Pagina 11 di 12 primaprima ... 9101112 ultimoultimo
Visualizzazione dei risultati da 101 a 110 su 111
[GUIDA][ROOT EXPLOIT+PATCH][2012.12.19] ExynosAbuse APK v1.40
  1. #101
    Senior Droid L'avatar di max70
    Galaxy S3
    Ringraziato 101 volte in 86 Posts
    Si, la XXDLJ4 ufficiale nobrand.
    Se ti ho aiutato metti un thanks, a te non costa niente, ma e me fa piacere.
    Possessore di Galaxy S3 Marble White
    Quote Originariamente inviato da max70 Visualizza il messaggio
    Ok...
    Jb sta dando segnali strani...
  4. #103
    Ringraziato 80 volte in 76 Posts
    inizia in uk il roll out del fix per questo bug
    Samsung now officially rolling out the new Android 4.1.2 Jelly Bean update for Samsung Galaxy S3 GT-I9300 in UK. This update brings the important role to fix the infamous Exynos memory bug that has been reported as a treat to users affected devices like Samsung Galaxy S2/S3, Galaxy Note 2 and all other Exynos based devices. If your device is affected, it would enable anyone with an evil intentions and could build an app to possibly access sensitive data like passwords and even credit card information which are stored in the physical memory. This a serious issues and could be dangerous and even fatal for the security of such devices, so this update is truly very important to Galaxy S3 users.
    Update Build: I9300XXELLA Android 4.1.2 Jelly Bean
    The firmware build number is I9300XXELLA an update from earlier released I9300XXELL4. United Kingdom is the first country to receives this update via Samsung Kies and OTA (Over the Air). So, just check it out right now, the I9300XXELLA weighs around 21.38MB.
    Device: Samsung Galaxy S III GT-I9300 (unbranded)
    Region: Europe
    Country: United Kingdom
    Build Number: JZO54K.I9300XXELLA
    Android version: 4.1.2 aka Jelly Bean
    PDA: I9300XXELLA
    CSC: I9300OXAELLA
    Baseband/Modem: I9300XXELLA
    Build Date: Dec-22-2012
    Released Date: Jan-02-2013
  5. #104
    Quote Originariamente inviato da quicck Visualizza il messaggio
    Infatti con quel firmware questo metodo non funziona più
  6. #105
    Dec 2009
    roma
    One Plus, Tab4, G3 32 gb ....
    Ringraziato 173 volte in 162 Posts
    Quote Originariamente inviato da JacOcaJ Visualizza il messaggio
    Non è ancora iniziato in UK? Io ho due S3 e quello uk è originale mentre l'altro ovviamente no. Non avendo ancora ricevuto alcun aggiornamento sul device (voda UK) presumo non sia ancora cominciato.
  7. #106
    Androidiano L'avatar di teoma
    Samsung Galaxy S4
    Ciao a tutti........
    Ho il telefono tutto stock 4.1.1, l'unica cosa che ho installato è exynos abuse solo per avere il root e non per correggere la falla delle "morti sospette".
    Ora quando arriverà l'aggiornamento via ota alla versione 4.1.2 avrò problemi o lo installa tranquillamente?
    Grazie a tutti
  8. #107
    Quote Originariamente inviato da teoma Visualizza il messaggio
    Grazie a tutti
    questo exploit non corregge la falla delle "morti sospette" comunque quando sarà il momento puoi togliere il root e l' app e aggiornare
  9. Il seguente Utente ha ringraziato Anna per il post:
    teoma (04-01-13)
  10. #108
    Sep 2010
    latina
    Realme X2-redmi note 9s
    Salve,io ho ancora il cell originale..., con l'ultima versione j4 volevo sapere se faccio questa guida ho il root senza toccare il contatore..?
  11. #109
    Quote Originariamente inviato da leodan70 Visualizza il messaggio
    Si dovrebbe....
    Leggi bene la prima pagina
  12. #110
    Androidiano L'avatar di darthmodel
    Mar 2011
    Ciao a Tutti
    Sto usando questa EXYNOS ABUSE per un tablet HYUNDAI che monta cpu EXYNOS
    l'app funziona, ma volevo capire il passaggio per fare l'UNROOT scegliendo l'opzione
    Unroot and cleanup (optionally leaving the exploit patch at boot in place)
    dato che non riesco a tradurre benissimo il senso di optionally leaving the exploit patch at boot in place
    se clicco questa opzione cose accade ? mi chiede se voglio patchare il buco oppure no ?
    sarebbe utile una spiegazione più estesa magari di tutte e 4 le opzioni.
    circa SUPERSU:
    facendo un wipe del sistema, mi è sparita la app SUPERSU che mi si era installata automaticamente installando EXYNOS ABUSE.
    L'ho ripresa dal market nella sua ultima versione. E' lo stesso oppure mi serviva proprio quella che installava EXYNOS ABUSE ?
    grazie mille
    ciao
