Pagina 6 di 14 primaprima ... 45678 ... ultimoultimo
Visualizzazione dei risultati da 51 a 60 su 133
LolliPop 5.02 NoBrand Italy, Deodexed, Zipaligned, Rooted, SuperSU e compat. Xposed
  1. #51
    Banned
    Apr 2011
    Usa
    Ringraziato 409 volte in 272 Posts
    Quote Originariamente inviato da mhazon Visualizza il messaggio
    Ciao volevo segnalare che oggi ho installato "Retrica", un'applicazione per la fotocamera, ma non si apre. Mi segnala che le OpenGl-Es 2.0 non sono supportate.
    Si è un problema che appare con Firmware Deodex.... sto provando a risolverlo m non è facile stay tuned
    Hispanico
    Ultima modifica di hispanico; 11-04-15 alle 09:08
    Banned
    Apr 2011
    Usa
    Segnalo che NUT ha aggiornato la DualRecovery che ora è compatibile con LolliPop, versione 2.87:
    XZDualRecovery 2.8.7 Released!
    RELEASE Change log:
    Version 2.8.7:
    Fully debugged for use with Sony's Lollipop and restored functionality on KitKat on all supported models. Both for locked bootloader installations and the XZDualRecovery Advanced Stock Kernel builder.
    Included the byeselinux patch by @zxz0O0 , heavily modified. It will unload the module when booting to the ROM to restore SELinux functionality.
    Converted XZDR from using my own solution to the more elegant 'wp_mod' method by @MohammadAG . It now uses my own solution as a backup.
    Made sure the modules will only be installed when required either by device or ROM version.
    Updated the flashable package to do the same.
    Updated the included NDR Utils to the latest version.
    Updated the (installer) included adb binaries to the current latest version (Required when using TWRP 2.8.6.0 and newer).
    The installer and the chargemon hijack script will now make a copy of the init 'rc' files to /system/.XZDualRecovery to be used during updates using the flashable zip, this way the (long!) list of firmwares in the installdisableric.sh script can be discarded in the future, which was only used in the flashable package because these init rc files are unavailable while in recovery.
    Z3C-lockeddualrecovery2.8.7-RELEASE.installer.zip
    Z3C-lockeddualrecovery2.8.7-RELEASE.flashable.zip
    Al momento vi consiglio di non aggiornare in quanto c'è qualche problemino sull'update da 2.83... stay tuned
    Hispanico
    UPDATE 12/04/2015 Molti problemi relativi a Mount e wipe ... NON CONSIGLIATA dallo stesso NUT
    Ultima modifica di hispanico; 12-04-15 alle 20:18
  4. Il seguente Utente ha ringraziato hispanico per il post:
    Shikaiya (11-04-15)
  5. #53
    Androidiano VIP L'avatar di Shikaiya
    Sep 2014
    Ringraziato 304 volte in 251 Posts
    @hispanico, giusto un'info prima di procedere. Il Flash del tuo MOD, cancellerà i dati del terminale, anche se si fanno solo i Wipe Cache e Dalvcik? Ho già fatto il backup della ROM e sto procedendo all'installazione del Modulo e poi di eXposed
  6. #54
    Banned
    Apr 2011
    Usa
    Quote Originariamente inviato da Shikaiya Visualizza il messaggio
    Bè se hai fatto il backup...buona cosa. Relativamente ai dati, rimangono tali sempre se hai seguito la mia guida.
    Fammi sapere...
    Hispanico
    Ultima modifica di hispanico; 11-04-15 alle 13:11
  7. Il seguente Utente ha ringraziato hispanico per il post:
    Shikaiya (11-04-15)
  8. #55
    Sep 2014
    [quote name="hispanico" post=6761338]Bè se hai fatto il backup...buona cosa. Relativamente ai dati, rimangono tali sempre se hai seguito la mia guida.
    Fammi sapere...
    Hispanico[/QUOTE]
    Fantastico. Installato pure il secondo tweak SystemUI e... non ho parole, troppo figo GRANDE H I S P A N I C O
    Edit: @hispanico Come si fa un soft reboot ed entrare subito in Recovery? Ossia, installato l'apk di Xposed, dici di fare un soft reboot ed entrare in Recovery... tenendo premuto il tasto Vol. +?
    Scusa. Capito. Grazie 😁
    Ultima modifica di Shikaiya; 11-04-15 alle 16:23
  9. Il seguente Utente ha ringraziato Shikaiya per il post:
    hispanico (11-04-15)
  10. #56
    fra47
    Ho notato che lo street view di Google maps va in crash, è un problema che ho solo io o lo notate anche voi?
    Inviato dal mio Sony Xperia Z3 Compact usando Androidiani App
  11. #57
    Sep 2014
    Quote Originariamente inviato da fra47 Visualizza il messaggio
    No a me funziona
  12. #58
    Banned
    Apr 2011
    Usa
    No a me funziona
    Anche a me tutto OK
    Hispanico
  13. #59
    Ringraziato 42 volte in 40 Posts
    Scomparsa la recovery anche a me e sigyc tornato a dare problemi... Peccato perché mi trovo bene assai con questa mod ma mi serve più il telefono apposto mi da che per il momento rimetto tutto stock con root e basta...
  14. #60
    Banned
    Apr 2011
    Usa
    Quote Originariamente inviato da gi4ngi Visualizza il messaggio
    Guarda che forse è il tuo cell che ha qualche problema forse... io lo uso quotidianamente con questa configurazione e non ho problemi, compreso sigyc
    Hispanico
  15. Il seguente Utente ha ringraziato hispanico per il post:
    Shikaiya (13-04-15)
