[ROM][ICS][.13][Arc/S] TrueSmoothV1.4 - Extreme Fast |Smooth| Stable | All in One - xda-developers
Vi presento una delle migliori rom ICS su base .13 (l'ultimo fw disponibile) in circolazione. Una rom senza fronzoli, inattaccabile, velocissima e senza perdita delle prestazioni a lungo termine. Graficamente non è la più bella ma, comunque, può essere personalizzata con le varie mod che trovate in giro. La rom non viene più sviluppata, non ce ne bisogno, vi consiglio di accoppiarla con il kernel LuPuS14
Features:
Changelog:- Based on ICS 4.1.B.1.13 ROM
- Extreme fast, smooth, and stable
- Suit for both gaming and multitask
- Switch mod easily with the installer
- Add support for HDMI
- Remove bloat-ware
- Tweaked for increasing performance
- AROMA installer with much customizable
- Change Mode in the installer help you delete mod and revert back to official version. No need to clean it yourself.
- Choice for camera (no mod, cybershot v6.7.2 or cybershot v7.1.2)
- Choice for sound enhancement (no mod or ACID Audio Engine v4, v5, v7)
- Choice for on-screen buttons size (22, 29, 35 dip or none)
- Choice for style of notification bar (slide, 2 version of tab or official)
- Choice for boot animation
- Choice for themes (Xperia Z or original Arc theme)
- Choice between many popular launchers
- Choise between SuperSU or Superuser
- And choice for many extra stuffs
v1.4:
- AROMA installer REMEMBER setup configuration
- LED fix (optional)
- Fix FC when edit image in Sony Album
- Fix Network Mode toggle not available in QuickPanel Setting of Slide Style
- All google apps is optional to install
- All Sony apps is optional to install (clock, calculator, album...)
- Sound mod only install WALKMAN (no Album or Video apps)
- Add new slide style notification bar v2
- Update apps to latest version
v1.3:
- Choices between SuperSU and Superuser
- Add Xperia S apps (optional) (thanks sohrab1985)
- Add new tab notification bar with more toggles (optional) (thanks EAGLEBOOY)
- Add AC!D v4 (optional)
- Add AC!D v5 (optional)
- Add Xperia V Media apps (optional)
- Add Social Engine (optional)
- Add Rescan Media app (optional)
- Delete outdated galery app from new installation
NOTICE: the installer in v1.3 considerably increase in size due to I add a lot more of customization. After installation, you still get a light, fast, smooth ROM as always
v1.2:
- All mods are uninstallable by using AROMA installer. You can use v1.2 to uninstall mod in previous version of TrueSmooth
- Add "Official Notification Bar" in the installer in case you dislike mod at all ^^
- Add cybershot v7.1.2 as an option in the installer (thanks jader)
- Fix 2G/3G toggle in Tab Notification Bar (thanks is0l4ted)
- Choice for camera mod in the installer
- Choice for sound enhancement mod in the installer
- Clean up the installer for more choice but less size
v1.1:
- Change to Cyber-shot mod v6.7.2 to make camera working
v1.0:
- Initial release
Altre raccomandazioni:
screenshot:Recommendation:
- Kernel: lupus v9. There's a newer version - lupus v10 but I haven't tried yet, because I'm just satisfied with current setup on my phone. I heard that lupus v10 even give you more free RAM
- Governor/Scheduler: ondemandx/sio
- Extra apps: Link2SD (config Auto-link) and Advanced Task Killer (config Auto Kill level is Crazy and frequency is When screen off). These apps are just essential when you want to install a lot of apps and games
- As my experience, using Xperia V Engine sound mod seem to boost overall system performance. Try and see if you feel like me
- Install ONLY apps you need to use frequently or essential to use because a lot of apps runs their service which slow down your phone.
- Disable startup of apps by any start up manager (I'm using ES Task Manager). You must figure out by yourself which app need to start up to run normally (email, alarm...) or sure to disable such as games (there's no reason to start up games at boot)
Installation Mode Behavior
New Mode: it swipe data and install entire .13 system core and your selected mods.
Change Mode: it clean up old mod and change to new selected one. It's useful when you want to test mod or just like to use bare bone ROM.
Installation instruction:
- Copy ROM setup file to SD card
- Enter CWM and choose the setup file
- Follow instruction in AROMA installer, customize the ROM as you like and click Install. NOTICE: in Extra section, unchecked item means you don't like it to install with this ROM, so it will be removed if it's already existed (in case you re-install the ROM)
Un grazie allo sviluppatore fearless139
LinkBack URL
About LinkBacks
Rispondi quotando
Ultima modifica di tetea; 08-06-13 alle
