Pagina 1 di 2 12 ultimoultimo
[Kernel] Xperia SSpeed Kernel
    Androidiano VIP L'avatar di GEKTHEBOSS
    LG Google Nexus 4
    Ringraziato 1,515 volte in 829 Posts
    Caratteristiche:
    • Pre-rootato
    • Recovery
    • Tweaks per performance
    • Durata batteria migliore
    • Governers Cpu Extra: Pegasusq
    Download:
    Kernel: download
    Thread Originale: xda
    Installazione:
    Solo per BootLoader Sbloccati! (guida presente!)
    • Riavvia in Recovery
    • install zip from sdcard => Scegli il kernel scaricato
    • Riavvia
    NOTA:
    The extra governors aren't optimized for our new Xperia 2012 devices yet. So lag or reboots can occur
    The extra I/O schedulars are also not edited for Xperia 2012 devices so they can also cause lag.
    Overclocking is a risk, be aware it can harm your device if you do things wrong. But dont worry, 1.15Ghz won't harm your device
    Ultima modifica di GEKTHEBOSS; 27-08-12 alle 11:20
  2. Il seguente Utente ha ringraziato GEKTHEBOSS per il post:
    marce (27-08-12)
    LG Google Nexus 4
    Changelog:
    Xperia SSpeed kernel v1 [18/06] ==
    • 1.1GHz OC
    • pre-rooted
    Xperia SSpeed kernel v2 [19/06] ==
    • 1.2 GHz
    • Changed frequency's from 600Mhz, 800Mhz, 1Ghz to 700Mhz, 950Mhz, 1.2Ghz
    • Added governors: Interactive, Smartass, Minmax, Smartassv2
    Xperia SSpeed kernel v3 [19/06] ==
    • 1.15GHz OC
    • Added Governors: Scary
    • Added I/O schedulars: SIO & VR
    • Added extra CPU frequency's
    Xperia SSpeed kernel v4 [21/06] ==
    • Added NTFS support
    • Updated Jhash to v3
    • Added added XZ compression and decompression
    • bumped VM_MAX_READAHEAD to 1024
    • Added JRCU & SQLB memory Allocator
    • Disabled CIFS for better battery performance
    • More small changes
    Xperia SSpeed kernel v4 [08/07] ==
    • Started all over from kernel Sources
    • only made some small changes
  5. #3
    LG Google Nexus 4
    Riservato per il futuro
  6. #4
    Senior Droid L'avatar di nicomarma
    Brescia
    Ringraziato 73 volte in 56 Posts
    Quote Originariamente inviato da GEKTHEBOSS Visualizza il messaggio
    Changelog:
    • 1.1GHz OC
    • pre-rooted
    • 1.2 GHz
    • 1.15GHz OC
    su xda è presente la 6.1.. [Kernel][Xperia U]Xperia SSpeed kernel v6.1|Fast, stable, smooth, recovery[31/07] - xda-developers
  7. #5
    LG Google Nexus 4
    Quote Originariamente inviato da nicomarma Visualizza il messaggio
    Infatti nel link download ce la 6.1
  8. #6
    Brescia
    sorry, ho guardato solo il changelog..
  9. #7
    Androidiano L'avatar di DogmaX
    Ringraziato 26 volte in 19 Posts
    Non mi ricordo l'ultimo kernel che installai, forse non era l'SSpeed, ma quell'altro, cioè questo:
    https://www.androidiani.com/forum/so...-cwm-root.html
    Che voi sappiate se ora flasho questo potrei avere qualche problema? O il kernel viene proprio sovrascritto come se fosse nuovo?
  10. #8
    LG Google Nexus 4
    Quote Originariamente inviato da DogmaX Visualizza il messaggio
    Perfetto,questo e il secondo passo dopo aver sbloccato e installato quello.
    Non perderai niente e avrai fluidita e batteria migliorate,piu una speciale accensione!
  11. #9
    La speciale accensione è quella dei tre led colorati vero? Già ce l'ho
    Comunque appena posso installo questo kernel... in teoria non dovrebbe cancellarmi nulla perché già flashai il kernel in passato e rimase tutto intatto.
    Vabè per sicurezza farò un backup, anzi aspetto proprio ICS a sto punto, visto che sembra in dirittura d'arrivo, così colgo due piccioni con una fava, backup, rom nuova, kernel nuovo
  12. #10
    LG Google Nexus 4
    No,vedrai Xperia SSpeed al posto di Sony!
    Comunque flashalo senza backup,ics entro inizio scuola in teoria LoL
