Pagina 1 di 82 1231151 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 818
[ROM] Resurrection Remix® 4.4.2 KitKat [AOKP][CM][PA][Omni][OTA][ART][I9300]
    Senior Droid L'avatar di ammanna
    Modena
    Meizu M2 Note
    Ringraziato 228 volte in 129 Posts
    Resurrection Remix ROM ®
    La RR è una ROM basata sulle più famose e utilizzate aosp: AOKP, CM, PA, Omni e l' originale ROM Remix.
    Questa combo genera fantastiche performance, molteplici personalizzazioni, potenza e tantissime features tutto insieme nel vostro dispositivo.
    Alcune Features e Personalizzazioni:
    Pitch Black
    Double-tap to sleep
    Quick access ribbon
    Expanded desktop
    Quick launch shortcuts
    Navigation bar height
    Network speed indicator
    Screen record
    Halo
    Lock screen slider shotcuts
    App Bar
    Clock widget
    Brightness adjustment
    Trasmetti schermo
    Custom carrier label
    Adaptive backlight
    Tiles style
    Power sounds
    Custom progress bar
    Camera mods
    Advanced display
    Luce di notifica pulsante
    Music Toggle
    ListView Animations
    Screen-off animations
    Intensità vibrazione
    Custom system animations
    Privacy
    Lockscreen see blur and reduce slider
    App permissions
    Recents Ram bar
    Center clock
    Battery bar
    Slider torch
    Blur lock screen
    Suspend actions
    Wakelock blocker
    Toast animation
    OmniSwitch
    Active display
    Lockscreen Notifications
    Slim Recents
    ART runtime
    PEEK
    TANTO TANTO ALTRO!!
    Changelog completo
    Changelog ultima versione:
    # Resurrection Remix KitKat 4.4.2 - v5.1.5-20140609 # Basic
    - Navigation bar dimensions
    - Ability to disable hardware keys via nav bar settings
    - Add android:key in hardware keys enable/disable option to forward enable this option
    - Themes: Delete icon resources during uninstall
    - Themes: remove unused code
    - Themes: uninstallThemeForAllApps shouldn't check if map is empty if it's null
    - base: remove extra checks
    - Don't cleanup overlay mapping for non-theme apps
    - appops: enforce appop for bluetooth disabled action
    - About Resurrection: devcard layout - fix FC devcard on lanscape mode
    - settings: FC on quick settings editor on tablets without a vibrator
    - Add a HAF access permission
    - Fix layout recreation check
    - CameraTile: Launch default gallery app when long pressing active camera tile
    - SystemUI: prevent NPE on clear recents double press
    - MtpDatabase JNI: Fixed a memory-leak in getObjectPropertyValue().
    - Correct stride for drawing to cached glyph bitmap
    - Use alpha channel instead of red in drawCachedGlyphBitmap
    - Temporarily hide lock screen unlock targets if opening a widget
    - fw: media: Handle NPE due to threading race
    - FW: LS Notification: fix FC when an expanded notification gets reposted without bigContentView
    - fix derp on INotificationListener
    - WallpaperCropper: do not display null bitmaps
    - Make theme change broadcast a protected broadcast.
    - Reduce memory leaks by removing all views.
    - appops: do not prune apps that are not present
    - apn: national roaming for ONO (Spain)
    - fix more keyguard derp
    - Mms: Clear notifications and mark messages read in certain situations
    - galaxys2-common: fix front cam video recording
    - Recovery - Version 6.0.4.9
    - included all cm-11.0 m7 updates
    - Check out the source activities for more details https://github.com/ResurrectionRemix
    # NOTE:
    - This is the final release of Resurrection Remix android kitkat series.I ll catch you guys on next android version A.K.A 4.5 or 5.0 . See you soon .Thank you !
    westcrip
    ENJOY!
    Installazione:
    1.- Bisogna avere installato una qualsiasi ROM KK (tipo CM11) o stock 4.2.2 ma NON una stock 4.1.2
    2.- Scaricate l' ultima versione della ROM
    3.- Scaricate le Gapps
    4.- Entrate in CWM recovery
    4a.- Raccomandato un nandroid backup
    5.- Full Wipe (cioè wipe data, chache, dalvik)
    6.- Flashare la ROM
    7.- Flashare Gapps
    8.- Reboot
    9.- Enjoy!
    Update:
    1.- Scaricate l' ultima versione della ROM
    1a.- Scaricare le ultime Gapps, qualora ci siano
    2.- Entrare in recovery
    3.- Flash ROM
    4.- Flash Gapps
    5.- Wipe Chache e Dalvik cache
    6.- Reboot
    7.- Enjoy!
    * Vi consigli, se volete fare una pulizia completa e veloce, di visitare questa discussione:
    [Tool][Aroma]Mega Wipe :-: Super Wipe :-: Factory Reset :-: Simple Wipe
    ** Se avete problemi con la fotocamera, visitate questa discussione:
    [AOSP 4.3+][PORT][APP]Fix App Fotocamera e Lib per tutte le ROM CM/AOSP
    Download:
    RR ROM
    RR Gapps
    Versione Attuale:
    Stato: Stabile
    Rilasciata: 9-06-2014
    Ringraziamenti:
    westcrip
    XDA developers
    CM team
    Kang (AOKP) team
    Omni team
    Slim rom
    cyberboob [For signatures, images]
    BigDenn [For Bootanimations]
    AND OF COURSE TO ALL THE SUPPORTERS, DONATORS AND USERS
    Discussione originale su XDA: GT-I9300 Resurrection Remix® 4.4.2 KitKat
    Ultima modifica di ammanna; 09-06-14 alle 20:39
  2. I seguenti 10 Utenti hanno ringraziato ammanna per il post:
    Billycook (26-05-14),calimerocz (28-05-14),Davidetrk (20-02-14),di3s3l (03-02-14),disasterpices666 (26-03-14),Enr1988 (11-01-14),MrFrancesco961 (04-01-14),pessottino (27-01-14),sAxOnLiNe (22-01-14)
    Modena
    Meizu M2 Note
    RR KitKat 4.4.2 Screenshots
    Ultima modifica di ammanna; 04-01-14 alle 18:28
  5. I seguenti 2 Utenti hanno ringraziato ammanna per il post:
    disasterpices666 (26-03-14),sAxOnLiNe (22-01-14)
  6. #3
    Modena
    Meizu M2 Note
    mio 2
    in costruzione
    Prova
    Ultima modifica di ammanna; 10-01-14 alle 22:17
  7. #4
    ......in riva al mare
    GalaxyS2-GalaxyS3-GalaxyS5
    aggiungo a caffè point
  8. Il seguente Utente ha ringraziato dieguccio per il post:
    ammanna (04-01-14)
  9. #5
    Nov 2013
    sulla ferrovia
    samsung s3 e note3
    Ringraziato 58 volte in 39 Posts
    qualche bug noto?
  10. #6
    Modena
    Meizu M2 Note
    Quote Originariamente inviato da Furetto56 Visualizza il messaggio
    qualche bug noto?
    io di bug fastidiosi non ne ho riscontrati comunque probabilmente gli stessi della CM
  11. #7
    Nov 2013
    sulla ferrovia
    samsung s3 e note3
    Room aggiornata!
  12. #8
    Modena
    Meizu M2 Note
    Room aggiornata!
    Tranquillo, entro stasera aggiorno anche il primo post; )
    Ultima modifica di ammanna; 10-01-14 alle 08:56
  13. Il seguente Utente ha ringraziato ammanna per il post:
  14. #9
    Modena
    Meizu M2 Note
    Oggi ho, un problema con la modifica di ogni mio post non so se solo io oppure colpa del server quindi di seguito trovate gli aggiornamenti della ROM.
    Ovviamente quando sarà possibile modificherò anche il primo post.
    Changelog dell' ultima versione rilasciata ieri:
    # Resurrection Remix KitKat 4.4.2 Experimental - 20140109 # Basic
    -non intrusive incall ui from omni rom
    -Add master switch to disable Halo
    -Added Halo app
    -enabled multiuser for n7100
    -QuickRecord Tile from slimkat
    -Add touch feedback to the clear all recents button
    -Make the lock screen camera widget configurable
    -Fix multi-user issues
    -Forward port cm11 Status Bar interface
    -SystemUI: Allow theming battery via theme chooser
    -Settings: Use solid actionbar
    -settings: Remove ZRAM settings
    -Support the signed-builds FOTA updater, too
    -improved camera fixed issues
    -improved Performance
    -Port over improvements from Chronus
    -updated Resurrection Remix wallpapers to v5.0
    -basic source updates and improvements
    Il link per il download è lo stesso che trovate nel primo post
    Guida update se state già utilizzando la RR 4.4.2:
    0.- Entrare in recovery
    1.- Wipe cache
    2.- Wipe dalvik cache
    3.- flashare la RR
    4.- flashare le gapps
    5.- reboot
    guida installazione:
    1.- Wipe data / factory reset (necessario solo se provenite da rom stock , RR 4.2.x o da un altra ROM)
    2.- Flashare la RR
    3.- Flashare le gapps
    4.- Wipe Dalvik Cache
    5.- Wipe Cache Partition
    6.- Reboot
    Vi consiglio se volete fare una pulizia completa e veloce di visitare questa discussione: [Tool][Aroma]Mega Wipe :-: Super Wipe :-: Factory Reset :-: Simple Wipe
    Ultima modifica di ammanna; 11-01-14 alle 15:00
  15. Il seguente Utente ha ringraziato ammanna per il post:
  16. #10
    Modena
    Meizu M2 Note
    Quote Originariamente inviato da ammanna Visualizza il messaggio
    -Added Halo app
    1.- Wipe cache
    3.- flashare la RR
    5.- reboot
    2.- Flashare la RR
    6.- Reboot
    OOOK, ci sono riuscito, primo post aggiornato
  17. Il seguente Utente ha ringraziato ammanna per il post:
