Pagina 148 di 232 primaprima ... 4898138146147148149150158198 ... ultimoultimo
Visualizzazione dei risultati da 1,471 a 1,480 su 2311
[ROM][4.3 MJ9] S4 Revolution v11™{why buy a new Note 3} 08/12
  1. #1471
    Androidiano VIP L'avatar di terzo33
    Palermo
    Galaxy S4
    Ringraziato 342 volte in 227 Posts
    Ragz ma non posso flashare il modem MJ9?
    DEVICE: Samsung Galaxy S4 16GB White Frost
    ROM: BoBCaTROM v.13
    KERNEL: Jeboo
    MODEM: Stock MJ7
    OPERATORE: Vodafone
    EXT MEMORY: Samsung MicroSDHC 32gb Classe 10 UHS-I
    Senior Droid L'avatar di luigiv97
    Ringraziato 48 volte in 40 Posts
    Quote Originariamente inviato da Ragz Visualizza il messaggio
    S4 Revolution v9 ONLINE !!
    Link (more coming soon) : https://mega.co.nz/#!y9J0lb7J!J9wdPj...GzyMgoM9D7lER4
    OTA download soon
    Changelog :
    -Fixed Network error after install ROM
    -Added kernel to aroma : liteGX,Adam,Googy Max
    -Updated modem from MC2 to MG4 (for who has modem lower that MG4,for who has MG4 or up you select NO FLASH OPTION in aroma)
    -Made some corrections/improvements in aroma installer (THANKS S0ul)
    -Updated stock kernel to MK2 (fixed wake up lag and better optimization)
    -Improved Water ripple effect using lib from S4
    -Added ANT+ support
    -Best face lib recognition from Note 3
    -Ported Galaxy Note 3 keyboard
    -Ported Music Player from S4
    -Ported S Voice from Note 3
    -Ported tutorial from Note 3
    -Ported S Health from Note 3
    -Ported S Note from Note 2 (THANKS ARSAW AND or1m)
    -Changed 5x5 icon in drawer launcher to 4x5
    -Fixed Magazine Home crash
    -Now open Magazine Home with swipe on much faster
    -Now open Magazine Home with press home button when you are in first page
    -Changed plat logo text
    -Enabled call recording
    -SMS app modded,that include the following features :
    -displaying sent Time instead of the received time
    -Permanent disabling of SMS, MMS & Email log history to be logged in call logs
    -SMS hack: SMS 200 recipients, stop SMS to MMS auto-converting, increase SMS hour limit, 1000 slides, group messages, scheduled messages and save/restore messages
    -Fixed crash Touchwiz when you press 2 time home button
    -Lot of other bugfix
    -Improved performance and stability
    UPDATED FROM LATEST FIRMWARE 4.3 FOR S4
    -Alarm widget
    -Easy Launcher
    -Easy Settings
    Grande!
    Una sola domanda, c'è l'effetto luce nello sblocco?
  4. #1473
    GTi9300 and SM-G920F
    Ciao ragazzi,
    scusate il disturbo, vorrei installare questa ROM e poichè parto da JB 4.1.2 voelvo fare una installazione pulita partendo da questa guida https://www.androidiani.com/forum/mo...ustom-rom.html, me lo consigliate?
    Inoltre dalle info del telefono vedo che ho il modem XXEMG4, in fase di installazione devo fare qualcosa di particolare?
    Ciao e grazie a tutti!
    P.S. Ragz complimenti per il tuo lavoro!
  5. #1474
    Senior Droid L'avatar di Michaelsdj
    Galaxy s3
    Ringraziato 41 volte in 36 Posts
    Come consiglio ti posso dire di fare un full wipe . Per la recovery è uguale, lo stesso per il root
    Esagerato...
    Si perché sono a dieta :-) :-D :-D
  6. #1475
    Androidiano VIP L'avatar di Ragz
    galaxy s3 galaxy s2 nexus
    Ringraziato 1,003 volte in 592 Posts
    Quote Originariamente inviato da Mauz17 Visualizza il messaggio
    Stasera anche io provo la tua creatura!
    Ps. Qualcuno mi consiglia un buon modem (ho mg4 ora) e un buon kernel?
    Con la tua rom faccio anche io il salto di qualità a 4.3! :P
    Come modem scegli l'MG4 o quello del firmware 4.3 negli UK. Come kernel il liteGX se non sei esperto in settaggi,oppure il googy se vuoi un'alta personalizzazione
    Quote Originariamente inviato da radis Visualizza il messaggio
    adesso che è uscita la v.9 inizieranno a chiedere la v9.1 scherzi a parte tutte queste richieste credo siano un attestato di stima per ragz e per il buon lavoro che fa ... di rom ne ho provate a iosa ma la tua è magnifica ora stò scaricando la v9 grazie e complimenti
    Speriamo di no
    Ma la v9.1 non dovrebbe tardare ad arrivare
    Quote Originariamente inviato da terzo33 Visualizza il messaggio
    Si
    Quote Originariamente inviato da luigiv97 Visualizza il messaggio
    Grande!
    No non c'e...
    Quote Originariamente inviato da Diavolo89 Visualizza il messaggio
    Ciao ragazzi,
    Si è possibili seguire quella guida,ma io non l'ho mai provata...
    In aroma puoi anche non selezionare il modem MG4,tanto ce l'hai già. In qualunque caso tu non avrai problemi
    Quote Originariamente inviato da Michaelsdj Visualizza il messaggio
    Allora ti do ragione
    PROVA LA MIA ROM,NON TE NE PENTIRAI !
  7. I seguenti 2 Utenti hanno ringraziato Ragz per il post:
    Diavolo89 (13-11-13),Michaelsdj (13-11-13)
  8. #1476
    Aggiornato il primo post... vi piace o era meglio prima ?
  9. #1477
    la fotocamera non va..
  10. #1478
    Così mi piace di più!
  11. #1479
    Scusatemi il triplo post
    Browser S4 (port from latest 4.3 firmware for S4) : https://mega.co.nz/#!TtY3nQzT!KMdr_V...lPrJAe--ZiAQoo
    COMPARAZIONE CON IL BROWSER STOCK S3
    Il browser di S4 ha una nuova UI,tra cui la modalità Full Screen e una nuova gestione delle finestre. E' più fluido e ha qualche funzione in più. Però in alcune circostanze è laggoso e ha un alto utilizzo di ram se confrontato con S3. Proprio per questo ho deciso di non integrarlo ma darvi l'opportunità di scegliere quale browser usare
  12. #1480
    tutto ok apparte che alcune app come supersu non possono aggiornarsi mostrando l'errore -110, la fotocamera non funziona e lo schermo sembra tremare..
    provo a riflashare installando fotocamera e galleria del nexus e kernel liteGX (prima avevo flashato il googymax)
