Visualizzazione dei risultati da 1 a 10 su 49
[ROM][AOKP] ..::AOKPXperia::. V 2.0 (Bootloader Bloccato)
    Sony Xperia U, LG optimus l9
    Ringraziato 10 volte in 5 Posts
    Lightbulb
    ROM BASATA SU FXP 146, CM9 BY ATIS, AOKP DA CHAMPIONSWINNER, ALCUNI FIX VENGONO DAL CM9 STOCK
    Screenshot_2012-11-04-21-04-36.jpg Screenshot_2012-11-04-22-10-49.jpg Screenshot_2012-11-10-00-20-27.jpg Screenshot_2012-11-10-00-22-41.jpg
    Features
    CWM TOUCH FULLY WORKING
    Alcune applicazioni sono aggiornate
    Alcuni tweaks per migliori prestazioni
    tutte le features da AOKP
    I giochi girano veramente fluidi
    é solo per il bootloader bloccato!
    •Superuser & Busybox preinstallate
    •Deodexed
    •180 Degree rotation
    •Built in performance/init.d configuration (Thanks Kejar & company)
    •CM Launcher/ Power Menu
    •CM Brightness slider
    •Custom color for anything in RC
    •Clock Color/Location: Right, Center, Disable
    •Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
    •Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
    •Nav Bar Trasparente
    •Nav Bar Button Reorder: Back-Home-Search-Menu
    •Nav Bar Color Picker
    •Nav Bar Button Glow Duration: Off, Fast, Slow
    •Nav Bar: Long press to Search button
    •Nav Bar Hide on Lockscreen
    •Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
    •Densità LCD (Careful with this)
    •Menu Button location: Right, Left, both, Remove
    •Menu Button Visability: Always show, Always show Invisible Icons
    •Lockscreen Style: Quad, Octo, Stock
    •Lockscreen SMS customizable shortcut
    •Lockscreen Horizontal Option
    •Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
    •Unlock Sceen with Legacy Menu Icon
    •Volume Key to Wake Screen
    •Volume Key to Skip Tracks
    •Long-press back button to kill process
    •Disable CRT off animation
    •LED pulse settings (time on/off)
    •ICS ringtones/notification sounds
    •Customize carrier text to whatever.
    •Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
    •Facebook contact sync integration (must wipe to get this)
    •Disable Boot animation
    •Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
    •Long press home for recent apps (thanks brucekey)
    Downloads
    Discussione d'origine
    COME INSTALLARE:
    -ANDARE SU CWM
    -FAI UN FULL WIPE
    -INSTALL THE ROM
    -REBOOT
    -GIOISCI!!
    VERSION1.0
    LED FIXED
    WIFI FIXED....thanks to dapaua for the fix
    ADDED ALL TWEAKS FOR AOKP (ACTIVATE WIHT ROM CONTROL)
    UPDATE TO THE LASTED AOKP/CM9 SOURCES
    VERSION 2.0(NON RILASCIATA)
    INIT.D SUPPORT FIXED
    UPDATED TO THE LASTED MILENSTONE/NYGTLY AOKP SOURCES
    MINOR CHANGES
    UPDATE SOME APPS
    ENABLE DUAL CORE SUPPORT
    PIU VELOCE
    VERSION 3.0
    AOP MILENTONE 6.4
    FIXED CAMERA INVERTED
    AGGIORNATO GOOGLE PLAY
    AGGIORNATO SUPERSU
    ROMCONTROL TOTALMENTE TRADOTTO IN SPAGNOLO
    APEX LAUNCHER
    NO MORE DRAIN BATERY
    FRAMEWORK.JAR PEER MIGLIORI PERFORMANCE 2D
    FIXATO MOUNT SD CARD
    SOLO CWM TOUCH
    E ALTRO...
    NON FUNZIONA
    Radio
    Bugs da CM by FXP
    la fotocamera fa le foto al contrario (risolto v3.0)
    Ho provato la v3.0 ma temo che passerò alla v1.0 per continui riavvii
    Immagini allegate
    Ultima modifica di mark98; 20-11-12 alle 19:52
    Sony Xperia U ------->stock 4.0.4
    Samsung Wave 2 ------->[CM10.1] UNOFFICIAL Galaxiian ROM 4.2.2
    LG optimus l9 -------> Stock 4.1.2
  2. I seguenti 6 Utenti hanno ringraziato mark98 per il post:
    CuoreRossonero (15-11-12),Federico1999 (24-01-13),marce (15-11-12),Ovolollo (20-11-12),parodiniccolo (28-11-12),Ying96 (15-11-12)
    Ringraziato 659 volte in 518 Posts
    Almeno metti il link a xda!
    Inviato dal mio ST25i con Tapatalk 2
  5. #3
    Ringraziato 13 volte in 9 Posts
    ecco il link XDA: [ROM][AOKP] ..::AOKPXperia::. V 2.0 (Locked Bootloader) ..::SOON::.. [12/NOV] - xda-developers
    non capisco... bisogna installare Alpha 1, Alpha 2, Alpha 3, e V1.0?, oppure se bisogna installare uno solo di questi?
    Ultima modifica di vittotjet; 15-11-12 alle 05:54
  6. Il seguente Utente ha ringraziato vittotjet per il post:
    mark98 (15-11-12)
  7. #4
    Dovrebbe mettere il link per la v2!
  8. #5
    Caserta
    P20 / P10
    Mark ti ho inserito il link alla discussione e sistemati gli screen. Consiglio, leva tutti i vari changelog e lascia solo l'ultima rom rilasciata altrimenti a breve finirai i caratteri a disposizione. Mi raccomando tieni la discussione aggiornata.
    @Vitto quelle son le varie versioni rilasciate ma naturalmente andrai ad installare l'ultima disponibile
  9. Il seguente Utente ha ringraziato marce per il post:
    vittotjet (15-11-12)
  10. #6
    Qualcuno l'ha provata?
  11. #7
    Senior Droid L'avatar di Ying96
    Ringraziato 194 volte in 119 Posts
    adesso provo...
  12. #8
    Quote Originariamente inviato da Ying96 Visualizza il messaggio
    adesso provo...
    Grande poi facci sapere! Mi interessa molto il consumo della ram!
  13. #9
    per adesso bug riscontrati la fotocamera che fa foto al contrario e il wi fi , per il resto è molto fluido. la rom occupa 240 ram quindi rimane 150
    EDIT: il wifi si connette dopo un paio di tentativi direi che è molto stabile la rom
    Ultima modifica di Ying96; 15-11-12 alle 13:57
  14. #10
    I bug sono quelli della cm... Bene allora!
