Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 19
[AOSP 4.3+][PORT][APP]Fix App Fotocamera e Lib per tutte le ROM CM/AOSP
    Senior Droid L'avatar di ammanna
    Modena
    Meizu M2 Note
    Ringraziato 228 volte in 129 Posts
    FIX FOTOCAMERA per tutte le CM/AOSP
    Come da titolo, ecco, anche sul nostro forum, il fix delle Camera app per l' sgs3
    - Testato su: Official cm10.2 nightlies, Temasek's Unofficial cm10.2, Temasek's Unofficial cm11.0
    - Funziona anche per: Molte CM/AOSP roms come PA, AOKP, Carbonn Rom, PAC, RR e altre
    Changelog completo
    Changelog ultima versione:
    V5 Update on 17/05/2014 :
    For CM Mod : 1. New camera app from CM11S with cool UI and more features.
    2. Added wrapper to blob camera.
    3. Fixed Goggle camera freeze after 1st shot. (http://review.cyanogenmod.org/64070)
    4. Added perfectly working snapshot while video recording feature. (http://review.cyanogenmod.org/64071)
    For OmniRom : New camera app from CM11S with cool UI and more features.
    Pros:
    1. Storage to external SD. (Tested on Temasek's cm11 builds)
    2. Timely synchronized flash when auto focus is on.
    3. All camera features those were available on cm10.2 nightlies.
    Cons/Bugs:
    1. Video recording previews are stretched, but recording comes normal.
    2. Gallery can't delete images captured from camera from external sd card, internal sdcard working good.
    Installazione/Update Zip:
    1.- Scaricate l' ultima versione
    2.- Entrate in recovery
    3.- Flashare lo zip
    4.- Wipe cache e dalvik
    5.- Reboot
    6.- Enjoy!
    Per chi utilizza ROM Omni o basate su essa, flashate solo la "Lib"!
    Download Zip, Lib:
    - CM_Fixed_Camera_for_CM_All_AOSP_roms_by_RohanAJosh i_V5.0.zip
    - Omni_Fixed_Camera_for_OmniRom_by_RohanAJoshi_V5.0. zip
    * Invece per risolvere il problema "Can't connect camera" (="Impossibile collegarsi alla fotocamera"), utilizzate questa app:
    Restart Camera by temasek APK
    Credits :
    RohanAJoshi
    Dhiru1602(For perfectly working lib)
    Temasek(for camera app)
    Discussione originale su XDA: [AOSP 4.3+][PORT][APP]Fixed Camera App and Lib for CM/All AOSP roms
    Ultima modifica di ammanna; 22-05-14 alle 23:17
  2. I seguenti 2 Utenti hanno ringraziato ammanna per il post:
    boris1971 (04-05-14),Daxer (04-05-14)
    Modena
    Meizu M2 Note
    Mio non si sa mai
  5. #3
    Modena
    Meizu M2 Note
    Io utilizzo questo fix per esempio sulla rom RR e funiona perfettamente sia con la fotocamera della rom sia con la Google camera che consiglio a tutti profondamente!
  6. I seguenti 2 Utenti hanno ringraziato ammanna per il post:
    acca (04-05-14),Daxer (04-05-14)
  7. #4
    Ringraziato 49 volte in 43 Posts
    Ammanna per chi come me utilizza la PA 4.3 beta 2 su galaxy s3 deve flashare tutti e due o solo
    - Fixed_Camera_for_CM_All_AOSP_roms_by_RohanAJoshi_V 4.0.zip ??
  8. #5
    Androidiano L'avatar di Daxer
    Samsung Galaxy S3
    Ringraziato 25 volte in 22 Posts
    Con la Resurrection Remix 5.1.0 cosa devo flashare? Non so su cosa è basata la Rom. Grazie
  9. #6
    Modena
    Meizu M2 Note
    Quote Originariamente inviato da boris1971 Visualizza il messaggio
    Solo fixed camera, no Omni lib
    Quote Originariamente inviato da Daxer Visualizza il messaggio
    Devi flashare fixed camera
  10. I seguenti 2 Utenti hanno ringraziato ammanna per il post:
  11. #7
    Samsung Galaxy S3
    Perfetto, grazie )
  12. #8
    Modena
    Meizu M2 Note
    se vi va lasciate un commento sul funzionamento del fix o lib o apk o tutti e 3 a seconda di quali usate
  13. Il seguente Utente ha ringraziato ammanna per il post:
    Daxer (04-05-14)
  14. #9
    Samsung Galaxy S3
    Il fix funziona egregiamente, l'apk anche, ma interrompe dei processi, ad esempio il lettore musicale.
  15. Il seguente Utente ha ringraziato Daxer per il post:
    ammanna (04-05-14)
  16. #10
    samsung galaxy s3 , iphone 3g
    Ma per flasharla mi si resetta il cellulare io ho la rr 4.4 ???
