Circa la Resurrection Remix ROM
Resurrection Remix č stata basata su CM, slim, omni e originali build Remix ROM, questo crea una fantastica combinazione di performance, personalizzazione e la maggior parte di nuove funzionalitą, portate direttamente sul tuo dispositivo.
Alcune cose nelle precedenti versioni sono state incluse in mods, sono incluse di default nella ROM quindi, per favore divertitevi!
Resurrection Remix
-Navigation Bar
-Enable/Disable Navbar
-Navbar Ring Switch
-Navbar Ring Targets
-Navbar Button Customization
-Navbar Dimensions(Potrait & Landscape)
-Statusbar
-Brightness Slider
-Enable/Disable Show Notification Count
-SuperUser Indicator Switch
-Carrier Label
-Carrier Label Switch
-Carrier label Colour
-Quick PullDown Switch
-Smart Pulldown Switch
-Clock Customizations
-Time & date
-Clock Colour
-Day & date Toogle
-Center Clock/Right Clock Choice
-Battery
-Battery Bar customization
-Battery Icon Customization(circle/landscape/Potrait and more)
-Battery % Text
-Network Traffic Indicator
-Theme Chooser
-RR exclusive PITCH BLACK THEME
-Animations
-Toast Animations
-ListView Animations
-System Animations
-Gestures
-Gestures Anywhere Feature
-App Circle Bar
-Choose apps in App circle
-Trigger Width
-Trigger Hieght
-Trigger Position
-Recents Panel
-Clear All button Switch
-Clear All Tasks Switch
-Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
-Cclock Widget
-CLock And Alarm Customizations
-Weather Panel Customizations
-Calender Events
-LockScreen
-Lockscreen Shortcuts
-Choose upto 5 Shortcuts
-100+ Icons for Shortcuts
-Quick Slider Shortcuts
-Notification Drawer
-Weather Display Switch
-Quick Settings
-Choice to Add 20+ Tiles
-Enable 2/3/4 Tiles per Row
-Enable Disable Birghtness Slider in Notification Panel
-Advanced Location Settings Switch(Choose Battery saving/Device Only/High Accuracy Directly in Notification Panel)
-LongPress Toogles to Enter Settings
-Buttons
-Backlight Timer
-Backlight Strength
-Navigation Bar left/Right handed mode Switch
-Power Menu
-Power Menu End Calls Switch
-Home Button(For devices with HW keys Only)
-Home Button Wake Up
-Home Button answer call
-Long Press Actions
-Double Tap Actions
-Back Button(For devices with HW keys Only)
-Wake Up device Switch
-Menu Button(For devices with HW keys Only)
-Wake Up Device Switch
-Short Press Actions
-Long Press Actions
-Search Button(For devices with HW keys Only)
-Wake Up Device
-Short Press Action
-Long Press Action
-Volume Buttons
-Wake Up Device
-Playback Control
-Keyboard Cursor Control
-Swap Buttons on Landscape mode
-Perfomance Profiles
-LCD Density
-Expanded Desktop Mode
-All New CM Audio FX App
-Heads Up Customizations
-OverAll Smoothness Improvements
-Quick Unlock
-Optimizations to Improve Battery
-ALL cm12 Features
-AND MUCH MUCH MORE
Istruzioni per l'installazione:
- Scarica l'ultima build
- Scarica le Gapps
- Fare un nandroid backup (č solo per sicurezza, č facoltativo)
Raccomandato - Full wipe e factory reset
- Flasha la ROM utilizzando la ClockworkMod recovery
- Flasha le GApps
- Riavvia
- Divertiti!
Istruzioni per aggiornare:
- Scarica l'ultima build della Resurrection Remix ROM
- Fare un nandroid backup (facoltativo)
- Flasha utillizzando la recovery
- Flasha le GApps
- Wipe cache
- Wipe dalvik cache
- Riavvia
- Divertiti!
Download:
ROM:
https://www.androidfilehost.com/?w=files&flid=22675
GApps:
http://forum.xda-developers.com/andr...ition-t2943330
Changelog:
https://gist.github.com/westcripp/8874051
