Pagina 1 di 12 12311 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 111
[GUIDA][ROOT EXPLOIT+PATCH][2012.12.19] ExynosAbuse APK v1.40
    ATTENZIONE:
    Essendo una procedura appena creata potrebbe essere moooooolto instabile e creare danni al cellulare, considerato anche che sfrutta una falla del sistema...
    Se la usate lo fate a vostro rischio e pericolo.
    Provato su jb 4.1.2 Polonia.
    Non aumenta il counter
    Quote Originariamente inviato da Chainfire Visualizza il messaggio
    This is an APK that uses the ExynosAbuse exploit (by alephzain) to be able to do various things on your Exynos4 based device.
    Features for non-rooters:
    - Securely patch the exploit
    Features for rooters:
    - Root the device (SuperSU v0.99)
    - Enable/disable the exploit at will
    - Enable/disable patching the exploit at boot
    - Unroot and cleanup (optionally leaving the exploit patch at boot in place)
    Please note that patching the exploit may break camera functionality, depending on device and firmware. Also note that if use the patch method without rooting, or keep patching the exploit at boot enabled when unrooting, you need an alternate method to re-root the device to disable this feature (like CF-Auto-Root) - you cannot use ExynosAbuse to do this since it patched the exploit. Unlike other patch authors, I do not believe in keeping an invisible rooted process running in the background while pretending you aren't rooted, to be able to unpatch this way.
    While the exploit patches work (aside from possibly disabling your camera), these are more work-around than actual fixes. A proper patch would be a kernel fix, either from a third party or Samsung themselves (hopefully one day...)
    My method vs Supercurio, RyanZA
    Mine is the only one that is secure. Both Supercurio's and RyanZA's method leave you with easily exploitable holes any serious malware author will abuse. More details http://forum.xda-developers.com/show....php?t=2053824
    Exploit
    For more details on the exploit itself, see this thread: http://forum.xda-developers.com/show....php?t=2048511. The exploit is used by this APK in unmodified form. You should be very afraid of this exploit - any app can use it to gain root without asking and without any permissions on a vulnerable device. Let's hope for some fixes ASAP !
    Camera
    If your camera keeps working depends on your device/firmware combination. Affected are mostly the SGS3, but there is good news too, there is a potential fix here: http://forum.xda-developers.com/show....php?t=2052675 SGS3 I9300 ONLY. It seems to work for a number of people. It replaces some system libraries with libraries from a different firmware version that does not rely on /dev/exynos-mem. Do not attempt this unless your camera actually breaks due to the exploit, and beware it may cause you to have to reflash your firmware. Also beware that even though this change will not prevent OTAs from downloading, it can possibly prevent OTAs from flashing succesfully.
    Device status
    Using this patch may turn your device status into modified. There's not really a proper solution to that at the moment, but you can restore status by removing the patch (and SuperSU) again and rebooting your phone. This will however leave you unprotected again. Doing all sorts of weird stuff (like for example wiping data) to get rid of this modified status while you're still have the patch applied at boot or keep SuperSU around, is an exercise in futility. If you want to go ahead and do that, that is fine, but do not litter my thread with your comments. Because eventually, the modified status is likely to return
    Compatibility:
    (If your device isn't listed it could still be both compatible with the exploit as well as this fix !)
    Samsung Galaxy S2 GT-I9100
    Samsung Galaxy S3 GT-I9300
    Samsung Galaxy S3 LTE GT-I9305
    Samsung Galaxy Note GT-N7000
    Samsung Galaxy Note 2 GT-N7100
    Samsung Galaxy Note 2 LTE GT-N7105
    AT&T Galaxy Note 2 SGH-I317
    Verizon Galaxy Note 2 SCH-I605 both locked and unlocked bootloaders work
    Samsung Galaxy Camera EK-GC100
    Samsung Galaxy Tab Plus GT-P6210
    Samsung Galaxy Note 10.1 GT-N8000, GT-N8010, GT-N8013, GT-N8020
    Google Nexus 10 not compatible, Exynos5
    Post in this thread if you have a device to add.
    Notes
    I'm not sure if this APK will work right on Android 2.x devices (not tested yet), doesn't mean the exploit doesn't work. So if you're on Android 2.x and this APK doesn't work for you, try doing the exploit manually.
    Download
    Please do not redistribute, link to this thread instead
    (v1.00: 3786; v1.10: 6397; v1.20: 12004; v1.30: 14480)
    Questo è il link alla discussione e al download.
    http://forum.xda-developers.com/show....php?t=2050297
    Visto che l'autore ha chiesto di non postare l'apk se qualcuno lo dovesse fare in questa discussione lo considereró warez... E lo infrazioneró
    Ultima modifica di Anna; 19-12-12 alle 18:43
  2. Il seguente Utente ha ringraziato Anna per il post:
    CamCam (09-01-13)
    2012.12.19 - v1.40
    - Added check for updates functionality
    - Added "current status" display
    - Split into sections for non-rooters and rooters
    - Added "One-click secure exploit patch" for those who just want to patch their device and forget about
    - Added ability to unroot and clean up the leftovers (optionally leaving the patch code in place)
    2012.12.18 - v1.30
    - Adjusted many things in the shell code, the app will now properly detect an install SuperSU/Superuser with the wrong permissions as NOT having root
    - Added a startup notification telling you your device/firmware is not susceptible to this exploit, if it isn't
    2012.12.17 - v1.20
    - Gingerbread-related fixes - note that not all Gingerbread firmwares of affected devices are vulnerable (for example, I know several SGS2 GB firmwares are not exploitable)
    - Added some spam (view my apps on Play, follow me on Twitter, that sort of BS)
    - Added icon
    2012.12.16 - v1.10
    - Added ability to disable and re-enable the exploit (which may break camera)
    - Added ability to disable exploit at boot (before any Play-installed app runs, other solutions run later which means they are still vulnerable)
    - Both above features require being rooted
    2012.12.16 - v1.00
    - Initial release
    Trollallero Trollallá mediante il mio GS2 con gingerbread 2.3.5 ki8
    Ultima modifica di Anna; 19-12-12 alle 18:45
  5. #3
    Androidiano VIP L'avatar di alegu
    MILANO
    NOTE3
    Ringraziato 2,319 volte in 1,584 Posts
    Ops...mi è scappato il dito...sarà il thread più visitato
    INVIATO DA ? CON IL MIO S?
  6. #4
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    Quote Originariamente inviato da alegu
    certo che lo sarà
    tranquillo ti redimo io
    Ultima modifica di dieguccio; 16-12-12 alle 19:54
  7. #5
    Ringraziato 80 volte in 76 Posts
    sta falla è peggio del bug emmc del note
    edit: leggendo su xda sembra che i dev abbiamo contattato samsung e messa al corrente
    Okay thanks, I confirm that people at Samsung have just made aware of it.
    Ultima modifica di quicck; 16-12-12 alle 20:05
  8. #6
    Jan 2010
    Come faccio a toglier il root una volta rootato tramite questo apk???
  9. #7
    Androidiano VIP L'avatar di ameris
    Udine
    samsung galaxy s6 32gb
    Ringraziato 66 volte in 52 Posts
    leggendo rapidamente "ho sonno" vedo che è stata trovata la falla nel kernel.. quindi sto trucchetto va solo con il kernel originale samsung?
    Ultima modifica di ameris; 17-12-12 alle 02:00
    Device : samsung galaxy s6 black sapphire 32gb , motorola moto E
    avuti negli ultimi mesi : s5;lg g3 32gb;nexus 6;meizu m2 note;
  10. #8
    già installata l'app sul mio s3
  11. #9
    Androidiano VIP L'avatar di Dezk
    Verona
    OnePlus3
    Ringraziato 268 volte in 194 Posts
    Scusate ma sono una pippa in inglese, tutto questo cosa comporta?
    OnePlus 3
  12. #10
    Quote Originariamente inviato da ciska Visualizza il messaggio
    Devi usare altri metodi, questo non toglie il root
    Quote Originariamente inviato da ameris Visualizza il messaggio
    No, io sul gs2 l'ho usato su cyano10.1 (togliendo prima il root con l'applicazione supersu)
    Quote Originariamente inviato da Maltempo Visualizza il messaggio
    Che fai il root da firmware stock con un applicazione. Anche se molto pericoloso perché sfrutta un bug del sistema
    Trollallerollá
  13. Il seguente Utente ha ringraziato Anna per il post:
    Dezk (17-12-12)
