Pagina 349 di 550 primaprima ... 249299339347348349350351359399449 ... ultimoultimo
Visualizzazione dei risultati da 3,481 a 3,490 su 5495
[ROM][9.0][SE1][G950/55F-FD] ☼ CarHDRom V.26 ☼ [23/05/19][THEMES]
  1. #3481
    lissone(MI)
    HD Rom by Carotix
    Fra sempre al top
    CarHDRom V.16 CRED
    #ROM
    -Deodexed
    -Debloated
    -Deknoxed
    -Rooted with SuperSU or Magisk V16.2
    -NX-R8 Kernel for G950F/FD/N and G955F/FD/N
    -Init.D Support
    -New Bootloders CRED
    -New Modems CRE3
    -Rom Control 2
    -MultiCSC
    -Floating Messages
    -MultiUsers
    -LTE Only
    -Netflix Fixed
    -Features
    -Tweaks
    -App Lock
    -SamsungVideoList
    -Live Drawing
    -AdAway
    -Data Usage to the center
    -Clock and Date Bigger in Pulldown
    -Anologic Clock on top in Recents
    -30 Extra Fonts
    -Deleted Safe Volume Warning
    -Navigation Bar Smaller
    -Mods center clock in OTA/MODS ROM
    -Fixed Fingerprint credits to KiLL-SwitCH and @yash92duster
    -Replaced CarHDRom OTA instead of help online in Dashboard Settings credits to @Edzamber
    -All Apps Updated
    #CarHDROM Control
    -Battery Bar In Pulldown
    -Open with "Once/Always"
    -USB Plug/Unplug Disable WakeUp
    -Torch Light on Volume Up when screen off
    -10way Reboot Menu
    -Outdoor Mode
    -Virtual Buttons in Statusbar
    -Background Settings in Statusbar
    -Background Settings in Navigation Bar
    -Background Settings in Recents
    -Background Settings in AOD
    -Background Settings in Phone
    -Background Settings in Pulldown
    -Background Settings in Power Menu
    -Lockscreen Settings Time Display
    -Lockscreen Rotate
    -Bootanimations
    -Lockscreen Settings Widget
    -Skip Tracks on Volume
    -Bixby Button Settings
    -Fingerprint working after reboot credits to @Albe96
    Installazione:
    -Flasha solo la rom sopra alla tua oreo rom
    -Full Wipe
    -Seleziona il nuovo Bootloader and Modem per il tuo modello di device (questo solo la prima volta)
    Attenzione: una volta flashato il nuovo bootloader , non puoi mettere una rom precedente
    Download V.16
    ricorda di mettere il tuo ringraziamento in questo post
    Aroma Theme V.16 Online
    -Everything Updated like V.15.4 with new mods V.16 Rom
    Inviato dal mio SM-G955F utilizzando Tapatalk
  2. Il seguente Utente ha ringraziato yuri76 per il post:
    carotix (12-06-18)
    Androidiano VIP L'avatar di hobin
    Feb 2011
    GalaxyS10+G975F_HD_Rom_Carotix
    Ringraziato 229 volte in 193 Posts
    Non capisco quindi devo riscaricare di nuovo la 15.4? chiedo questo perchè ho visto che in ota non vedo la v16
  5. #3483
    lissone(MI)
    HD Rom by Carotix
    Quote Originariamente inviato da hobin Visualizza il messaggio
    Dove hai visto che è online? Fra di solito lo scrive alla fine del post
  6. #3484
    Ringraziato 53 volte in 46 Posts
    Che pizza era meglio mega per scaricare
    Il sito che usi non va Non trova il mirror
  7. #3485
    Russi - RA
    Ringraziato 12,214 volte in 4,776 Posts
    quello che ho scritto li è per dire che è tutto aggiornato come nella v.15.4 e in aggiunta ci sono le nuove mod
    Aroma theme v.16 lo trovi nel solito posto e anche nelle impostazioni della nuova rom
    Quote Originariamente inviato da leonardomarra76 Visualizza il messaggio
    a me li trova
  8. I seguenti 2 Utenti hanno ringraziato carotix per il post:
    hobin (12-06-18),yuri76 (12-06-18)
  9. #3486
    Russi - RA
    per sicurezza ... mettete la twrp v3.2.1 se non l'avete già
    poi magari scegliete supersu la prima volta ... per rifare gli stessi passaggi che ho fatto io
    edit: ora c'è anche il modo di saltare i 7 giorni se si flasha un firmware col nuovo bootloader
    Ultima modifica di carotix; 12-06-18 alle 14:44
  10. Il seguente Utente ha ringraziato carotix per il post:
    yuri76 (12-06-18)
  11. #3487
    lissone(MI)
    HD Rom by Carotix
    fra non riesco a fare la scrittura della memoria esterna con TB mi dice spazio insufficente.se flasho la rom si toglie il file?
  12. #3488
    Feb 2011
    Quote Originariamente inviato da yuri76 Visualizza il messaggio
    Anche a me, Praticamente quando si clicca su rileva trova solo la SD esterna
  13. #3489
    lissone(MI)
    HD Rom by Carotix
    Semmai ti trova solo quella interna
  14. #3490
    Feb 2011
    Sì esatto scusa, prima avendo la cartella su SD esterna cliccando su rileva intero dispositivo mi dava il percorso mnt
