Utente della settimana: bluemask con ben 15 Thanks ricevuti negli ultimi sette giorni
Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 38
[ROM] ICS U Clean 1.1 (Locked bootloader)
    Xperia U
    Ringraziato 5 volte in 2 Posts
    Wink
    HOT!! [ROM] ICS U Clean 1.2b (Locked bootloader)
    ICS CLEAN Versione Xperia U 1.2b
    • Android 4.0.4
    • ICS UI
    • Custom SystemUI/Framework
    • Stock ICS Apps
    • Rimosse SEMC Apps
    • Trebuchet Launcher
    • IO File Manager
    Installare:
    -Installare ICS di Sony
    -Rootare il Dispositivo e installa la CWM
    -Fare il wipe Data/Cache
    -Installare la rom .zip dalla memoria
    -Configurare l'account Google
    -Riavviare
    ScreenShot:
    Screenshot_2000_01_01_00_49_08.jpg Screenshot_2012_12_06_01_30_15.jpg Screenshot_2012_12_06_01_31_23.jpg Screenshot_2012_12_06_01_32_11.jpg
    Screen dalla versione 1.0 con Framework AOSP
    Bugs:
    Sovrapposizione tastiera dei contatti se si installa il Framework AOSP
    Versioni:
    Beta v0.3:
    Market is now Working
    SystemUI Modified
    Holo Launcher
    ICS Wallpapers
    ICS Icons
    Framework Modified
    Beta v0.4:
    New ICS Framework
    ICS Fonts
    Beta v0.5:
    Trebuchet Launcher
    System Tweaks
    New Status Bar Icons
    LED Bar Themes
    BootLoop, Google Search, Dialler Fixed
    Version v1.0:
    Based on New 6.1.1.B.1.54
    System Tweaks
    AOSP Framework and Status Bar
    Google Now Working
    KeyBoard Updated
    Flash and StatusBar Toggles Removed (Avaliable as an Extra)
    Version v1.1:
    More System Tweaks
    Torch(CM9) Added
    ICS Original LiveWallpapers
    AOSP SystemUI with Toggles
    Version 1.2:
    System Tweaks
    Torch(CM9) Removed Will be Added as an Extra soon
    AOSP Framework Finished
    Version v1.2b:
    Wi-fi Fixed
    Keyboard from ICS
    Minor Tweaks
    Versioni Download:
    Beta v0.1: Download
    Beta v0.2: Download
    Beta v0.3: Download
    Beta v0.4: Download
    Beta v0.5: Download
    Version v1.0: Download
    Version v1.1: Download
    Version v1.2: Download
    Version v1.2b: Download
    Extra:
    Installare gli Extra solo dopo averlo riavviato per la prima volta.
    BackUP&Restore: Download
    Flash Player: Download
    StatusBar Toggles: Download
    ROM testata personalmente, Tutto ok perfino la barra LED funziona.
    ROM presa da forum.xda-developers.com/showthread.php?t=1943184&highlight=ics+clean XDA
    Tradotta da me.
    Non mi assumo nessuna responsabilità per eventuali danni al vostro device.
    Immagini allegate
    Ultima modifica di MatrixU; 09-04-13 alle 21:04 - Motivo: Aggiornamento
  2. I seguenti 4 Utenti hanno ringraziato MatrixU per il post:
    armando988 (09-02-13),CuoreRossonero (09-02-13),Federico1999 (10-02-13),peppegio (10-02-13)
    Senior Droid L'avatar di armando988
    HTC ONE; Galaxy s4
    Ringraziato 116 volte in 110 Posts
    i link per i download non vanno.
  5. #3
    Xperia U
    Non me li hanno ancora abilitati, ma funzionano basta levare i due spazi
    Inviato dal mio Xperia U con Tapatalk 2
  6. #4
    HTC ONE; Galaxy s4
    ok grazie!
  7. #5
    Xperia U
    Prego ottima ROM vero?
  8. #6
    xperia u
    Secondo voi e meglio questa room o la cyano?
  9. #7
    HTC ONE; Galaxy s4
    la sto provando da poco!è fluida,pulita e veloce..molto bene per il momento!anche se forse ho riscontrato un altro bug..il servizio exchange per le mail push va in crash!
  10. #8
    Xperia U
    Quote Originariamente inviato da biddu Visualizza il messaggio
    Le ho provate entrambe, sicuramente la Cyano 9 ha un po più di personalizzazioni ma in quanto a stabilita e fluidità per me molto meglio questa. Te la consiglio vivamente Inoltre con la Cyano 9 la barra LED non funziona mentre con questa ROM si, poichè bastasta su firmware stock.
    Ultima modifica di MatrixU; 09-02-13 alle 16:58
  11. #9
    Xperia U
    Quote Originariamente inviato da armando988 Visualizza il messaggio
    Hai installato il framework AOSP?
    Ultima modifica di MatrixU; 09-02-13 alle 16:53
  12. #10
    HTC ONE; Galaxy s4
    Quote Originariamente inviato da MatrixU Visualizza il messaggio
    no,non ho installato nessun extra al momento.
