Utente del mese: bluemask con ben 31 Thanks ricevuti nell'ultimo mese
[ROM] PhoeniX ROM [Fast | OTA | Unique | Stable]
    Androidiano VIP L'avatar di pegliese93
    Liguria, Genova
    Ringraziato 671 volte in 442 Posts
    Cool
    Benvenuti sul Thread per Samsung Galaxy S4 I9500, tutti i crediti vanno a lui
    Thread sviluppatore: XDA
    Based on the lastest stock firmware: Android 4.2.2 XWUBMG5 (build date: 18/07/2013)
    Stock Kernel XWUBMG5
    Fully Deodexed
    Added latest BusyBox
    Added latest SuperSU+Bin files
    Added Flashplayer support (Note: Flash doesn't work on stock browser, use dolphin or something.)
    Updated all stock apps to their latest version(Gmail, Google search, Google Maps ,Play store etc.)
    Removed debug info - system is faster by 30% from stock!
    Unique PhoeniX bootanimation & shutdown animation - Huge thank to the artist anbech
    Mods:
    • Call Recorder
    • Hacked Stock Email App
    • CRT Animation enabled
    • Sysro & sysrw support
    • Enabled touchwiz wallpaper scrolling
    • Disabled scrolling cache
    • Phone with no increasing ringtone
    • All supported languages enabled
    • All supported languages for Samsung Keyboard enabled
    • Enabled init.d scripts
    • Shutter Sound menu Enabled to stock camera
    • Big APN list
    • Enable sub Symbols on Stock Samsung keyboard
    • Added exit menu to stock web browser
    • Dialer search matches numbers in contacts and call logs along with contacts
    • data/app enabled
    • NFC Hack - You can use your NFC while the screen is off, and at lockscreen.
    • 4 ways to reboot menu - Extended power menu
    • Enable call button in contact list
    • Disabled Converting Effect Between SMS MMS
    • Automatic SMS encoding (Arabic and other utf-8 encoding support)
    • Automatic efs backup when flashing the rom.
    • Multiwindow Manager by bjbinc
    • Pie Control
    • Exclusive! Only to PhoeniX ROM!:
      * New Amazing Wallpapers in Wallpaper Chooser Wallpapers! Beautiful Wallpapers! How to use? Click on Menu-> Set Wallpaper-> Home/Lock/Both-> Wallpaper Picker/chooser-> Select your Wallpaper!
      * New Settings app: Huge thank to ficeto!
      PhoeniX Settings App includes the following features:
      Samsung Secret Codes
      Fast Dormancy
      Faster Fix GPS
      CSC Select
      CPU Spy Plus
      Idle Wifi Time Manager
      Logcat
      OS Monitor
      PhoeniX OTA Center - now you can update the rom without plugin into the computer!
      The downloads will be save on the internel SD card(if you use my memory script so it will be saved in the externel sd card) undr the folder OTA updates.
      Reboot options - Normal, Recovery, Download.
      And more coming soon
    Tweaks:
    Kernel Tweaks
    Zipalign
    Build prop tweaks
    PhoeniX Special Tweaks:
    - SD External / Internal tweak
    - Smoothness tweak
    - Better Scrolling tweak
    - And more
    Removed from the rom:
    Bloatware - can be found here or here . - around 550MB of bloatware.
    • If you come from another rom, it is important to make Super Clean(From mike1986.[Thank you!]) - It will delete your internel sd card! make sure you have a backup.
    • If you upgrade this rom from previous version just make full wipe(when required).
    • Make efs backup(If you have one already, don't make)
    • Install rom - Choose options in the Aroma installer(Options are coming soon, we hae to wait for aroma installer)
    • Reboot(Do not flash any mods before 1st boot)
    • Enjoy!
    Ultima modifica di pegliese93; 02-08-13 alle 01:18
    Se ti sono stato d'aiuto un Thanks è sempre gradito
    Liguria, Genova
    Riservato
    Liguria, Genova
    Riservato 2
    thread chiuso
