Pagina 10 di 86 primaprima ... 891011122060 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 855
[KERNEL][AOSP/TW] KTweaker
  1. #91
    Senior Droid L'avatar di kenzolo
    Galaxy s3 Blue
    Ringraziato 236 volte in 116 Posts
    Nuova versione disponibile
    AOSP JELLYBEAN 4.2.2 VERSION:
    http://goo.gl/HttgW
    Touchwiz JELLYBEAN 4.2.2 VERSION:
    http://goo.gl/eq22p
    Change Log 7.11.2013
    1. cpufreq:ktoonservativeq: Make lockout cores tunable a 3 way toggle, 0 = normal hotplug, 1 = locked ON full time, 2 = locked OFF full time
    2. AOSP: Merged in MFA
    3. TW: merged in MFD from I9505G
    4. mm: slub: Try setting slub_max_order to zero
    5. mm: slub: Memory allocated by kstrdup should be freed
    6. Async I/O latency to a ssd greatly increased, 34% gain (Creds: kleikamp)
    7. KTweaker: sched: Make GENTLE_FAIR_SLEEPERS configurable thru "Extras" screen
  2. Il seguente Utente ha ringraziato kenzolo per il post:
    Allen35 (12-07-13)
    Galaxy s3 Blue
    nuova versione disponibile
    Versione per ROM Touchwiz JELLYBEAN 4.2.2
    15.07.2013
    clicca qui
    Versione per ROM AOSP/AOKP 4.2.2
    15.07.2013
    clicca qui
    Changelog
    1. 2 New KTweaker items: "Charging Min Mhz" and "Charging Max Mhz" options (Under "Extras" screen in Ktweaker). Use these to set your Min/Max Mhz while charging
    2. Improved CPU sync for ktoonservativeq
    3. New ktoonservativeq tunable: Added disable_hotplugging_chrg option. 0 = normal hotplugging while charging, 1 = disable hotplugging while charging so all cores are on full-time.
    4. Linux 3.4.53
    5. misc: uidstat: avoid create_stat() race and blockage
    6. block: row: change hrtimer_cancel to hrtimer_try_to_cancel
    7. Many updates to Interactive governor for CM
    8. Merged Interactive governor from CM to TW version
    9. New KTweaker item: "Force Samsung MTP (requires a reboot to take effect first time)". This will force the Samsung version of MTP. *****USE THIS OPTION ONLY IF YOU ARE RUNNING A TOUCHWIZ ROM. DO NOT USE ON AOSP OR GOOGLE EDITION ROMS
    10. cpufreq: RemoveD the 1134 lower ceiling from TW ROMs
  5. I seguenti 2 Utenti hanno ringraziato kenzolo per il post:
    Anna (16-07-13),terzo33 (16-07-13)
  6. #93
    Androidiano VIP L'avatar di terzo33
    Palermo
    Galaxy S4
    Ringraziato 342 volte in 227 Posts
    ragazzi ma a che serve il fix permission? se non lo faccio e flasho questo kernel cosa succede?
    DEVICE: Samsung Galaxy S4 16GB White Frost
    ROM: BoBCaTROM v.13
    KERNEL: Jeboo
    MODEM: Stock MJ7
    OPERATORE: Vodafone
    EXT MEMORY: Samsung MicroSDHC 32gb Classe 10 UHS-I
  7. #94
    Galaxy s3 Blue
    Quote Originariamente inviato da terzo33 Visualizza il messaggio
    puoi anche evitarlo,serve nel caso il sistema non riesca ad attribuire i giusti permessi ai file.
    Per il momento non ho mai riscontrato problemi facendo i classici wipe cache/dalvik
  8. #95
    Questo kernel è flashabile sulla rom GE di jamal? Ho provato a flashare la versione AOSP ovviamente ma il gs4 non si accendeva più e ho dovuto riflashare la versione kernel di google...Vorrei montarlo perchè a mio avviso è molto più personalizzabile e performante...
  9. #96
    Androidiano L'avatar di ItsMeLeo
    Xperia X10, Galaxy S4, Note 4
    Ringraziato 43 volte in 38 Posts
    Devi flashare la versione TW e non la AOSP.
    Comunque io preferisco il kernel di ausdim
    Inviato dal mio GT-I9505 Google Edition 4.3
    Vecchi telefoni:
    Xperia X10i, Samsung Galaxy S4, Galaxy Note 4, Galaxy Note 9
    Telefono attuale:
    Samsung Galaxy Note 9
    Rom: Stock 9.0
    Kernel: Stock
    Mio canale Youtube: www.youtube.com/c/ItsMeLeo
  10. #97
    Androidiano VIP L'avatar di Gerardo87
    Castelnuovo B.ga
    Samsung Galaxy s4 GT-I9505
    Ringraziato 351 volte in 271 Posts
    Come si comporta questo kernel per un full wipe o un nandroid??? Problemi di sorta?
    SAMSUNG GALAXY S4 GT-I9505 No-Brand
    Primary Rom: [4.4.2] Imperium Rom v11
    Kernel: Alucard-KK4.4-TW-INTL-04.09.2014
    Modem: XXUGNH7
    Bootloader: Vecchio(MGA)
    Google Nexus 7 (2012) Wi-fi
    Primary Rom: [4.4.4] Cyano 11.0 Ultima nightly
    Kernel: M-Kernel a69
  11. #98
    Ringraziato 196 volte in 170 Posts
    Ragazzi ma quale governator consigliate di installare.?
  12. #99
    Galaxy s3 Blue
    Quote Originariamente inviato da mitic Visualizza il messaggio
    i governor non si devono installare..
    in ogni caso ktconservative
  13. #100
    Galaxy s3 Blue
    Quote Originariamente inviato da Gerardo87 Visualizza il messaggio
    non ho capito cosa intendi?
    non ho alcun problema a fare un full wipe o un nandroid...ma piu' che dal kernel dipende dalla recovery
  14. Il seguente Utente ha ringraziato kenzolo per il post:
    Gerardo87 (17-07-13)
