Misterx86
ciao blu mi sono permesso di tradurlo in italiano
Seeing as the thread in the development section is being flooded with questions when its meant to be a development research thread and important info is getting lost amongst all the questions, I thought Id create a Q&A thread for all Knox bootloader 0x1 related questions so that we can try and keep the development thread just for research and testing.
Please feel free to ask any question here and i'll do my best to answer it but hopefully some of the other members who know a bit more will also join in and help answer some of the questions people have.
What we know so far (I think!)
1. Upgrading to newer Samsung firmware will upgrade the bootloader to knox bootloader. this will give an additional 2 lines in download mode about knox status.
2. If the Knox warranty void line says 0x1 then you cannot use knox firmware as your device has been flagged as insecure.
3. If the knox warranty line says 0x0 knox will work.
4. with the new knox bootloader root will work, however rooting will trip the knox flag. thanks @
DjeMBeY for correcting this point
5. If you try to downgrade to earlier firmware / bootloader it will set the knox flag to 0x1 i.e. void.
6. once the knox flag gets set to 0x1 there is no way to set it back (that anyone has found yet anyway!)
7. some newer 4.2.2 software that's supplied with the knox bootloader has been repacked by devs to not use the new bootloader and it all works fine you can still keep up to date.
8. I've seen people trying the test build of 4.3 touchwiz without the new knox bootloader sound and wifi does not work.
9. There seems to be a big question mark as to weather Samsung will allow hardware repairs under warranty with the knox 0x1 flag
10. only seems to affect GT-i9505 at the moment!
11. 4.3 touchwiz leak rom will not work with custom kernels at the moment.
12. 4.3 touchwiz leak rom will not work with the old knox-free bootloader
13. Software affected thanks to @
DjeMBeY
What knox bootloader looks like in download mode . In this picture Knox warranty is in tact as the flag is 0x0:
I hope this answers some questions, anyone feel free to correct me and i'll try to keep this OP updated with info as people supply it / discover it.
TRADUZIONE
Visto che il thread nella sezione di sviluppo è stato inondato di domande quando il suo vuole essere un filo di ricerca di sviluppo e di informazioni importante è perdersi tra tutte le domande , ho pensato Id creare un Q & A filo per tutti Knox bootloader 0x1 domande correlate in modo che si può cercare di mantenere il filo sviluppo solo per la ricerca e la sperimentazione .
Per favore, sentitevi liberi di fare qualsiasi domanda qui e farò del mio meglio per rispondere , ma si spera alcuni degli altri membri che conoscono un po 'di più sarà anche partecipare e aiutare a rispondere ad alcune delle domande che le persone hanno.
Quello che sappiamo fino ad ora (credo ! )
1 . L'aggiornamento al firmware più recente Samsung aggiornerà il bootloader di knox bootloader . questo darà un ulteriore 2 linee in modalità download sullo stato Knox.
2 . Se la linea di garanzia vuoto Knox dice 0x1 quindi non è possibile utilizzare il firmware Knox come il dispositivo è stato contrassegnato come non sicuro .
3 . Se la linea di garanzia Knox dice 0x0 knox funzionerà.
4 . con il nuovo bootloader knox il root funzionerà , tuttavia il root farà scattare il flag Knox. grazie [ MENZIONE = 4398524 ] DjeMBeY [ / MENZIONE ] per la correzione di questo punto
5 . Se si tenta di effettuare il downgrade a precedenti firmware / bootloader sarà impostato il flag Knox per 0x1 cioè nullo .
6 . una volta che il flag Knox viene impostato su 0x1 non c'è modo di impostare di nuovo ( non si è trovato il modo! )
7 . alcuni software più recente 4.2.2 che è fornito con il bootloader Knox sia stato ripiegato da sviluppatori di non utilizzare il nuovo bootloader e tutto funziona bene è ancora possibile mantenere aggiornati.
8 . Ho visto persone che cercano il test build di 4,3 TouchWiz senza il suono nuovo bootloader Knox e wifi non funziona.
9 . Sembra che ci sia un grande punto interrogativo da tempo Samsung permetterà riparazioni hardware in garanzia con lil flag Knox 0x1
10 . sembra influenzare solo il GT - i9505 in questo momento !
11 . 4,3 TouchWiz perdita rom non funziona con kernel personalizzati al momento.
12 . 4,3 TouchWiz perdita rom non funziona con il vecchio bootloader knox - libero
13 . Software interessato grazie a [ MENZIONE = 4398524 ] DjeMBeY [ / MENZIONE ]
questo è quello che esce in modalità download . In questa immagine la garanzia e il Knox sono intatte come il flag è 0x0 :
