[ROM]GingerDX pro v17
    Ringraziato 33 volte in 33 Posts
    Requirements:
    - Rooted
    - ClockworkMod Recovery
    - Latest kernel and latest baseband xxx015
    We are not responsible if this ROM bricks your device.
    Features
    Android 2.3.7
    Superuser
    Busybox
    Apps2SD
    Super HQ Camera
    2D performance
    Best 3D performance
    Additional Features
    Ginger DX Settings in CM Menu
    Fake xLOUD
    Bravia Engine
    Sense Ring Style
    Sense Wallpaper
    Sense Lock Screen
    questa e una rom abbastanza difficilotta per i sunyericcson xperia x10 mini pro mi raccomando usatela a vosto riskio e pericolo XD
    GingerDX pro v17 (97,15 MB) MD5: D145BDE077399DF06F220F7B8D31A1A3
    Multiupload.com - upload your files to multiple file hosting sites!
    New CMParts.apk with more features(566.9 KB) MD5: E9AD436FCE68F34C96372669EEC9B31F Multiupload.com - upload your files to multiple file hosting sites!
    -THANKS to madbulls - for v17 so flash it
    Modules GingerDX fixed (338.06 KB) MD5:0672FFFDD9B841412D96000B7B41B280 Multiupload.com - upload your files to multiple file hosting sites!
    -flash this modules if you use stock kernel THANKS to slade87
    Optional for default keyboard MD5:E2582E8AE6A107CA4EE26579ABDFF182 Multiupload.com - upload your files to multiple file hosting sites!
    - with this you'll get rid of language bar on default keyboard
    Installation
    Download GDX_XXX.zip to your sdcard storage on your Xperia X10 Mini Pro
    Boot into Recovery through whatever method you choose
    Back up your existing installation
    Use the volume keys to select Factory Reset and push home button
    Select Install Zip from SD Card
    Find the GDX_XXX.zip file you downloaded earlier
    Scroll through and hit Yes, install GDX_XXX.zip
    Wait for the installation to finish
    Select Reboot
    After initial reboot, reboot a second time and you're all set
    XD mi raccomando XD
