung Sources Update10
    - Linux version 3.0.78 :good:
    - Compiled with gcc linaro 4.7.3 :good:
    - Wireless hotspot working on sammy & cm
    - ZRAM activated and configurable in STweaks (On/Off (On default) - Zram disksize (400MB default) - Swappiness(80% default) ) :good::good::good:
    - CPU OC/UC/UV
    - GPU OC/UC/UV
    - Adaptive Body Bias control
    - Audio enhancement and sound boosting for great headphone experience (partial-port of wm8994 based implementation from project-voodoo)
    - Governors : Pegasusq / Zzmoove / Lulzactiveq [default] / Ondemand / Hotplug
    - Improved cpu hotplugging mechanism
    - I/O Schedulers : Deadline - cfq[default] - noop - row - sio - vr
    - Dynamic FSync
    - init.d support
    - Increased values for SD ReadAhead
    - Auto-root
    - Kernel based gestures support by Tungstwenty
    - NTFS automounting for USB sticks, mounted to /mnt/ntfs folder in Read Only mode
    - ExFAT support
    - mDNIe negative effect toggle with 4 consecutive press of home button
    - mDNIe values can be adjusted using the interfaces in /sys/class/misc/mdnie
    - Higher charging rates for AC & USB chargers (Fast Charge) [Adjustable]
    - CRT-OFF support (Early Suspend) [Adjustable]
    - TriangleAway support
    - Almost everything is configurable via simple and free STweaks (included in the kernel)
    - slide2wake (incomplete)
    - Gokhanmoral : For the wonderful base !!!
    - DerTeufel1980 for his help
    - Samsung : For the code source
    Source : (NOT up-to-date)
    https://github.com/googyanas/Googy-Kernel
    NON SONO, IL RESPONSABILE SE VI BRIKKATE IL TELEFONO, NE' TANTO MENO IL BLOG "ANDROIDIANI", SIAMO TUTTI MAGGIORENNI!.
    INUTILE DIRE CHE TUTTI I RINGRAZIAMENTI NON VANNO A ME MA A "googy_anas"
    E NON POTEVA MANCARE IL PERMESSO DI APRIRE IL THREAD
    ★★ oihcceps ollad klatapat noc otaivnI★★★
    Chi mi consiglia un buon settaggio per risparmiare batteria??
    Ultima modifica di erickmac; 27-05-13 alle 15:52
    Senior Droid L'avatar di peppesound
    Salerno
    Ringraziato 354 volte in 267 Posts
    Quote Originariamente inviato da N1m0Y Visualizza il messaggio
    Com'è il Touch-to-Wake?
    Inviato dal mio supermuletto :tank:
    lo usavo ai tempi dell'i9000, essendo implementato sui kernel per questo terminale. In sostanza ti permetti di riaccendere lo schermo dopo che si è spento atomaticamente, semplicemente tappando su di esso
    i9300 Marble white
    Kernel: Googy Max Kernel + Settaggi ILLUMINATI
    1° Rom: Imperium Rom 12.3
    2° Rom: Slim Rom 5
  4. #143
    Salerno
    Ragazzi..una domanda...voi consigliate di tenera attiva la zRam? Sapevo che questa funzione era utile per i dcvice che avevano poca Ram....ma visto che il nostro ha 1giga, non so serva piu di tanto...attendo consigli e pareri
    i9300 Marble white
    2° Rom: Slim Rom 5
  5. #144
    Anche io aspetto risposte!
  6. #145
    Huawei Mate 8
    Ringraziato 71 volte in 68 Posts
    Ciao a tutti,
    ho controllato se ci fossero dei settaggi ma giuro che non li ho trovati: qualcuno di voi ha da consigliarne? Grazie!
    TRATTATIVE CONCLUSE
    Downgrade da Marshmallow a Lollipop su Huawei P8? Leggi qui!
    Hai bisogno di contattarmi? Sono su Telegram!
  7. #146
    Androidiano VIP L'avatar di illuminato67
    Samsung Galaxy S7 Edge
    Ringraziato 6,421 volte in 2,733 Posts
    Quote Originariamente inviato da peppesound Visualizza il messaggio
    Tienila attiva
    Quote Originariamente inviato da Jianlucah Visualizza il messaggio
    Ciao a tutti,
    Puoi usare quelli del post 10 del 3d del Siyah
  8. I seguenti 2 Utenti hanno ringraziato illuminato67 per il post:
    Jianlucah (28-05-13),peppesound (29-05-13)
  9. #147
    Huawei Mate 8
    Quote Originariamente inviato da illuminato67 Visualizza il messaggio
    Tienila attiva
    Grazie per la risposta
    TRATTATIVE CONCLUSE
  10. #148
    Corato
    Samsung Galaxy S3
    Per esperienza personale e anche leggendo vari utenti su xda posso dirti che il telefono con zram disattivata è più fluido e ha meno lag... pensa che la home non mi si riavvia quando lo disattivo, invece quando attivo zram a volte si ricarica... a parer mio è solo fumo negli occhi
    DEVICE SONY Xperia Z3 D6603 Black
    ROM LOLLIPOP STOCK - ROOTED
    MICRO SD Samsung 32Gb classe 10
  11. Il seguente Utente ha ringraziato aldot89 per il post:
  12. #149
    Il kernel fa veramente schifo, il telefoni mi si spegne da solo, ed ho rischiamo anhe il freeze per aver attivato lulzactive al posto de pegasus! Tornato alla boeffla
  13. #150
    Corato
    Samsung Galaxy S3
    Quote Originariamente inviato da erickmac Visualizza il messaggio
    Mi sembra esagerato dare un feedback del genere, anche perchè se leggi un po' qua un po' su xda probabilmente è l'unico feedback di questo genere... spegnere non si spegne da solo anche con uv di -100, magari cosuma qualcosa di piu del persus si, però è anche l'unico aggiornato che consente il dual boot senza problemi... mha
