[ROM][WIP]AOSP 5.0 Beta v2.5 | Lollipop for Xperia Z1 [16-11-2014]
    Ringraziato 13 volte in 9 Posts
    Ciao ragazzi!
    so che ancora è in lavorazione ma volevo portarvi allo sguardo questa prima rom basata su AOSP con grafica Lollipop
    Direct Link [ROM][WIP]AOSP 5.0 Beta v2.5 | Lollipop for … | Sony Xperia Z1 | XDA Forums
    == Project status ==
    Working:
    - Bluetooth
    - Wifi
    - NFC??
    - LED
    - Texting
    - Calling
    - Sound
    - Sensors
    - Auto-Brightness
    - Vibration
    - Screen/Touch
    - SELinux
    - Recovery
    - everything that's not in the "not working list"
    Not working:
    - Camera
    - Mobile Data?
    - Youtube Video Playback
    - GPS
    == Updates ==
    I'm working on fixing bugs and making this rom a daily driver. This might take some time though.
    == Download ==
    Download all 4 files from the correct device folder, userdata and cache can be found in the common-files directory, system and kernel are in the version directories
    - Rom: Xperia Z1 AOSP 5.0 Beta v2.0
    - Gapps can be found in the main directory
    == Already on this rom?? ==
    No need to wipe data unless I tell it in the thread
    - Just flash system.img and boot.img using fastboot.
    You can flash gapps in the embedded recovery.
    == Installation instructions: ==
    - flash boot.img and system.img using fastboot
    - Boot into recovery, wipe data, dalvik and cache
    - You can flash gapps in the embedded recovery.
    Don't try this roms when you don't know what you are doing!!
    == Changelog ==
    codice:
     == Beta v2 ==
    - Sensors are fixed
    - first Z1 compact, Z2, Z3 and Z3 compact release
    - Latest 3.5.2.2 kernel
    - Mic is working while calling????
    - Auto-brightness fixed
    - Rotation is working
    == Beta v1.1 ==
    - Wifi is a lot more stable
    - Updated kernel
    - charging-LED is working now
    - Rom is more stable and supersmooth
    == Beta v1.0 ==
    - Bluetooth
    - Wifi
    - LED
    - Texting
    - Calling
    - Sound
    - Brightness Slider (autobrightness doesn't work yet, turn it off to make slider working)
    - Vibration
    - Screen/Touch
    == Screenshots ==
    In the screenshot part of devdb project are more screenshots
    XDA:DevDB Information
    [ROM][WIP]AOSP 5.0 Beta v2.5 | Lollipop for Xperia Z1 [16-11-2014], ROM for the Sony Xperia Z1
    Contributors
    krabappel2548
    Source Code: https://github.com/xperia-aosp-project?tab=repositories
    ROM OS Version: 5.0.x Lollipop
    ROM Kernel: Linux 3.4.x
    ROM Firmware Required: Unlocked bootloader
    Based On: AOSP
    Version Information
    Status: Beta
    Current Beta Version: 2.5
    Beta Release Date: 2014-11-18
    Created 2014-11-06
    Last Updated 2014-11-17
    Ultima modifica di vittotjet; 18-11-14 alle 02:24
  2. Il seguente Utente ha ringraziato vittotjet per il post:
    ptrizio (11-12-14)
    Androidiano VIP L'avatar di thereferee
    fixing...
    Zenfone 2
    Ringraziato 1,045 volte in 892 Posts
    Hummmm un copia incolla è meno faticoso vero, ma siamo su un forum italiano e molta gente non potrebbe capire l' inglese... Traducila in italiano altrimenti dovrò chiudere
    Quasi tutti quelli che parlano di calcio hanno giocato a calcio almeno una volta nella vita.
    Quasi tutti quelli che parlano di arbitri non hanno mai arbitrato una partita nella loro vita
    Nicola Rizzoli
    Chiudiamo pure, tanto non ne sono capace
  6. #4
    fixing...
    Zenfone 2
    Allora chiudo. Se si trova qualcuno che vuole tradurla, con piacere.
    Edit: guida tradotta https://www.androidiani.com/forum/sh...d.php?t=449124
    Ultima modifica di thereferee; 13-01-15 alle 23:29
    Nicola Rizzoli
