Pagina 4 di 1205 primaprima ... 2345614541045041004 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 12043
[ROM] CyanogenMod 11 Official Builds [4.4][GT-I9300]
  1. #31
    Io ho messo la Philz 6.0.4.5 tutto ok.. Anche io ho notato la status bar nera nella lock sc reen, in piu non mi legge la sd.. A voi ragazzi?
    Senior Droid L'avatar di luigiv97
    Ringraziato 48 volte in 40 Posts
    Con l'ultimo aggiornamento risolto il bug della stutus bar
  4. #33
    Senior Droid L'avatar di Moskyz
    Associazione Cazzeggiatori Anonimi
    Galaxy S3
    Ringraziato 74 volte in 65 Posts
    Fuori nightly del 7/12/13
    Ecco il changelog
    Since Fri Dec 6 12:20:58 UTC 2013
    android
    • e39e0a3 4.4_r1.2 -> 4.4.1_r1
    build
    • cefde81 Merge "Revert "build: add AST support"" into cm-11.0
    • bfadf99 Revert "build: add AST support"
    • c8eda46 Merge commit '4.4.1_r1' into HEAD
    • 97e7cae build: add AST support
    external/skia
    • b81d6f4 Revert "Skia: Add NEON intrinsic D32_A8_Black and D32_A8_Opaque"
    external/wpa_supplicant_8
    • 67128b6 Merge tag 'android-4.4.1_r1' into HEAD
    • 6125d0e eap_proxy: Add context data pointer to the get_imsi call
    • 6f23a73 eap_proxy: Re-read IMSI from proxy in Interworking functionality
    • 9656c41 eap_proxy: Confirm eap_proxy initialization before reading SIM info
    • a178e5d P2P: Clear p2p_group_formation and p2p_in_provisioning on group removal
    • fde766c P2P Extend postponing of concurrent scans for persistent GO
    • 94bdb98 P2P: Extend group formation timeout on GO to first data connection
    • a745708 P2P: Cancel group formation timeout on client connection
    • f221369 P2P: Increase Invitation Request timeouts
    • 1485026 Fix ENABLE_NETWORK not to reconnect in disconnected state
    • c9b2093 P2P: Allow persistent group determination based on Beacon frame
    • 9af8f6c P2P: Do not allow P2P client connection without P2P IE from GO
    • 7569e15 P2P: Do not drop P2P IEs from BSS table on non-P2P scans
    • 937b595 P2P: Allow GO to be discovered based on Beacon frame
    • 3589704 P2P: Show p2p flag in debug info for scan results
    • e40b5c4 P2P: Show P2P flag in BSS entries also based on Beacon frames
    • 6b7661d p2p: Add p2p_no_group_iface flag to p2p conf file
    • 0632836 Use configured sched_scan interval for the PNO scan
    • 544dd9d WPS: Ignore PBC-to-PIN change from M1 to M2 as a workaround
    • 191324e Android: Add PMF support to hostapd build
    • 559bdba Enabling the HS2.0 functionality in the default config file
    • d544c9b Android: Enable IEEE 802.11r in wpa_supplicant builds
    • c3b28c2 Android: Enable IEEE 802.11w support in the build
    • 9a301b1 Android: Enable WNM in the build
    • 4682053 wpa_supplicant_8: Remove android specific handling for assoc reject events
    frameworks/base
    • abf2cb8 Merge "Avoid layout passes when updating data activity indicators." into cm-11.0
    • 17c2e4f Merge "Make ImageView drawable update more efficient in some cases." into cm-11.0
    • 9628375 Merge "Revert "core: add AST support"" into cm-11.0
    • a462079c Revert "core: add AST support"
    • 34ec6a3 Merge commit '4.4.1_r1' into HEAD
    • 864a84c core: add AST support
    • 1e3c4a9 SystemUI: unbreak RecentsPanel with translucent decors.
    • cc2b05b Merge "Keyguard: fix statusbar lags when default widget shown." into cm-11.0
    • 22a7c84 Merge "framework: fix screenshot and rotation animation for devices with abnormal hw rotation" into cm-11.0
    • c872eca QS: Disable WifiDisplay tile
    • 58f25d1 Merge tag 'android-4.4.1_r1' into HEAD
    frameworks/native
    • 753e3c8 Merge commit '4.4.1_r1' into HEAD
    • 2b38f72 Merge "add BoardConfig flag TARGET_USES_OPENGLES_FOR_SCREEN_CAPTURE" into cm-11.0
    packages/apps/CMUpdater
    • 92d6255 CMUpdater: Fix for Transifex
    packages/apps/Dialer
    • cc7ba81 Merge "Dialer: DE translation" into cm-11.0
    • e2a5210 Partial revert of cce501cbde0ba0a53e1f458328bb96dff4dd6588
    • d05e1d8 Merge tag 'android-4.4.1_r1' into HEAD
    packages/apps/Settings
    • 826b137 Merge commit '4.4.1_r1' into HEAD
    • 53ffd59 Merge tag 'android-4.4.1_r1' into HEAD
    packages/inputmethods/LatinIME
    • e447523 Merge commit '4.4.1_r1' into HEAD
    packages/providers/MediaProvider
    • e1a8739 Merge tag 'android-4.4.1_r1' into HEAD
    vendor/cm
    • 5a27f63 cm: Allow devices to set the GMS client id
    • 275701b cm: Remove procmem and procrank from user builds
    vendor/lge
    • 3aed0e9 Merge pull request #26 from TheMuppets/cm-11.0-to-4.4.1-props
    • 925c859 4.4.1 props
    • ecc3d0a vs980: update blobs
    vendor/samsung
    • 398178d Merge pull request #355 from invisiblek/cm-11.0
    • 27d4192 d2/jf: vendor-ize the camera blob
  5. Il seguente Utente ha ringraziato Moskyz per il post:
    criiistian (07-12-13)
  6. #34
    Androidiano L'avatar di zatto00
    ZTE Nubia z7 max
    Ringraziato 30 volte in 16 Posts
    Si può configurare cyandelta per la cm11?
  7. #35
    buongiorno a tutti
    vorrei sapere se posso installarla senza problemi avendo già i modem nuovi (quelli che cambiano la cartella efs) oppure prima devo ripristinare con i modem vecchi
    AndroidNow HD 14.0
  8. #36
    Galaxy S3
    Quote Originariamente inviato da zatto00 Visualizza il messaggio
    Non saprei...io l'ho installata normalmente con wipe cache + dalvik
    Edit: la nuova nightly fa si che all'avvio lo sfondo sia ben posizionato, la statusbar nella schermata di blocco sia trasparente e che il risveglio col tasto centrale sia più veloce
    Ultima modifica di Moskyz; 07-12-13 alle 16:50
  9. #37
    La sto provando da stamane
    ci sono ancora troppi bug, se si scorre velocemente il menu dei widget si blocca,il flash della fotocamera non funziona correttamente
    con la nightly di oggi è passata alla versione 4.4.1
    sicuramente con i prossimi aggiornamenti le cose miglioreranno
  10. #38
    Mar 2011
    prov MC
    galaxy S3 - nexus 7 II
    Installata da qualche ora, poco dopo l'ho aggiornata alla 4.4.1 ottima!
    avete qualche soluzione per flash player?
    consigliate qualche kernel in particolare?
    ciao
    Ultima modifica di Marco867; 07-12-13 alle 18:01
  11. #39
    Galaxy S3
    Quote Originariamente inviato da Marco867 Visualizza il messaggio
    ciao
    Io ho installato l'apk modificato appositamente per KitKat e funge
    Edit: qui trovi il flash http://docs.google.com/file/d/0B1qjr...1EVWM5YlE/edit
    E poi per farlo funzionare devi necessariamente scaricare dolphin e attivare il flash di li
    Ultima modifica di Moskyz; 07-12-13 alle 19:06
  12. Il seguente Utente ha ringraziato Moskyz per il post:
    Marco867 (07-12-13)
  13. #40
    non capisco perchè a me non s'installa, mi da errore md5
