Pagina 135 di 140 primaprima ... 3585125133134135136137 ... ultimoultimo
Visualizzazione dei risultati da 1,341 a 1,350 su 1396
[ROM] [UBUGNB1] [4.3] [Sammy's Stock] | [06/04/14] ArchiDroid V1.7.14[I9300]
  1. #1341
    Androidiani Power User L'avatar di Promez
    Samsung Galaxy S3
    Ringraziato 1,724 volte in 1,012 Posts
    Dear AD 1.X users.
    As you probably noticed, I stopped updating AD 1.X some time ago. Samsung didn't release KK for our device, and there's literally nothing changing between each "new" version. Not to mention that we're still on 4.3 JB, while on the other side of the barricade I'm working on 5.1 LP.
    I decided, that ever if I wanted, I wouldn't find any motivation to work on AD 1.X anymore. This project is more or less complete, it features everything I ever wanted, and due to the fact that I switched myself to AD 3.X (based on AOSP) about half a year ago, I have no use of old AD 1.X, that served me well up to that point.
    Therefore, I kindly notice everyone of you, that this project is now in official EOL (end of life) state. It is no longer updated, and you shouldn't expect any updates, neither support regarding AD 1.X from now on.
    This was my first project on XDA, I started as total noob dev, and today they call me "RC/RD" . I simply can't find any use of CrapWiz anymore, and with today's experience I wouldn't start such project at all, I'd use AOSP from the start.
    It was fun, I learned a lot about CrapWiz and CrapSung, but this is where one project must end it's life to make room for other, better ones.
    If you're searching for good AD replacement, please give AD 3.X a try. This is the ROM I'm using myself, and I'm constantly updating it.
    If you're interested in CrapWiz ports, there are many currently available.
    And if you want to keep 4.3, well, you can stay on AD 1.X. It works, and it will work - Samsung is not touching that legacy code anyway.
    Lastly, I'd like to thank everyone of you, who supported me, or this project, directly or indirectly.
    Goodbye
    OnePlus One 64Gb : Dirty Unicorns V10.5 05/08 (6.0.1 MTC20F) / Banks Dynamic Gapps
    Google Nexus 7 32Gb : Nougat AOSP 11/08 (7.1.2 NZH54D) / OpenGapps Pico
    Ex Samsung Galaxy S3 Murble White, Google Nexus 4
    Ringraziato 24 volte in 21 Posts
    salve ragazzi,
    ho notato che se provo ad equalizzare il suono con il boeffla non riesco a farlo. Qualcuno ha qualche suggerimento da darmi?
    grazie a tutti lol
  4. #1343
    Androidiani Power User L'avatar di xPissio
    Mar 2014
    Padova
    OnePlus 6
    Ringraziato 1,348 volte in 785 Posts
    Come gira questa ROM?
    OnePlus 6 // OxygenOS 9.0.5
    ______________________________________
    Regolamento Forum
  5. #1344
    Samsung Galaxy S3
    Quote Originariamente inviato da xPissio Visualizza il messaggio
    Molto bene, ma lo sviluppo è terminato
  6. #1345
    Aug 2014
    Messina
    Galaxy S3
    Salve a tutti ragazzi, ho installato da circa 2 mesi la ROM Archidroid 1.7.18 e da 3-4 giorni a questa parte, da un punto all'altro quando ho aperto l'applicazione fotocamera mi spunta un messaggio popup con scritto "Errore Fotocamera". Dando un click sull'ok l'app si chiude. E ogni volta che la riavvio mi da sempre questo errore. Ho fatto il reset data-chache-dalvik. Ho provato ad installarla nuovamente tramite twrp ma niente, sempre lo stesso errore. Come posso fare? Sinceramente non mi va di cambiare ROM anche perche con questa trovo un rapporto prestazioni\durata batteria eccellente. Aiutatemi per favore
  7. #1346
    Samsung Galaxy S3
    Quote Originariamente inviato da GianniGS3 Visualizza il messaggio
    Strano, di solito quel problema accade quando si flasha la Rom con un kernel diverso dallo stock.
    Che kernel hai?
  8. Il seguente Utente ha ringraziato Promez per il post:
    GianniGS3 (28-04-15)
  9. #1347
    Aug 2014
    Messina
    Galaxy S3
    Quote Originariamente inviato da Promez Visualizza il messaggio
    Che kernel hai?
    Ho scelto il boeffla tra quelli proposti dall'installazione della Rom.
    Non ho cambiato il kernel, è sempre rimasto questo. Cosa posso fare?
    Edit. Ti allego lo screen del boeffla cosi puoi vedere il kernel che ho. Allegato 141744
    Ultima modifica di GianniGS3; 27-04-15 alle 23:08
  10. #1348
    Samsung Galaxy S3
    Non vedo niente
    Comunque prova a flashare lo stock e vedi se continua il problema
  11. Il seguente Utente ha ringraziato Promez per il post:
  12. #1349
    provala non te ne pentirai...
  13. #1350
    È successo anche a me, x ora uso l app per il reset della fotocamera cercalo sul play store...
